Feature Request : Change battery alert
It is possible to add some alert in the mobile app that show as push notification about low battery alert of any sensor… so you dont need to check each device manually to see if the battery % is ok…
Check out something like Simple Device Viewer which will let you view all batteries at once.
Or you can use SmartTiles and set up a Battery dashboard showing all batteries.
www.smarttiles.click
Alternatively, you can use one of the rule engines like CoRE or Automation Director
The app does this natively now, but you can’t set at what % it notifies. So if the device dies above this mysterious threshold then you would never know unless you monitor its activity.
I use the following SmartApp to let me know if any of my devices stop reporting in for any reason. As you mention, battery monitoring is not foolproof since the device can die well above the threshold for notification.
