So I’m trying to convert the Ridiculously Automated Garage Door Opener to notify me if everyone is out of the house and someone unlocks or opens a door in the house.
I’m running into a problem that I can’t figure out where the variable “state” is declared. I’ve been assuming it’s some sort of system defined global, but when I do that, I get errors when I try to do a comparison operator against it. So:
if (result == false) {
if (!<strong>state</strong>.openDoorNotificationSent && now() - currentSensor.latestValue.date.time > thresholdMinutes * 60 *1000) {
def msg = "${currentSensor.displayName} has been open for ${thresholdMinutes} minutes"
log.info msg
sendPush msg
if (phone) {
sendSms phone, msg
//state.openDoorNotificationSent = true
else {
//state.openDoorNotificationSent = false
in the case above, in referring to state, I get:
error Property ‘SmartSense Multi’ too ambiguous for this device
Any ideas? I can paste the entire routine in here, but it’s sort of torn apart while I try to get this particular script to work.
