REPLICA 1.3.09 RELEASE
New release Replica 1.3.09 supporting ‘warning’ for late OAuth refresh but token but is still valid. A token is valid for 24 hours, but is attempted refresh every 3 hours. If the refresh is unsuccessful the ‘warning’ will be shown in the corresponding the ‘Replica Location Knob’ device authorized in that location.
‘Replica Location Knob’ was updated to support SmartThings Weather, Forecast, airQuality and Alert notifications.
Install instructions here with HPM updated to match.
Replica 1.3.09:
- Support for ‘warning’ for late OAuth tokens.
- UI bug fixes.
OAuth 1.3.09:
Replica Location Knob 1.3.2:
- Updated to support SmartThings Weather, Forecast, airQuality and Alert notifications. See below for detail list of possible attributes.
SAMSUNG DRIVERS+ BY DAVE
Please see here for new @djgutheinz device handlers and information. These are available in HPM for installation and updates.
Location Knob attributes populated by SmartThings Weather:
webCoRE piston example to watch Alert attribute which receives the raw alert message in the data construct of the alert event:
REPLICA 1.3.10 RELEASE
New release Replica 1.3.10 supporting the SmartThings Virtual Lock and all ST Virtual devices will be updated with default values upon creation. Updates to ‘Replica Location Knob’ with more AQI information, Level fix in ‘Replica Fan Control’. Minor static updates to several other drivers.
Replica 1.3.10:
- SmartThings Virtual Lock support
- SmartThings Virtual devices updated to default values on creation
Replica Location Knob 1.3.3:
REPLICA 1.3.11 RELEASE
New release Replica 1.3.11 supporting the SmartThings Virtual Devices API allowing user to build their own ST Virtual devices (see examples below). Expanded UI support editing rules using buttons to enable/disable logging & periodic refresh.
Replica 1.3.11:
- Support for building your own Virtual Devices
- Mute logs/Disable periodic refresh buttons on rules.
- Updated to support schema.oneOf.type drivers (support for Samsung Microwave)
Replica Switch 1.3.1:
Replica Location Knob 1.3.4:
CUSTOM ST UI EXAMPLES:
Replica Configuration (Example 1):
SmartThings Virtual Device custom:
Replica Configuration (Example 2):
REPLICA 1.3.12 RELEASE
New release Replica 1.3.12 supporting GitHub issue ticket support for new device requests.
Replica 1.3.12:
- Bug fix for dup event trigger to different command event (virtual only)
- GitHub issue ticket support for new device requests
Replica Samsung OCF Microwave Hood 1.3.1:
Replica Multipurpose Sensor 1.3.2:
- Supports capability “IlluminanceMeasurement”
Replica Location Knob 1.3.5:
REPLICA 1.4.00 RELEASE
New release of Replica 1.4.00 with initial support for Home Assistant device replication. Releasing the base application early to ensure no SmartThings issues are reported before releasing the HA supporting package.
Replica 1.4.00:
- Startup fixes to ensure safe start from new code and hub reboots
- Several changes to base code to allow for Home Assistant to be enabled within same application.
Replica 1.4.00:
- Bug fix for safe(r) authorization and rewrite to support Replica changes for HA
Replica Temp-Humidity-Pressure Sensor 1.3.5 @bthrock:
- Supports attribute “pressure”
- Supports capability “Relative Humidity Measurement”
- Supports capability “Temperature Measurement”
