Fibaro 2 Dimmer (212 not 211)
Right you are, I’m getting exactly the same behaviour as you. Well noticed!
Nothing wrong with your setup then, just a minor incompatibility issue. I’m sure this can be improved either through a custom device script (there is one for the Dimmer 2 which I’ll give another go), or with time as it’s added to the compatible device list.
I’ve given my recommendation on momentary switches before. There are lots of options available, and you can spend between £3 and £70 upward per switch. Here’s what I’ve chosen:
