I’m trying to write my first SmartApp, but I get the following error when trying to run it in the Simulator using virtual device types. The error I get is:
org.springframework.security.access.AccessDeniedException: Access is denied @ line 52
Line 52 is:
subscribe(partnerOnePresence, “presence”, presenceChangeRouter)
Note that I have a log.debug immediately before that line, and for some reason it is not showing up into the log output.
Any suggestions on what is going on?
Code:
- HomeAwayControl2
- Copyright 2015 Taylor Lehman
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0 - Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
definition(
namespace: “taylorlehman”,
author: “Taylor Lehman”,
description: “Automating When I arrive and leave”,
category: “Family”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”,
iconX3Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”,
oauth: true)
The preferences data structure drives the UI the user sees whuile installing the app that
instructs them to select their preferences.
preferences {
section(“Please Select the Presence Sensors to Track”) {
input “partnerOnePresence”, “capability.presenceSensor”, required: true
input “partnerTwoPresence”, “capability.presenceSensor”, required: true
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug “Updated with settings: ${settings}”
unsubscribe()
initialize()
def initialize() {
log.debug "EVENTOCCURRED"
subscribe(partnerTwoPresence, “presence”, presenceChangeRouter)
This method gets called by the smartthings event handling system when the presence
state of one of the partner’s presence state has changed.
def presenceChangeRouter(presenceEvent){
if(presenceEvent.value == “present”){
/The sensor became present - if one person is present,
we want the home to be in the present state/
setHome()
} else {
/The presence sensor is not present - we only want to put the home
into not-present state if the other partner is also away/
if(!isOtherPartnerPresent(presenceEvent.device)){
setAway()
def isOtherPartnerPresent(device){
log.debug “Current device is ${device.name}”
def partnerSensor = partnerOnePresence
if(device.name == "partnerOnePresence"){
partnerSensor = partnerTwoPresence
log.debug "Partner devicer is ${partnerSensor.name}"
if(partnerSensor.presenceState == "present"){
log.debug "Partner is Present"
return true
} else {
log.debug "Partner is Not Present"
return false
def setHome(){
log.debug “Someone’s home! Let’s wake the house back up”
//TODO: Tell nest we are home (which should turn off the camera and turn up the heat)
def setAway(){
log.debug “Everyone is gone! Let’s shut the house down”
//TODO: Put the garage door down if it is up
//TODO: Tell nest we are away (which should turn on the camera and turn down the heat)
