"Get your location from this phone"
You have or have had Multiple locations too?
I’ve been dealing with this issue for the last 2 days and I’m about to lose my mind. I’ve deleted and reinstalled enough that I’ve timed out on both the 2fa text and calling. I’ve removed my phone and my wife’s phone from the smarthings IDE. I’ve rebooted my hub 500 times, I’ve tried it on wifi and off wifi and it’s not working. I’m at a loss here and getting super frustrated.
report the issue to ST support.
Several posts seem to say that this is a problem if you have (or ever had) more than one location associated with your account… Don’t know for sure, but seems possible. It’s certainly driving me mad!
I am having the exact same issue on an iphone. I deleted app, reinstalled, signed out, restarted phone. Nothing works. Can not toggle it on.
also having this issue!
Well… I submitted an error report and they have asked me for additional information (screen recording showing the problem and error logs from my app), so it appears that they are actually working on this. (I hope so!)
It may or may not help, but if you want to report the problem to them, you might want to reference the existing error report -
Re: 1500706 | Cannot turn on “Get your location from this phone”
(You can send problem reports to support@smartthings.com)
I am also having the same problem.
I am registered as the location owner.
I have two users associated with my location, me and my wife. Both are iPhone 14 pro users.
She has two locations associated with her phone. I have one location.
She doesn’t have the problem but I do.
I have tried support via chat and they are not able to help. Will call the support number a bit later to open a ticket.
This is also affecting me. Got 2 new iphones and trying to get things moved over.
Samsung support is garbage as usual. I’ve already opened up a ticket with them.
Below is their candid response thinking everyone is on an android. lol
Dear Customer,
Thank you for contacting us. We appreciate the opportunity to assist you.
I understand from your inquiry that you have encountered an issue in the Smartthings app.
First of all, please make sure you have a strong and stable network connection, then access your phone’s Settings menu and select Apps > SmartThings > Force Stop > Storage > Clear Cache and Clear Data.
Then, if the issue persists, go back one and tap on Uninstall, then open the Samsung Galaxy Apps or Google Play Store and install the application again. This will ensure that you have the latest version installed.
Finally, register your device(s) again and try to use the application.
Should the issue persist, please contact us again with the below information so we can send your case for investigation to the application’s developer team:
  • Application version (open SmartThings > three dots menu in the top right corner > Settings > About SmartThings > Version):
  • Model of devices (phone and device that you would like to connect with it):
  • Screenshots of the error message that appears
  • Log Files
To take a screenshot, please press and hold the Home and Power buttons at the same time. On the newer models without the Home button, press and hold the Power and Volume Down buttons instead.
After that, follow the below step to get the Log Files of your phone:
  1. Open the Dial pad on your phone
  2. Type in *#9900#
  3. Select “Delete dumpstate/logcat”
  4. Reproduce the issue by opening the SmartThings application
  5. Select “Run dumpstate/logcat”
  6. Select “Copy to sdcard(include CP Ramdump)”
  7. Connect the phone using a USB cable with a PC/Laptop
  8. Using explorer, find your connected device and go to “/sdcard/log” folder
  9. Zip (compress) all the files and send it to us by going to https://help.content.samsung.com > Contact us > select SmartThings as a service and fill in the required fields.
You can also get the log files like so: Run app > Select ≡ > Select Contact us > Select Error reports.
If you encounter any other unexpected situation and have more questions, please do not hesitate to send us your request by using the “Contact us” option on http://account.samsung.com and our support team will assist you with all the necessary information.
You can also reach us by accessing our website at https://samsung.com/support/your-service, selecting “Sign in” > “App Inquiry” > filling in the form and tapping on “Submit”, or through the Samsung Members app on your mobile device.
Thank you for using our services. Your satisfaction is very important to us.
Kind regards,
Cesar
Customer Service Center
It does not matter that you don’t have an Android device. These steps don’t fix the problem on those devices either.
Hmm… It just started working again (at least for me). Maybe they fixed it?
I sure hope so!
I went to go through the troubleshooting steps, that I’ve done 100 times, and deleted the app, reinstalled, and then attempted to turn on the feature again. Well it worked this time, so I’d say they fixed the issue.
Mine started working also. SO glad I can get back to normal. Hopefully it’s permanent!!
Same here. I didn’t even redo any steps. Just went straight to the setting and flipped the switch on. The only thing that I had to was reassign my phone again to the automations that used location awareness setting.
Yep, I was able to turn on location tracking for my second location today without changing anything.
Yes mine started working as well
Mine is working too. They obviously had a problem in the background that has been fixed. I’m going to mark this thread as solved.
I was having the same difficulty as many others in setting my Geolocation (address) in order to use the functions of my new SAMSUNG Series 6 OptimalDry DV80T5220AW/S1 Wi-Fi-enabled 8 kg Heat Pump Tumble Dryer – White. (S/N: 0VG65AEW600081D), & I was growing increasingly frustrated every time I tried to set it.
I initially looked on the boards & whilst I read that many others were having the same issue, nobody had found a fix at that time. So I contacted Leslie via Chat Support at Samsung online when registering my dryer for warranty purposes.
I explained to Leslie that I recently bought a SAMSUNG Series 6 OptimalDry DV80T5220AW/S1 Wi-Fi-enabled 8 kg Heat Pump Tumble Dryer – White. (S/N: 0VG65AEW600081D) & that I had linked my new appliance with the SmartThings App on my mobile phone. The SmartThings App came pre-installed on my phone & is already linked to my Samsung Smart TV with no issues. However, I could not set up my ‘Geolocation’ as required in order to avail of certain tumble dryer functions. I outlined the problem to Leslie as follows:
Under the tab: Tumble Dryer/Remaining Laundry/Going Out Mode:
When I toggled the button for ‘Going Out Mode’ to the on position, a pop-up appeared on-screen telling me to set the location of my dryer to use ‘Going Out Mode’.
When I clicked on ‘set’ it brought me to the page which shows a map, radius area & the option to cancel or save. (I attached a screenshot). Despite the fact that the location marker/arrow was directly pointing to the location of my house, the app told me: ‘Unable to save. Address empty’. (Again, I attached a screenshot). Obviously, the address is not empty but no matter what I did it would not recognise my geolocation & save my address.
I tried to manually search for my address using my Eircode which is the most accurate means of locating an address in Ireland, & every possible connotation of my address that I could think of – no joy. The app still wouldn’t recognise my address, despite the fact that the map clearly showed the name of the area I live in & other buildings/businesses in the area. (I attached another screenshot).
Having paid €829.98 for a smart dryer expecting to be able to use all the functions available I was most disappointed & felt it really was not good enough, that the SmartThings app, used to control Samsung smart tumble dryers, did not work effectively so that ALL functions of the dryer could be activated by the user.
Unfortunately, Leslie was unable to provide a solution, but she did give me the email address to contact customer support specifically for the SmartThings App.
I sent an email outlining the above with several screenshots to support@smartthings.co.uk & opened a ticket to find a solution to the problem.
Next, I received an email from Customer Service at SmartThings which stated that they had received my query & aimed to respond to me within 3 working days. Depending on the query, the support team required access to my SmartThings account in order to provide a resolution. You have the option to allow or deny access to your account to help resolve your query – however if you deny access, they can only provide you with limited support.
I allowed the support team access to my SmartThings account by giving them the registered email account of the Samsung Account I use with the SmartThings App & I followed these steps to grant the SmartThings Support Team with access to my account for the period of 1 week in order to give them time to resolve my query:
Go to SmartThings Web online:
  • Log in to your Samsung Account.
  • Select the Menu (⋮) & choose Settings.
  • Toggle on Account Data Access.
  • Select the time period & choose Confirm.
If the support team are unable to investigate your request during the time period that you have selected for account access, they may need to ask you to extend it so that they can resolve your issue.
Over the course of the last 8 days, Alex from SmartThings Support has helped to find a ‘fix’ for the problem. He initially contacted me requesting the following information, as first & foremost, you will need to ensure that your phone works with the SmartThings App & appliance:
  • Phone make & model.
  • Phone operating system version.
  • SmartThings App version.
Obviously, you will need to ensure that the latest version of the app is installed on your device; you can do this within the SmartThings app by:
Tap the 3 lines at the bottom > tap the gear icon in the top right corner > tap about SmartThings.
Here it will state if the latest version of the app is installed on your device; if not you will need to install an update from your app store.
I provided Alex with the information he requested & in this instance, all was in order. My phone, the SmartThings App & my appliance were all compatible & the latest version of the app was already installed on my device.
Alex contacted me again stating that he was going to escalate this issue for it to be looked into & that as soon as he had an update to share, he would get back to me.
He came back to me with the following information:
  • Check that all location data service settings are enabled on your phone.
  • Also, make sure that location services are enabled for the SmartThings App as well (Tap the 3 lines at the bottom of the app > Tap the gear icon in the top right corner > Tap Get your location from this phone).
  • If all of the settings are enabled, scroll around the map to check if the app can find other addresses.
  • If the app still cannot identify the correct address, please generate & send us dumpstate logs straight after trying this by following the below steps:
  • Open the Phone app > Enter *#9900#
  • Run Dumstate/Logcat > (Wait until the dump result pop up)
  • Copy to device storage (Include cp ramdump) > (Wait until the copy is successful)
  • Send that log file to SmartThings Support in your email response
… they will keep an eye out for your response.
I am now able to set the Geolocation in the SmartThings App.
All location settings were enabled on my phone/device; however, location services were NOT enabled in the SmartThings App itself. Please note that the app did NOT request permission to access my location or request that I enable location permission when I was trying to set my geolocation. It did not request that I enable any app permissions in order to use the functions available or to set the geolocation.
That is probably where the issue lies for the majority of users that are experiencing the same problem I imagine. Like me, I expect the majority of users that were having this issue thought that connecting to Wi-Fi, pairing to their appliance & enabling location settings on their device should allow them to set their geolocation. However, this will NOT work unless the SmartThings App itself has been allowed access to your location settings. Perhaps the app seeks permissions immediately after downloading & installing on a device (I don’t know as it was preinstalled on my phone - without permissions enabled) & if not set at that point they have to be enabled later by the user but they may not be alerted to the fact that this is required.
The SmartThings app itself did not request permission to access my location in order to set my address or geolocation, it just kept saying ‘unable to save. address empty’, instead of requesting that I give the SmartThings app permission to access my location all the time. Also the fact that the address/geolocation has to be set under two separate headings on the App adds to the confusion, i.e. ‘Get your location from this phone’ & under ‘Going Out Mode’ under ‘Remaining Laundry’.
If the user clicks on the ‘Remaining Laundry’ tab before ‘Get your location from this phone’ it says ‘set the location of my dryer’ to use going out mode, Then when you click on ‘set’ it brings the user to the page which shows a map, radius area & the option to cancel or save. Then despite the fact that the location marker/arrow may be directly pointing to the location of the users house, the app will display a message reading ‘unable to save. address empty’. Searching for an address will also be pointless - further frustrating the user. This presumably occurs because the SmartThings App location permissions have not been enabled on the users device, as the user is not made aware that it is required because there is nothing to alert them to that fact.
I contacted SmartThings Support to advise them that their ‘fix’ had worked & I received a further email with more advice from Keith at SmartThings Support.
He gave me the following link which he said may be helpful as it explains some of the things, I’ll be able to use SmartThings for:
IMPORTANT: Whilst it doesn’t mention it in the link above, the ‘Smart Control’ feature needs to be turned on each time you turn on & load the machine. Further information regarding the ‘Smart Control’ functions is available on page 38 of the appliance manual.
‘Smart Control’ is enabled by pressing the same button you use to initially connect the appliance to Wi-Fi, but this time you won’t have to hold it down for so long – just until the icon appears on the digital display of your tumble dryer. ‘Smart Control’ turns off automatically when a cycle finishes; or, if you have ‘Stay Connect’ enabled in the app, when the door is open. Apparently, this is a safety feature to stop the possibility of a child, for example, entering the drum before a cycle is started remotely. Without the ‘Smart Control’ being enabled, you’ll have limited control via the app.
Also, on a different issue, depending on where you purchased your dryer from, it may qualify for a free five-year warranty if it’s listed as a qualifying device – search fiveyearwarranty on the Samsung website.:
This page is from the UK website, however, it does state in the terms & conditions that purchases can be made in the ROI, & there’s a number for ROI claimants as well (0818 717 100). Please make sure that if you have purchased from a participating store, that you claim within 90 days of the purchase.
So, I hope that this may be of benefit to any reader who encountered the same difficulty as I did in setting the ‘Geolocation’ in the ‘SmartThings App’.
However, if you’re still experiencing difficulties contact the guys at SmartThings Support for further information – they provide an excellent service & are quick to respond to any queries in a clear, concise & timely manner. Just follow the links above or email the address noted above.
i suppose this is the place to ask, ive been looking for you guys… im having a problem with creating a scene that turns off the lights when i leave… locations just wont change. do i have to create a scene that changes the mode to away? or is this natively done? is there anyone that can assist me here on how to create a basic scene? or routine? also… is the word Scene banned all of a sudden? the word scene doesnt event exist anymore in my ST app… thanks
