I purchased a multi purpose st sensor for the garage door sensor,and wired up my old honeywell wifi thermostat to the garage heater.
2 problems:
#1 I can set up a routine to change the temp set point but how do I change the mode from heat to off and off to heat
#2 I only want this to work if I have the heat on… I don’t want the heat to always kick on when the garage door closes
