I am writing a smartApp that schedules a light to turn on and then off again at a given time.
When I try to install the app in the IDE for testing, I get a groovy runtime exception.
groovy.lang.GroovyRuntimeException: Ambiguous method overloading for method script1415065329498578984625#runDaily.
Cannot resolve which method to invoke for [null, class java.lang.String] due to overlapping prototypes between:
[class java.lang.String, class java.lang.Object]
[class java.util.Date, class java.lang.Object] @ line 99
The code I’m writing is below. Can someone try this and see if you get the same error? And perhaps explain why?
Thanks in advance,
Mike
definition(
namespace: "mlupo",
author: "michael lupo",
description: "Turn the foyer lamp on 1.5 hours before sunset and leave on till 11:59pm.",
category: "Safety & Security",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section ("At sunset...") {
input "sunsetMode", "mode", title: "Change mode to?", required: false
input "foyerOutlet", "capability.switch", title: "Turn on?", required: false, multiple: true
section ("Sunset offset (optional)...") {
input "sunsetOffsetValue", "text", title: "HH:MM", required: false
input "sunsetOffsetDir", "enum", title: "Before or After", required: false, options: ["Before","After"]
//section ("How long to leave the light on for? MINUTES (ie. 90)") {
// input name: "minutes", title: "Minutes?", type: "number", multiple: false
//section("What time to turn the light off?") {
// input "time1", "time", title: "When?"
section ("Zip code (optional, defaults to location coordinates)...") {
input "zipCode", "text", required: false
section( "Notifications" ) {
input "sendPushMessage", "enum", title: "Send a push notification?", options: ["Yes", "No"], required: false
input "phoneNumber", "phone", title: "Send a text message?", required: false
def installed() {
initialize()
def updated() {
unsubscribe()
//unschedule handled in astroCheck method
initialize()
def initialize() {
subscribe(location, "position", locationPositionChange)
subscribe(location, "sunsetTime", sunriseSunsetTimeHandler)
astroCheck()
def locationPositionChange(evt) {
log.trace "locationChange()"
astroCheck()
def sunriseSunsetTimeHandler(evt) {
log.trace "sunriseSunsetTimeHandler()"
astroCheck()
def astroCheck() {
log.debug "sunsetOffset is: $sunsetOffset"
def s = getSunriseAndSunset(zipCode: zipCode, sunriseOffset: sunriseOffset, sunsetOffset: sunsetOffset)
def off = getSunriseAndSunset(zipCode: zipCode, sunriseOffset: sunriseOffset, sunsetOffset: sunsetOffset)
def now = new Date()
def sunsetTime = s.sunset
log.debug "sunsetTime: $sunsetTime"
if (state.sunsetTime != sunsetTime.time) {
state.sunsetTime = sunsetTime.time
unschedule("sunsetHandler")
if(sunsetTime.before(now)) {
sunsetTime.next()
log.info "scheduling sunset handler for a sunset at: $sunsetTime"
runDaily(sunsetOffSetTime, sunsetHandler)
def sunsetHandler() {
log.info "Executing sunset handler. Will turn off the outlet at 11:59pm."
if (foyerOutlet) {
foyerOutlet.on()
changeMode(sunriseMode)
outletOff()
def changeMode(newMode) {
if (newMode && location.mode != newMode) {
if (location.modes?.find{it.name == newMode}) {
setLocationMode(newMode)
send "${label} has changed the mode to '${newMode}'"
else {
send "${label} tried to change to undefined mode '${newMode}'"
private send(msg) {
if ( sendPushMessage != "No" ) {
log.debug( "sending push message" )
sendPush( msg )
if ( phoneNumber ) {
log.debug( "sending text message" )
sendSms( phoneNumber, msg )
log.debug msg
private getLabel() {
app.label ?: "SmartThings"
private getSunriseOffset() {
log.debug "DEBUG: getting offset value"
sunsetOffsetValue ? (sunsetOffsetDir == "Before" ? "-$sunsetOffsetValue" : sunsetOffsetValue) : null
def outletOff() {
//log.debug "called outletsOff() and delaying turning off the outlet till ${time1}"
log.debug "called outletsOff() and delaying turning off the outlet at 11:59pm"
schedule("00 59 23 * * ?", scheduledTurnOff)
//schedule(time1, scheduledTurnOff)
def scheduledTurnOff() {
foyerOutlet.off()
unschedule("scheduledTurnOff") // Temporary work-around to scheduling bug
