Govee water sensors and SmartThings integration
Can someone please figure out a way to integrate Govee water sensors into SmartThings?
They are probably the most popular water sensors in the world right now. I am using them with ifttt triggers but the integration is unreliable.
Govee has no integration with SmartThings.
Water leak sensors which integrate with SmartThings are listed here
I use Aqara water sensors tied to an Aqara Hub BUT not visible through Matter Bridge into SmartThings. You can directly pair into SmartThings using custom drivers but I found that thise devices consistently went offline. Hopefully Aqara will add these devices to Matter to facilitate SmartThings integration.
I’ve never had an issue getting the Aqara water leak detectors registered natively nor have i had drop issues.
Like always zigbee device stability is as much a function of the zigbee network as it is anything else. Not saying other things like a driver cant cause issues but topology really matters with the aqara implementation zigbee.
