AdamV
(Adam V)
18
Hi Guys - I’ve just installed 6 of these in my apartment so I created a dedicated device handler for it.
advantages over the generic handler:
- Handles the actual heat modes used by this device
- Handles the actual Temperature Sensor Modes used by this device
- Uses new multi attribute tiles so looks better
- Allows you to set configuration parameters that are bespoke to this device in the settings
- Allows you to change which temperature sensor it uses
- Allows you to set the eco mode temperature
