Get ready to make the switch!
Does anyone know how to create a virtual switch in the new app?
Apparently I need a dozen to get everything working again, and the ones I created with ‘Alexa virtual device Creator’ are not usable on the new app!
Then when I try to do it the old way in the soon to die IDE it says.
Access Denied
We’re sorry, but you are not authorized to perform the requested operation.
I know - I just don’t get why they can’t just add the information - it’s incredibly annoying not to have the ability to know why something happened (Yes, I know I can go to the IDE - but that’s not the point).
update,
I figured this part out at least
I Had to use incognito mode on the web browser
Yep. And why this is necessary sometimes has never been explained. Just another frustration.
With all these changes I am trying to use Modes to help coordinate changes between STHM, new Automations , Webcore and ActionTiles
Couple issues…
-changing mode names in new app does not update the modes for my location that show in the IDE. Also changing them in IDE didn’t update new app either. Neither seemed to update ActionTiles
-would be nice if the current Mode showed at the top of the new app home screen in the under-utilized empty space (between location name and temperature maybe???)
It appears that the new app uses a different databases to store things (device existence, device names, room assignments, device history, etc). The Classic app and the IDE use the “legacy” databases. There seems to be multiple back-end services that exist to synchronize changes from one set of databases to the other set. At times this synchronization either gets delayed or breaks. This may help explain what you are seeing.
…And they seem to get out of sync a lot. I still haven’t figured out which activities force a sync.
STHM and location modes seem totally screwed for me.
My arrive home automation doesn’t switch disarm STHM but my leave home switches the STHM to arm.
Secondly if I create a new automation which has a precondition of the “Away” location mode, I can then switch the location mode on the “Then” section.
But if I remove the precondition I am not given the option to add it back in
That’s expected behavior - and part of the modification they made to allow location mode to be both in the IF and THEN parts of an automation - their first iteration didn’t allow it (to prevent race conditions) and they quickly heard from the community that it was necessary and so they changed it… .BUT ONLY IF the location mode is set as a precondition.
This one just needs to be looked at from a troubleshooting perspective, what automation is disarming STHM, screenshot?
Thanks @nathancu,
This is the routine:
And looking at the messages it shows that the routine runs but the security isn’t disarmed so 8f you see below it clearly shows the routine runs but the security is triggered when I open the door
Looks setup correctly - Looks like you get to have fun with support.
Yeah I have already raised a support ticket but not expecting much, all I ever get is “Your query has been forwarded to the correct department”
I can really see people’s pain now, I am very new to SmartThings (Started in the new app)…
But recently with the outages and all the basic automations not working as expected I am getting really annoyed to the point where my home was smarter before SmartThings.
Short version: “Is there a white list”?
Longer: In the spirit of getting ready, I decided to refresh my ZW network. I noticed a warning/error message (“Could not update neighbors”) with one of my devices, a FS20Z-1 relay, so I decided to remove/re-add the device in an attempt to fix.
What an aggravating experience. I could not get the device to remove - tried all the suggestions in the related posts (this device is known to be tricky to unpair apparently), tried a secondary controller which always works with my other devices, no joy. I could force removal in IDE, but since I can’t unpair the device itself it could not be re-added… After 1.5hrs of various different attempts, I’ve decided the device itself must have become defective and want to just to replace it with a new fan switch.
So my question is - how do I know the product will be on the “white list” for ST supported devices post IDE/groovy sunset? I’m looking at basic fan control switches, which I would hope are just natively supported but not sure how to verify that pre-purchase.
Well, I made the switch over the weekend. I’ve had to clean up a few things around routines that didn’t go quite right but that wasn’t too hard. The dumb things is it appears you can only use a scene in one automation. For instance, changing to night mode and away mode is supposed to turn off all lights. However the All Lights Off scene could only be used with one, the other I had to duplicate turning all the switches off.
The SMH is another. I created three simulated switches, one for each alarm mode. Then created and automation that when I turn on a switch, the automation set’s the SMH to that mode and turns off the other two switches. And for each mode I created an automation that if the mode changed, such as the night mode turning on armed stay, the automation would turn on that switch. That way the switches stay in sync with the SMH mode. Thankfully I only had one webcore piston that disarmed SMH by code so it didn’t create a lot of grief, I just changed it from using the set smh command to turning on the disarm switch.
I also did have to re-authorize some things like IFTTT, Sharptools etc if they didn’t work.
You should definitely be able to use a scene with more than one automation, that’s kind of the whole point of scenes. There are sometimes issues if a scene changes something which is also changed in the automation.
@jkp would know more. Meanwhile, can you post a screenshot of the automation and the scene that didn’t work together?
We would probably need to see screenshots of the automations and scenes to determine what was going on. I know you can’t use two scenes if they happen to have the same device in both.
Anybody else just lose all of their room sorting settings in the iOS app?
My rooms are fine but they do lose their sorting every now and again on their own (not related to signing out/in)
Hey, @georgeh. I posted concerns about zwave control in the new app here Get ready to make the switch! and had a similar issue to you. Zwave control in the new app sucks, devices can be deleted but no force remove. I really hope they fix this or I’ll probably end up moving all my zwave devices to something else.
