Global variables and Callbacks
How do you achieve global variables in Groovy. I have looked at some examples on line but cannot get them to work. In a nut shell I have a sendHubCommand that has a callback associated with it. What I would like is to update some global variable and then use that data in another method. I have tried using
@Field String array = new String[10]
def callback(…)
array = {…}
log( array )
def anotherMethod()
log(array)
In the above example the log outputs the value the populated array from the callback method. However, when being output in ‘anotherMethod’ it is always empty. I have tried loads of different combinations but to the same avail.
How can I achieve this.
Steve
Use state.array = […] in callback() and then you can access it from anotherMethod()
state is a global object of type map
Take a look at Edge Drivers! They run locally and allow automations to run the same way (depending on the Automation config)
There are different samples than can help you get started:
