here is the driver log and the driver changed happened in 2024-06-13T09:41 UTC+8
2024-06-13T09:41:39.417612109+08:00 TRACE Matter Sensor Received event with handler driver_lifecycle
2024-06-13T09:41:57.042190168+08:00 TRACE Matter Sensor Setup driver matter-sensor with lifecycle handlers:
DeviceLifecycleDispatcher: matter-sensor
default_handlers:
infoChanged:
init:
driverSwitched:
child_dispatchers:
2024-06-13T09:41:57.064310353+08:00 TRACE Matter Sensor Setup driver matter-sensor with Capability handlers:
CapabilityCommandDispatcher: matter-sensor
default_handlers:
refresh:
refresh
child_dispatchers:
2024-06-13T09:41:57.086258581+08:00 INFO Matter Sensor Created dispatcher [SecretDataDispatcher]matter-sensor that had no handlers
2024-06-13T09:41:57.098154297+08:00 TRACE Matter Sensor Setup driver matter-sensor with Secret Data handlers:
SecretDataDispatcher: matter-sensor
default_handlers:
child_dispatchers:
2024-06-13T09:41:57.117767652+08:00 TRACE Matter Sensor Setup driver matter-sensor with Matter handlers:
MatterMessageDispatcher: matter-sensor
default_handlers:
attr:
AttributeReportHandler: cluster: IlluminanceMeasurement, attribute: MeasuredValue
AttributeReportHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
AttributeReportHandler: cluster: PressureMeasurement, attribute: MeasuredValue
AttributeReportHandler: cluster: BooleanState, attribute: StateValue
AttributeReportHandler: cluster: RelativeHumidityMeasurement, attribute: MeasuredValue
AttributeReportHandler: cluster: OccupancySensing, attribute: Occupancy
AttributeReportHandler: cluster: PowerSource, attribute: BatPercentRemaining
event:
cmd_response:
child_dispatchers:
2024-06-13T09:41:57.137453429+08:00 TRACE Matter Sensor Received event with handler driver_lifecycle
2024-06-13T09:41:57.154669234+08:00 INFO Matter Sensor received driver startupState: {"hub_zigbee_id":"XMfB//7itOg=","hub_node_id":null,"hub_ipv4":"172.20.10.7"}
2024-06-13T09:41:57.166193552+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:41:57.183973200+08:00 INFO Matter Sensor device init
2024-06-13T09:41:57.204107502+08:00 WARN Matter Sensor Device does not support cluster 0x002F not adding subscribed attribute
2024-06-13T09:41:57.227526495+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> sending InteractionRequest: <InteractionRequest || type: SUBSCRIBE, info_blocks: [<InteractionInfoBlock || cluster: OccupancySensing, attribute: Occupancy>]>
2024-06-13T09:41:57.241664340+08:00 INFO Matter Sensor device init end
2024-06-13T09:41:57.258926787+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:41:57.281687401+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:41:57.288112937+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: removed
2024-06-13T09:41:57.294426445+08:00 TRACE Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received unhandled lifecycle event: removed
2024-06-13T09:41:57.300889962+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:41:57.307473710+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:41:57.313613347+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: added
2024-06-13T09:41:57.320722957+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:41:57.327137415+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:41:57.332243569+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: driverSwitched
2024-06-13T09:41:57.339055661+08:00 TRACE Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received unhandled lifecycle event: added
2024-06-13T09:41:57.345350970+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:41:57.350190133+08:00 TRACE Matter Sensor Received event with handler matter
2024-06-13T09:41:57.356533460+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received InteractionResponse: <InteractionResponse || type: REPORT_DATA, response_blocks: [<InteractionResponseInfoBlock || status: SUCCESS, <InteractionInfoBlock || endpoint: 0x01, cluster: OccupancySensing, attribute: Occupancy, data: OccupancyBitmap: \x01>>]>
2024-06-13T09:41:57.362846218+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:41:57.370146941+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:41:57.375465864+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:41:57.381635444+08:00 INFO Matter Sensor device init
2024-06-13T09:41:57.387930920+08:00 WARN Matter Sensor Device does not support cluster 0x002F not adding subscribed attribute
2024-06-13T09:41:57.393493345+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> sending InteractionRequest: <InteractionRequest || type: SUBSCRIBE, info_blocks: [<InteractionInfoBlock || cluster: OccupancySensing, attribute: Occupancy>]>
2024-06-13T09:41:57.399905305+08:00 INFO Matter Sensor device init end
2024-06-13T09:41:57.406626151+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:41:57.411692491+08:00 TRACE Matter Sensor Found MatterMessageDispatcher handler in matter-sensor
2024-06-13T09:41:57.416678622+08:00 INFO Matter Sensor Executing AttributeReportHandler: cluster: OccupancySensing, attribute: Occupancy
2024-06-13T09:41:57.421809097+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"active"}}
2024-06-13T09:41:57.428421248+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:41:57.433811676+08:00 TRACE Matter Sensor Received event with handler matter
2024-06-13T09:41:57.440219554+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received InteractionResponse: <InteractionResponse || type: REPORT_DATA, response_blocks: [<InteractionResponseInfoBlock || status: SUCCESS, <InteractionInfoBlock || endpoint: 0x01, cluster: OccupancySensing, attribute: Occupancy, data: OccupancyBitmap: \x01>>]>
2024-06-13T09:41:57.447937068+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:41:57.454142256+08:00 TRACE Matter Sensor Found MatterMessageDispatcher handler in matter-sensor
2024-06-13T09:41:57.460710762+08:00 INFO Matter Sensor Executing AttributeReportHandler: cluster: OccupancySensing, attribute: Occupancy
2024-06-13T09:41:57.469473170+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"active"}}
2024-06-13T09:41:57.550987767+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:41:57.930443861+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:41:57.939980757+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: infoChanged
2024-06-13T09:41:57.946203769+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:41:57.950968260+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:42:21.302061876+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:42:21.428275862+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: removed
2024-06-13T09:42:21.439935279+08:00 TRACE Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received unhandled lifecycle event: removed
2024-06-13T09:42:21.450580579+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:42:21.457249909+08:00 TRACE Matter Sensor Received event with handler driver_lifecycle
2024-06-13T09:42:21.467677693+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:42:42.633204888+08:00 TRACE Matter Sensor Setup driver matter-sensor with lifecycle handlers:
default_handlers:
driverSwitched:
init:
infoChanged:
child_dispatchers:
2024-06-13T09:42:42.663253481+08:00 TRACE Matter Sensor Setup driver matter-sensor with Capability handlers:
default_handlers:
refresh:
refresh
child_dispatchers:
2024-06-13T09:42:42.697776711+08:00 INFO Matter Sensor Created dispatcher [SecretDataDispatcher]matter-sensor that had no handlers
2024-06-13T09:42:42.737952613+08:00 TRACE Matter Sensor Setup driver matter-sensor with Secret Data handlers:
default_handlers:
child_dispatchers:
2024-06-13T09:42:42.768145342+08:00 TRACE Matter Sensor Setup driver matter-sensor with Matter handlers:
default_handlers:
attr:
event:
cmd_response:
child_dispatchers:
2024-06-13T09:42:42.788575539+08:00 TRACE Matter Sensor Received event with handler driver_lifecycle
2024-06-13T09:42:42.815652410+08:00 INFO Matter Sensor received driver startupState: {"hub_zigbee_id":"XMfB//7itOg=","hub_node_id":null,"hub_ipv4":"172.20.10.7"}
2024-06-13T09:42:42.846539750+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:42:42.880407308+08:00 INFO Matter Sensor device init
2024-06-13T09:42:42.885941748+08:00 INFO Matter Sensor entering battery cheking----------------------
2024-06-13T09:42:42.939538270+08:00 INFO Matter Sensor
2024-06-13T09:42:42.953607065+08:00 WARN Matter Sensor Alias: PowerSourceFeature => Feature
2024-06-13T09:42:42.959535433+08:00 INFO Matter Sensor -motion
2024-06-13T09:42:42.971754237+08:00 INFO Matter Sensor remove leading--------------------------
2024-06-13T09:42:42.978255901+08:00 INFO Matter Sensor motion
2024-06-13T09:42:42.990639373+08:00 INFO Matter Sensor updated
2024-06-13T09:42:42.996313951+08:00 WARN Matter Sensor Device does not support cluster 0x002F not adding subscribed attribute
2024-06-13T09:42:43.016112422+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> sending InteractionRequest: <InteractionRequest || type: SUBSCRIBE, info_blocks: [<InteractionInfoBlock || cluster: OccupancySensing, attribute: Occupancy>]>
2024-06-13T09:42:43.030071189+08:00 INFO Matter Sensor device init end
2024-06-13T09:42:43.040305444+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:42:43.050815686+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:42:43.059563060+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: added
2024-06-13T09:42:43.071261292+08:00 TRACE Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received unhandled lifecycle event: added
2024-06-13T09:42:43.077592666+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:42:43.091397885+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:42:43.099002664+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: driverSwitched
2024-06-13T09:42:43.114288767+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:42:43.121459388+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:42:43.129845027+08:00 TRACE Matter Sensor Received event with handler matter
2024-06-13T09:42:43.143379798+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received InteractionResponse: <InteractionResponse || type: REPORT_DATA, response_blocks: [<InteractionResponseInfoBlock || status: SUCCESS, <InteractionInfoBlock || endpoint: 0x01, cluster: OccupancySensing, attribute: Occupancy, data: OccupancyBitmap: \x01>>]>
2024-06-13T09:42:43.159136624+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:42:43.165589229+08:00 TRACE Matter Sensor Found MatterMessageDispatcher handler in matter-sensor
2024-06-13T09:42:43.176162482+08:00 INFO Matter Sensor Executing AttributeReportHandler: cluster: OccupancySensing, attribute: Occupancy
2024-06-13T09:42:43.183815112+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"active"}}
2024-06-13T09:42:43.200936172+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:42:44.167600348+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:42:44.354900776+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: infoChanged
2024-06-13T09:42:44.409505543+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:42:44.506288003+08:00 INFO Matter Sensor info changing--------------------------
2024-06-13T09:42:44.526276171+08:00 WARN Matter Sensor Device does not support cluster 0x0403 not adding subscribed attribute
2024-06-13T09:42:44.532859211+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> sending InteractionRequest: <InteractionRequest || type: SUBSCRIBE, info_blocks: [<InteractionInfoBlock || cluster: OccupancySensing, attribute: Occupancy>]>
2024-06-13T09:42:44.549383736+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:42:44.559857497+08:00 TRACE Matter Sensor Received event with handler matter
2024-06-13T09:42:44.575266080+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received InteractionResponse: <InteractionResponse || type: REPORT_DATA, response_blocks: [<InteractionResponseInfoBlock || status: SUCCESS, <InteractionInfoBlock || endpoint: 0x01, cluster: OccupancySensing, attribute: Occupancy, data: OccupancyBitmap: \x01>>]>
2024-06-13T09:42:44.581334586+08:00 TRACE Matter Sensor Found MatterMessageDispatcher handler in matter-sensor
2024-06-13T09:42:44.590303224+08:00 INFO Matter Sensor Executing AttributeReportHandler: cluster: OccupancySensing, attribute: Occupancy
2024-06-13T09:42:44.601548807+08:00 WARN Matter Sensor Attempted to generate event for 01f1ea25-3d57-4d30-97e6-6d3133d94b47.main but it does not support capability Motion Sensor
2024-06-13T09:42:44.610915288+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:42:44.622404457+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:42:44.632045010+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: infoChanged
2024-06-13T09:42:44.642950471+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:42:44.657462378+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:43:07.911423209+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:43:08.059364201+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: removed
2024-06-13T09:43:08.073365197+08:00 TRACE Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received unhandled lifecycle event: removed
2024-06-13T09:43:08.079103535+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:43:08.088404216+08:00 TRACE Matter Sensor Received event with handler driver_lifecycle
2024-06-13T09:43:08.093522239+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:43:22.681817236+08:00 TRACE Matter Sensor Setup driver matter-sensor with lifecycle handlers:
default_handlers:
driverSwitched:
infoChanged:
init:
child_dispatchers:
2024-06-13T09:43:22.700149024+08:00 TRACE Matter Sensor Setup driver matter-sensor with Capability handlers:
default_handlers:
refresh:
refresh
child_dispatchers:
2024-06-13T09:43:22.725869615+08:00 INFO Matter Sensor Created dispatcher [SecretDataDispatcher]matter-sensor that had no handlers
2024-06-13T09:43:22.741292900+08:00 TRACE Matter Sensor Setup driver matter-sensor with Secret Data handlers:
default_handlers:
child_dispatchers:
2024-06-13T09:43:22.756791980+08:00 TRACE Matter Sensor Setup driver matter-sensor with Matter handlers:
default_handlers:
attr:
event:
cmd_response:
child_dispatchers:
2024-06-13T09:43:22.770873644+08:00 TRACE Matter Sensor Received event with handler driver_lifecycle
2024-06-13T09:43:22.786095321+08:00 INFO Matter Sensor received driver startupState: {"hub_zigbee_id":"XMfB//7itOg=","hub_node_id":null,"hub_ipv4":"172.20.10.7"}
2024-06-13T09:43:22.803233789+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:43:22.815383544+08:00 INFO Matter Sensor device init
2024-06-13T09:43:22.840100138+08:00 INFO Matter Sensor entering battery cheking----------------------
2024-06-13T09:43:22.845844098+08:00 INFO Matter Sensor
2024-06-13T09:43:22.850891032+08:00 WARN Matter Sensor Alias: PowerSourceFeature => Feature
2024-06-13T09:43:22.857202083+08:00 INFO Matter Sensor -motion
2024-06-13T09:43:22.863534082+08:00 INFO Matter Sensor remove leading--------------------------
2024-06-13T09:43:22.868773544+08:00 INFO Matter Sensor motion
2024-06-13T09:43:22.874682214+08:00 INFO Matter Sensor updated
2024-06-13T09:43:22.879832845+08:00 WARN Matter Sensor Device does not support cluster 0x002F not adding subscribed attribute
2024-06-13T09:43:22.908064639+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> sending InteractionRequest: <InteractionRequest || type: SUBSCRIBE, info_blocks: [<InteractionInfoBlock || cluster: OccupancySensing, attribute: Occupancy>]>
2024-06-13T09:43:22.915028031+08:00 INFO Matter Sensor device init end
2024-06-13T09:43:22.920774448+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:43:22.926966558+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:43:22.933565049+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: added
2024-06-13T09:43:22.939377350+08:00 TRACE Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received unhandled lifecycle event: added
2024-06-13T09:43:22.944431363+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:43:22.949955516+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:43:22.957142296+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: driverSwitched
2024-06-13T09:43:22.962837572+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:43:22.969568205+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:43:22.975947431+08:00 TRACE Matter Sensor Received event with handler matter
2024-06-13T09:43:22.980877548+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received InteractionResponse: <InteractionResponse || type: REPORT_DATA, response_blocks: [<InteractionResponseInfoBlock || status: SUCCESS, <InteractionInfoBlock || endpoint: 0x01, cluster: OccupancySensing, attribute: Occupancy, data: OccupancyBitmap: \x01>>]>
2024-06-13T09:43:22.987928812+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:43:22.995551207+08:00 TRACE Matter Sensor Found MatterMessageDispatcher handler in matter-sensor
2024-06-13T09:43:23.001766306+08:00 INFO Matter Sensor Executing AttributeReportHandler: cluster: OccupancySensing, attribute: Occupancy
2024-06-13T09:43:23.009092225+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"active"}}
2024-06-13T09:43:23.015530171+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:43:23.537223402+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:43:23.679989775+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: infoChanged
2024-06-13T09:43:23.766924994+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:43:23.803462383+08:00 INFO Matter Sensor info changing--------------------------
2024-06-13T09:43:23.870315773+08:00 WARN Matter Sensor Device does not support cluster 0x0403 not adding subscribed attribute
2024-06-13T09:43:23.888048027+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> sending InteractionRequest: <InteractionRequest || type: SUBSCRIBE, info_blocks: [<InteractionInfoBlock || cluster: OccupancySensing, attribute: Occupancy>]>
2024-06-13T09:43:23.917900135+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:43:23.925627020+08:00 TRACE Matter Sensor Received event with handler matter
2024-06-13T09:43:23.932107070+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received InteractionResponse: <InteractionResponse || type: REPORT_DATA, response_blocks: [<InteractionResponseInfoBlock || status: SUCCESS, <InteractionInfoBlock || endpoint: 0x01, cluster: OccupancySensing, attribute: Occupancy, data: OccupancyBitmap: \x01>>]>
2024-06-13T09:43:23.939126350+08:00 TRACE Matter Sensor Found MatterMessageDispatcher handler in matter-sensor
2024-06-13T09:43:23.945480089+08:00 INFO Matter Sensor Executing AttributeReportHandler: cluster: OccupancySensing, attribute: Occupancy
2024-06-13T09:43:23.951646545+08:00 WARN Matter Sensor Attempted to generate event for 01f1ea25-3d57-4d30-97e6-6d3133d94b47.main but it does not support capability Motion Sensor
2024-06-13T09:43:23.958445311+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
2024-06-13T09:43:23.964664741+08:00 TRACE Matter Sensor Received event with handler device_lifecycle
2024-06-13T09:43:23.970507569+08:00 INFO Matter Sensor <MatterDevice: 01f1ea25-3d57-4d30-97e6-6d3133d94b47 [92EB06375A58EA0D-9C75E6A7E7B0150A] (LeTianPai Presence Sensor Box)> received lifecycle event: infoChanged
2024-06-13T09:43:23.977232121+08:00 TRACE Matter Sensor Found DeviceLifecycleDispatcher handler in matter-sensor
2024-06-13T09:43:23.983336276+08:00 DEBUG Matter Sensor LeTianPai Presence Sensor Box device thread event handled
