Read the installation instructions for the Pi. They recommend a change on the config. I had this same problem until I did the change and then worked.
I did, tried it all twice. Based on the instructions in this posted issue, I did the following:
sudo apt-get update
sudo apt-get upgrade
curl -sL https://deb.nodesource.com/setup_7.x | sudo -E bash -
sudo apt-get install nodejs:
sudo apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev
Then cloned project and ran npm install
Then modified vi node_modules/mdns/lib/browser.js
Then modified example.js replacing Google Home with name of my device, Kitchen Home
Did you do this?
After ānpm installā
Modify the following file ānode_modules/mdns/lib/browser.jsā
Find this line:
Browser.defaultResolverSequence = [
rst.DNSServiceResolve(), āDNSServiceGetAddrInfoā in dns_sd ? rst.DNSServiceGetAddrInfo() : rst.getaddrinfo()
, rst.makeAddressesUnique()
And change to:
rst.DNSServiceResolve(), āDNSServiceGetAddrInfoā in dns_sd ? rst.DNSServiceGetAddrInfo() : rst.getaddrinfo({families:[4]})
Yes
(10 characters)
In example.js did you try setting the name to one of the āGoogle-Home-xxxā strings listed in the debug? I couldnāt get my friendly names to work but those internal names work for me.
Same here. The default worked but my own name didnāt.
Youāre talking about the āGoogle-Home-clasmlc939hr3anfp9aw393fjwhateverā name thatās in the output? I have not tried that, I use the āKitchen Homeā name that I assigned through my Home app. Iāll give this a try when I get home. Thanks for the idea
I used the original name from the config which I believe was āGoogle-Homeā.
I tried changing it and wasnāt working and I rolled back to original and
workedā¦
That was it guys, thanks. I used the long name Google Home-lknasclascon9f38903jf0w93f and itās working now. Thanks!
@Ev1l5anta did you say in another thread that you had this working through CoRE? Iām trying to get it set up but it looks like CoRE can only do JSON and FORM content, while google-home-notifier seems to require application/x-www-form-urlencoded content. If itās working for you, how did you set up?
It does work. I will check and send what I used.
You should use FORM. You need to initialize a variable with a value which you will use. I created multiple with something like text=whatever I want it to say
Can you post a screenshot by chance? I have been trying to send variables and itās not working.
Hereās the piston setup. The variable text is set to value of Hello:
Hereās the console log. No data between the brackets:
Hereās what Wireshark shows as the incoming request. Note that the format is [variable name]=[variable value]
For comparison, hereās what I see when using the example cURL with the -d (application/x-www-form-urlencoded) content request.
Request:
Console log:
Wireshark:
I tried using cURL to send a FORM request instead of the encoded request and it responded the same as my CoRE piston above.
A screenshot of yours would be really helpful if you donāt mind.
When I execute this -> curl -X POST -d ātext=Hello Google Homeā https://ae474203.ngrok.io/google-home-notifier I get the following output on my Pi:
{ text: āHello Google Homeā }
Device āGoogle-Home-76475acb66ca2e7225c2d03247435263ā at 192.168.1.141:8009
Device āChromecast-41a5b7694d0677c433d89bf2058b0c6eā at 192.168.1.136:8009
Device notified
When you initialize the variable, it should be called text and the content on the variable content field.
It should not be text= or text:, just text
This should work even though I have not been able to test now. Give it a try.
Unless Iām misunderstanding, what you are describing is exactly what I had posted above. My variable name is ātextā (without the quotes), and the variable value is āHelloā (without the quotes).
As far as I can tell, the issue is that CoRE is sending the ātext=Helloā as part of the URL (which it should not be doing in a POST request), whereas cURL is sending correctly as part of the request body.
CoRE request:
cURL request:
Got this working - awesome. Thank you all for this thread, it really helped.
Can you share how you got your CoRE settings so it can help others? Iām traveling and cant play to get the settings good again to share.
Iām getting exactly the same results as @destructure00
Second time that Iāve had to delete my post, lol. I got core to work. The literal name of the local variable must be text. Then the raw value will be what you want it to say. Other then that is post and form. Iām using the internet URL with the port forwarded to my rPi
Unless Iām misunderstanding you, thatās exactly what Iām doing (except Iām sending it over my local intranet). Hereās my piston:
Can you post a picture of your piston for comparison?
