Edge Shelly drivers for Gen1 and Gen2 Devices
@TAustin , I installed the driver for my Shelly PLus Uni, and using the v. 1.5 driver. (The 1.9 version will not go online) The driver installed normally, and went online after inputting the IP address. The on/off buttons on the interface appear to work when pressed, but have no effect on the Shelly state, and none of the input functions seem to be receiving any data either. Do you have any suggestions on getting this driver to work?
Thanks for your excellent efforts on this project.
Hi there. You’ll definitely need the Gen2 driver (Shelly Gen2 Device Driver V1.5), however that I hadn’t included support for the Plus Uni yet. I will add it in my next update, which I hope to have out shortly.
Can you please do me a favor and in a browser address bar type in the IP address of your Plus Uni device followed by ‘/shelly’? For example:
192.168.1.150/shelly
I need to see the shelly id value they are using for the Plus Uni device.
FOLLOW-UP:
After looking at the specs for the Uni device, I see it has something new: a counter input field. However the API docs don’t show how the value is actually sent. So can you do me another favor and try this from a browser address bar (substituting your own device’s IP address):
http://192.168.1.150/rpc/Input.GetStatus?id=0
http://192.168.1.150/rpc/Input.GetStatus?id=1
http://192.168.1.150/rpc/Input.GetStatus?id=2
Let me know the results. Thanks.
Thanks for responding. The results you asked for are as follows:{“name”:null,“id”:“shellyplusuni-d48afc79f8d0”,“mac”:“D48AFC79F8D0”,“slot”:0,“model”:“SNSN-0043X”,“gen”:2,“fw_id”:“20240223-142029/1.2.2-g7c39781”,“ver”:“1.2.2”,“app”:“PlusUni”,“auth_en”:false,“auth_domain”:null}
{“id”:0,“state”:false}
{“id”:1,“state”:false}
{“id”:2,“counts”:{“total”:0,“by_minute”:[0,0,0],“minute_ts”:1712332320},“freq”:0.00}
– DRIVER UPDATE NOTICE –
Driver Name: Shelly Gen2/3 Device Driver V1.6
If you already had the Shelly Gen2 Device Driver V1.5 installed, then it will automatically get upgraded to this new version.
The Shelly Gen2 driver has been updated to be able to support Gen3 devices as well. I’ve started by adding support for the Gen3 PM Mini (@William_Kaper), but can add additional devices as the community requests.
Additionally, Gen2 Shelly Plus Uni support has been added (@garhun).
Also for awareness: A change was made to the SmartThings platform & mobile apps that has broken the ability to display tables of information such as what is used in the wifi and device components of the Gen2/3 devices. So unfortunately, with the latest mobile app, you’ll only see HTML gibberish in those device fields right now. I’m hoping that SmartThings will provide some kind of alternative for displaying multi-line text, but in the meantime you’ll have to ignore those fields. If it looks like a solution from SmartThings is not forthcoming, I may have to remove or modify those fields.
Hi @TAustin , Gen3 appears to be working. Im going to test with some automations, but on the surface everything looks great!
Thank you for adding this!
-Bill
Edit - I got one of the i4 working by uninstalling the driver and then reinstalling, rebooting the hub and adding the device. Still can’t get the second one connected.
Hi, I’m using the Gen 1 and Gen 2 Edge drivers for a number of devices without any issues. I recently installed two i4 devices and added them to the Shelly app no problem, I can add them via auto discovery with the Gen 2 driver, however they don’t link with the device. Tried resetting and re-discovering them a couple of time but same result. Any ideas??? Thanks.
@TAustin
On behalf of the whole community, I’d like to thank you for all your work! It’s incredible what you can and do, especially as you rely on the community for testing and your fixes are based on this!
I’ve been one of your Shelly Gen1 drivers users for a long time. Back then there was the device creator to add a device and allocate the IP address. All working good there.
I recently bought three Shelly 1 Mini Gen3 for some other lights and despite your new Gen2 Gen3 driver installed, auto discovery can’t seem to find it.
I’ve read several posts above and not sure what am I missing or doing wrong, unless your driver doesn’t include the JSON for these new relays? If so, please find the below and hope it helps!
{“name”:“OutsideGarden”,“id”:“shelly1minig3-5432045f6680”,“mac”:“5432045F6680”,“slot”:1,“model”:“S3SW-001X8EU”,“gen”:3,“fw_id”:“20231121-110944/1.1.99-minig3prod1-ga898543”,“ver”:“1.1.99-minig3prod1”,“app”:“Mini1G3”,“auth_en”:false,“auth_domain”:null}
Thank you in advance!
For what its worth, I was using a Smartthings Wifi hub when I had these issues. I ended up updating to a V3 Aeotec hub and this has resolved all the issues I was seeing.
Love the driver. Thanks!
Hey Keith, thanks for the answer. I’ve been using the ethernet V3 hub since the beginning, so perhaps a red herring this time?
I wonder what’s @TAustin opinion if perhaps the mini gen 3 are too new for this driver?
Hi,
I added the 1.6 driver to use with shelly plus 2pm.
I can see the modules, open/close the window shutter but if I open it partially by pressing the open button and stopping it, I can’t see the open percentage.
Can you help me with this please?
@TAustin
@TAustin
Also if I open or close it partially by sliding the % bar, it reaches the position and stops but I still see closing or opening in the status instead of partially opened.
Hi @TAustin
Does your driver support Shelly Pro 3EM?
Hi,
Does the driver support Shelly Pro3EM? there is info about 3em in the main description but it’s not the same.
im try to add a shelly pro3em with their cloud integration and didnt get lucky, i submited a ticket to shelly and this was their response:
"We regret to inform you that the Shelly Pro 3EM is currently not supported in the SmartThings integration. This is due to the device not containing a relay, which prevents the SmartThings application from detecting or including it.
Please be advised that this limitation originates from Samsung’s side. If you have any further questions or concerns, please don’t hesitate to reach out. We appreciate your understanding in this matter."
is there a way to bypass this in any way?
@TAustin any chance you know?
thanks in advance.
I have just started using this driver for the Shelly 3EM and it works quite, however I was wondering if you could add a couple of features as below, if at all possible.
  1. It doesnt appear to show negative number for when you are feeding power back into the grid. It just shows ‘Out of Range’ not sure if this is a driver issue or Smartthings issue.
  2. I am only using 2 of the PM’s so it would be great if you could remove the 3rd unused meter so it doesnt display in Smartthings.
  3. It would be good if you could change the name of the meters rather than them just being Meter 1, Meter 2 and Meter 3.
  4. I would prefer if the refresh, reset and signal strengths were at the bottom of the page with the meter details at the top, but thats just me.
Also is it possible to make the 3EM work with the SmartThings Energy App?
Hi Austin, I have shelly 1pm mini Gen3 and I installed latest driver 2/3 v1.6 but still can not discover any shelly Gen3 devices…please advise
Hello @Mariano_Colmenarejo and others.
I have issue with devices appearing random as offline in smarrthings app. Devices are all sort gen 1. (1, 1pm, 2.5pm, dimmer2, rgbw2).
Triggering device in official Shelly android app ON/OFF gets specific device online in Smartthings but within a few hours device is again offline.
I have tried to delete all devices, delete driver, reinstall driver, readd devices and this does not solve this issue.
Devices use fixed IP addresses.
Anyone can help? I’d like edge instead of official C2C integration…
Dusan
@dusanhauko
Sorry, I don’t have any active Gen1 Devices. But I do have a bunch of Shelly Gen 2 Devices using these Edge Drivers and all have been functioning well in both the Native Shelly App, as well as within SmartThings.
Some thoughts & questions:
  1. What Shelly Firmware Version(s) are you running? According to this, Gen1 latest is v1.14.0 from 09.08.2023. There have been significant updates in the Gen 2 Devices which seem to have helped.
  2. More importantly, I had experienced a similar behavior. Found that the Wi-Fi Access Point they were connected to was competing heavily with a nearby/neighboring 2.4GHz AP! That interference caused the Shelly Devices to go offline/online randomly. I performed a Wireless Survey near my AP, found an open channel with little/no competition, then switched MY AP to that open channel and changed it to a Fixed Channel. Also be aware in this endeavor that if you’re using 40MHz 2.4GHz AP, your AP is using “two” Channels: One being the Control Channel, the other being located in either the next Upper or Lower Channel Number (Upper/Lower position can sometimes be controlled in your AP depending upon make/model). So an interfering/competing Channel can be located in that Upper/Lower position as well. IF you don’t need 40MHz speeds on your AP, then change it to 20MHz Only as the Shelly Devices ONLY connect at 20MHz and don’t benefit from 40MHz.
Good luck and report back!
Hello, thanks for info but… :slightly_smiling_face:
Shelly devices are allways online, accessible 24hrs via Shelly app or web interface. They only appear randomly offline, but when i toogle random online device in Shelly app it instantly shows online in Smartthings with actual state.
I also configured cloud-smartthings integration and in this case devices are OK. But as i said, i’d like it with Edge driver.
All mine Shelly GEN1 devices have the latest FW, in my house.
I’m living in a non crowded place, all my house is covered only with one wifi system (Mikrotik bgn router + 3x AP, all with the same settings.
As mentioned, all my wifi devices have static IP.
So, weird :confused:
