I’m working on a door-knocking app. I have a SmartSense Multi on my front door and it can detect if the door is shut and if there’s a knock. Awesome. However, I’m getting a false positive for every time I shut the door (the contact is closed and its acceleration is active).
What I’d like to do is add a custom property to the multi (without having to tinker with writing a whole new custom device type) to register the last time the door was open. If the door was opened within a set amount of time, it’s probably just you shutting or locking the door. If adding a property to an existing object is not possible, is there a way to use a static variable within a function - or even a global var to store this last timestamp?
Sorry for the noob questions, java / groovy are new to me.
I’d look to handling this in the code of the app rather than in the devise type.
What I would look at doing is subscribing to when the sensor is opened and closed. When it’s opened use change a state variable to false, and then when close run a procedure in a minute to change the state.
What this does is when the door closes, it schedule the ‘closeState’ procedure to run in 60 seconds. This gives a 1 minute for the accelerator time to stop moving.
Then in your procedure where you run the actions when acceleration happens, put in a conditional:
def accelerationCheck {
if (state.doorClosed = true) {
Insert you code to do stuff here
That way you need acceleration AND the variable needs to say closed. And that won’t say closed until the door has been closed for at least a minute.
Ahh - the “state” variable was the secret sauce I was looking for. I can load state.lastOpen = now() when a door is open and check for elapsed time when a knock is felt to see if the door’s been opened recently.
Just a personal preference probably, but I’d base it on when the door is closed. If someone were to leave the door open for a while and the time expired then you’d get a false positive when the door closed.
Fair enough - I’ll give that a go. I did have that set originally but moved it to “open” for a reason I can no longer recall. I was juggling things around a lot trying to sort out a way of storing the timestamp, so I’m sure it’s irrelevant now. Updated on SmartThings - will update github later.
