Error code 33-504
Hi @jeongjoonshin
Could you confirm if the serial number is correct, please? I can’t seem to find that serial number
Hi @quaningeneva
I sent you a DM
Hello. Same problem here (factoy reset and no success)
Hi @Sergio_A
Could you share with us the serial number, please?
@Itati DM with sn send
I have same issue serial 4021215805
I had a very similar issue and opened a ticket with Aeotec who responded with this
“Last year there was a change of security certificate, the old certificate expired at the beginning of March 2025. For devices that have not been activated by then and have a production date before March 2024 or have not received an update since March 2024, this means that activation is no longer possible. However, this only applies to devices that meet the following criteria: Device has purple packaging (EU Only) and Date of manufacture is before March 2024”
Mine was a UK version and they replaced it without any question. The new hub arrived and worked straight away.
Hi @Itati.
I have same issue serial 3011255966
Hi @Daniel_al
I sent you a DM
Please find my serial number, same issure here
5031307482
Hello, I have the same issue error 33-504 the serial number is 3011335737. Thank you
Hi @Jaemyung_Lee
I sent you a DM
Hi @Michelle_George
I sent you a DM
@Itati
I am having the same issue. Error 33-504. Serial: 3011332457
Any assistance you can provide would be appreciated.
@Itati
If I tell the hub to connect via wifi, I can see it attach to my network, and I get to a screen that says “Your Hub is being added to SmartThings”, after a while I get the message “Couldnt Register Hub” and error code: 33-505
@Itati
I tried over and over and over with wifi and it eventually registered.
However, now the device has a flashing orange light.
I can see it is on my network. It has an IP addr. No DNS issues. No blocked ports.
Any ideas?
Hi @sublimese
I see that you have successfully connected your hub.
For this specific case, I recommend that you contact Customer Support, as they can directly escalate the issue to the appropriate team and provide you with the best possible assistance.
From the ST app
  1. Open the SmartThings app
  2. Go to the menu tab at the bottom-right corner.
  3. On this page, select the option “contact us” and then go to “Error reports”
  4. Select the topic related to your issue and follow the steps to submit your support request
@Itati
I will do as you requested.
You need to update the instructions for the SmartThings Web page portion of your instructions. The link is to smartthings.com, but it redirects to Smart home with Samsung SmartThings | Samsung US. The samsung.com site doesnt have “email” as an option. When I click through the various options, I eventually get redirected to samsung support, who eventually tell me to go to: https://support.smartthings.com/hc/en-us (which also doesnt have email). The https://support.smartthings.com/hc/en-us page, when you click on “contact us”, simply takes you back to the samsung website, thus starting the entire process over again.
Thank you for your response! We will review and update it.
@Itati Hello. I have the same problem. Error 33-504. S/N: 4011025290 help me pls.
