My Shelly PM Mini Gen 3 devices stopped updating in ST tonight. Two things happened today. I believe you updated the driver and I updated the firmware on the units. I don’t know which update caused the problem.
I have had 2 PMs running for about 6 months and they worked great in ST with your driver until tonight. They are still working normally in both the Shelly app and in Home Assistant. I installed a 3rd one tonight. It was discovered with out any problems but all the values are “0” in ST. They have been that way for several hours. After the install and updates I discovered you also updated the driver.
The firmware update fixed a problem I was having HA. The problem was that they stopped functioning as Bluetooth proxies.
I have rebooted all 3 units via the Shelly app, power cycled 2 of the 3 units, rebooted my ST hub, clear the cache in the ST app, and force stopped the ST app. None of these things helped.
I have a 4th unit that I could install tomorrow, run logs during the install, and DM the logs to you.
EDIT: The Shelly PM Mini Gen 3 do not have Matter and don’t work with the official c2c integration.
