Edge Shelly drivers for Gen1 and Gen2 Devices
Thank you for your reply, I will try to connect and let you know
I connected Shelly 1 Gen4 using matter and it works just fine with no issues.
thank you for your care
Is there any way a Shelly pro dimmer 2 could be added to the gen2/3 driver
Many thanks
Just to confirm - you can’t use matter over wifi ?
I can take a look at adding Gen2 support if that’s what you need
Hi thanks for the very prompt response
I don’t think the Shelly Pro Dimmer 2PM is matter enabled.
I can add the device via the cloud integration but it doesn’t support the button inputs which I need for routines
I have successfully connected a Shelly Pro 4PM using your excellent Shelly Gen 2/3 device driver, but can’t find the Pro dimmers. When I look at the device list it does not include the dimmers.
BTW I have 5 x pro dimmers but I guess the add device via search nearby will detect them all
Thanks for your help
See this post
Can you get the device info for me for one of the devices? I just need an example for the device type.
Hi, here is the info returned:
{“name”:null,“id”:“shellyprodm2pm-2cbcbb9f5b74”,“mac”:“2CBCBB9F5B74”,“slot”:1,“model”:“SPDM-002PE01EU”,“gen”:2,“fw_id”:“20250730-063231/1.7.0-gbe7545d”,“ver”:“1.7.0”,“app”:“ProDimmerx”,“auth_en”:false,“auth_domain”:null}
Many thanks
Thank-you. I’m starting to look at this now.
Hi TAustin,
I have a Shelly 1 Gen 3 with a Temperature Add-on. Would it be possible to integrate the Add-on with SmartThings so that the temperature is visible? Using your drivers, I can discover the Shelly 1, but not the temperature sensor.
Is it possible for you to use MQTT connection?
Shelly Sensor Add-On | Shelly Technical Documentation
Hi. No.
A segunda, 6/10/2025, 16:20, TapioX via SmartThings Community <notifications@smartthings.discoursemail.com> escreveu:
I will take a look at it. I’m working on adding another device to the driver now, so I may be able to roll this in to the update if you are willing to do the testing.
Actually for me I have no issue with shelly gen1 driver as I have many devices work without issue but my issue is with shelly gen 2 driver as i completely remove gen 2 driver due to that the response of the devices became very very slow and i need to restart the hub 3 to 4 times a day (I have more that 45 shelly gen 2 devices) after i removed gen 2 driver every think returned to work fluently without any problem..Actually for local actions i am using you web request driver.
With that many devices, could it be possible you’ve hit a device or driver limit on your hub?
I’m happy to diagnose things with you on the Gen2 driver if you’d like. You will need the SmartThings CLI to run driver logs.
Hi Taustin, how are you?
Would it be possible to set Shelly products as solar and home energy types in the driver? I know these types already exist in SmartThings, but via Matter. I don’t know if it would be possible via the driver.
Hello.
Just waiting for a Shelly 1 Gen4 device to plug it to my Boiler’s thermostat connector.
Since the Shelly 1 Gen4 has Zigbee and Matter over Wifi and I have the V2 hub, I think my best option is to use the Zigbee connection.
Am I thinking right?
And since I’ll use the Zigbee connection, the device will not be added to the Shelly cloud, right?
Tell me specifically what devices you need and I’ll look into it.
Shelly Gen2/3 Driver Update Notice
Name: Shelly Gen2/3 Device Driver V1.7
Version: 2024-04-05T17:29:29.455930569
Changes: Added support for:
  • Shelly Pro Dimmer 2PM
  • Shelly 1 Gen 3 with Temperature Add-on
The driver is still on my test channel and anyone subscribed will get the updated automatically.
Thank-you to Clive and Bruno for testing.
An interesting new device from Shelly (only available in Europe ???)
The Pill by Shelly
Regular price10,35 €
Incl. VAT Shipping calculated at checkout.
In stock
Compact USB-C powered Wi-Fi and Bluetooth device that connects to various sensors and low-voltage peripherals for monitoring and control of temperature, humidity, voltage, and digital I/O.
Size (HxWxD): 26 x 19.95 x 8.5 mm / 1.02 x 0.79 x 0.34 inch
Shelly Gen3 functionality
The Pill by Shelly - Shelly Europe
Edit:
Edit:
Is it at all possible to get the Shelly GAS (CNG) wifi sensor to integrate with SM via this edge driver?
