I’ve got several of the GE Outdoor Switches (outlets).
Which Device Type Handler should they be using? Which DTH should they autodetect?
Device MSR code is 0063-4F50-3031
In Groovy i have one that is ZWave Generic Switch and one that is ZWave Generic Metering Switch… but only one shows Metering as a capabtility.
Do those even support metering? I have one that matches that fingerprint and I didn’t think it did. Maybe the newer ones do, so you might want to check if they’re all the same fingerprint.
Mine runs fine on Z-Wave Switch Generic. I don’t think they have any functionality beyond on/off, so just pick a stock DTH that runs local, makes the device turn on/off, and updates the app if you toggle the device with the physical button.
@philh30 I know it’s been a while. Thanks for your stuff in HA as well. Power metering is good for me as I use these to control Christmas lights. Knowing how much power is going thru one is of interest (and safety)
