Sounds like an obvious thing to want to do right? Problem is that the existing systems of modes and hello home actions won’t allow you to do this - you need to use a SmartApp. There have been several variants posted on the forum at different times. Here is mine, it is a modified version of “Honey I’m Home”. It uses 2 Hello Home Phrasees that you can set to turn lights on or off, and optionally change modes. You enter an offset from sunrise and sunset and give it a list of presence sensors to monitor and it does the rest. Its been working great for me.
* Honey, I'm Home!
* Author: oneaccttorulethehouse@gmail.com
* Date: 2014-01-26
* Heavily borrowed from Night Light/Sunrise/Sunset and Greetings Earthling.
* Will turn on lights and change the mode when someone arrives home and it is dark outside.
// Automatically generated. Make future change here.
definition(
name: "Honey I'm Home",
namespace: "aimc",
author: "Andrew Cockburn",
description: "asd",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences
page( name:"Settings", title:"Settings", nextPage:"selectPhrases", uninstall: true )
section("When one of these people arrive at home")
input "people", "capability.presenceSensor", multiple: true
section ("Sunrise offset (optional)...")
input "sunriseOffsetValue", "text", title: "HH:MM", required: false
input "sunriseOffsetDir", "enum", title: "Before or After", required: false, metadata: [values: ["Before","After"]]
section ("Sunset offset (optional)...")
input "sunsetOffsetValue", "text", title: "HH:MM", required: false
input "sunsetOffsetDir", "enum", title: "Before or After", required: false, metadata: [values: ["Before","After"]]
section ("Zip code (optional, defaults to location coordinates)...")
input "zipCode", "text", required: false
section( "Notifications" )
input "sendPushMessage", "enum", title: "Send a push notification?", metadata:[values:["Yes","No"]], required:false
input "phone", "phone", title: "Send a Text Message?", required: false
section([mobileOnly:true])
label title: "Assign a name", required: false
mode title: "Set for specific mode(s)", required: false
page(name: "selectPhrases")
def selectPhrases() {
dynamicPage(name: "selectPhrases", title: "Configure", uninstall:true, install:true) {
def phrases = location.helloHome?.getPhrases()*.label
if (phrases) {
phrases.sort()
section("Run This Phrase When...") {
log.trace phrases
input "lightPhrase", "enum", title: "It's light", required: true, options: phrases, refreshAfterSelection:true
input "darkPhrase", "enum", title: "It's dark", required: true, options: phrases, refreshAfterSelection:true
def installed()
log.debug "Installed with settings: ${settings}"
log.debug "Current mode = ${location.mode}, people = ${people.collect{it.label + ': ' + it.currentPresence}}"
subscribe(people, "presence", presence)
def updated()
log.debug "Updated with settings: ${settings}"
unsubscribe()
private isDark(rt, st)
def dark
def t = now()
dark = t < rt || t > st
dark
def presence(evt)
log.debug "evt.name: $evt.value"
if (evt.value == "present")
def s = getSunriseAndSunset(zipCode: zipCode, sunriseOffset: sunriseOffset, sunsetOffset: sunsetOffset)
def riseTime = s.sunrise
def setTime = s.sunset
log.debug "riseTime: $riseTime"
log.debug "setTime: $setTime"
def Phrase
if (isDark(riseTime.time, setTime.time))
Phrase = darkPhrase
else
Phrase = lightPhrase
def person = getPerson(evt)
def message = "${person.displayName} arrived at home, executing '${Phrase}'"
log.info message
send(message)
location.helloHome.execute(Phrase)
private send(msg)
if ( sendPushMessage != "No" )
log.debug( "sending push message" )
sendPush( msg )
if ( phone )
log.debug( "sending text message" )
sendSms( phone, msg )
log.debug msg
private getPerson(evt)
people.find{evt.deviceId == it.id}
private getSunriseOffset()
sunriseOffsetValue ? (sunriseOffsetDir == "Before" ? "-$sunriseOffsetValue" : sunriseOffsetValue) : null
private getSunsetOffset()
sunsetOffsetValue ? (sunsetOffsetDir == "Before" ? "-$sunsetOffsetValue" : sunsetOffsetValue) : null
