I have a sample st-schema connector going and running, using Node and the st-schema node package, latest version (1.5.2).
I write out callback auth tokens to a file so that if I stop and restart, I can re-fetch them and use them. This was working out OK. I see eventually it needed to refresh the token and thus jumped into the refresh logic of st-schema:
updateState(callbackUrls, callbackAuth, deviceState, refreshedCallback) {
return this[doUpdateState](callbackUrls.stateCallback, callbackAuth.accessToken, deviceState).then(res => {
if (res.status === 401 && refreshedCallback) {
return new RefreshTokenRequest(this.clientId, this.clientSecret).getCallbackToken(
callbackUrls.oauthToken,
callbackAuth.refreshToken
).then(refreshResponse => {
refreshedCallback(refreshResponse.callbackAuthentication);
return this[doUpdateState](callbackUrls.stateCallback, refreshResponse.callbackAuthentication.accessToken, deviceState)
.then(checkFetchStatus)
return checkFetchStatus(res)
I have a refreshedCallback passed in that just logs something so that it proceeds to refresh the token. I know itβs been called. However when it gets down to checkFetchStatus() I get an exception:
Uncaught Error UnhandledPromiseRejection: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason β[object Object]β.
at getErrorWithoutStack (internal/process/promises:321:15)
at generateUnhandledRejectionError (internal/process/promises:341:15)
at processPromiseRejections (internal/process/promises:287:24)
at processTicksAndRejections (internal/process/task_queues:96:32)
promises:321
Does anyone have an idea why this might be happening, or if there is any additional programming required to handle refreshing tokens?
