Edge Shelly drivers for Gen1 and Gen2 Devices
OK , let me know if you need any help. Basically you just need this command:
smartthings edge:drivers:logcat
Please direct message me the log rather than post here, and be sure you surround the log text with three back-tick characters (```) to help in formatting.
I will let CLI run until the bug arises. It will be a long log list.
@TAustin
I have 10 Shelly Devices (Plus1 Switches and Plus Plugs) that were originally discovered with a Static IP.
They were working fine in SmartThings (Shelly Gen2 Device Driver v1.5).
I’ve since changed the IP Address for each to a new Static IP and they work fine in the Shelly App.
However, it appears that SmartThings Device Card has held onto the Original IP. Is there any way to force the Switches & Plugs in SmartThings to their new Static IP’s ? CLI? MySmartThings Advanced? ???
Turns out to be pretty simple…
  1. Change the IP Address inside of the Shelly App or Shelly WebGUI
  2. In SmartThings, click + , then Add Device, then Scan Nearby.
  3. Give a minute or two to update the IP Addresses.
  4. Then check the IP in the SmartThings Device Card
Thanks @TAustin for having this sort of thing baked in!!!
Hi @TAustin, I was using your drivers with great satisfaction then I had several problems that led me to have to replace the hub. Since I replaced it nothing works anymore, as soon as I create the Shelly 2.5 device and enter the IP address I see it as offline. Please tell me what the problem could be? Thank you
Hi T Ausitn. I just installed your Shelly test ED’s and was successful getting my Shelly 4i working in ST. A bit funky but I can now write routines/actions. I noticed there is a 1.8e version dated after the 1.5 version. Should I stick with the 1.5 or update my device on ST to use the 1.8e?
Thanks for the effort on this, got me past my issue of Shelly cloud not sync to ST app.
I’m using the gen2 drivers for a Shelly Plus 1 to control my garage door opener. How do I get the open or closed status to show in SmartThings? The status is working using the Shelly app.
I also asked about this earlier: Edge Shelly drivers for Gen1 and Gen2 Devices - #797 by hokkanen
But I’m not sure if there is a direct way using shelly edge drivers. One option that is to use MQTT virtual shade device which receives status updates directly from shelly (have not tried this, but shellys should support sending MQTT messages) or through intermediary (own script, or Home Assistant which I use). You need to setup an MQTT broker running somewhere on your LAN though.
However, MQTT virtual device allows having the open/close status and the operate button nicely in the same device card. See my post in other thread: Integration Solutions using MQTT - #563 by hokkanen
Hope this helps. Cheers.
Thanks for the amazing work may you please enable the shelly duo on the gen 1 driver
Hi can you look in to enabling the shelly duo in the gen1 drivers when you have a chance
Yes, I’ll get to it!
Hi there. Did you Shelly device get discovered and created in SmartThings?
Hi sorry you are having problems with your hub. One thing I’d recommend is configuring your router to use a fixed IP address for your hub, and make sure it is on the same subnet as your other Shelly devices.
Let me know if you still are having problems.
@mventman -
There are two different Shelly drivers - one is for Gen 1 devices and is currently named “Shelly Device Driver V1.8e”, and the other is for Shelly Gen 2 devices and currently named “Shelly Gen2 Device Driver V1.5”.
** Shelly GEN 2 Driver Update Notice **
Driver Name: Shelly Gen2 Device Driver V1.5
Driver Version: 2024-01-06T22:10:35.909032438
I have pushed out a minor update to this driver to fix an issue with authentication if authentication is enabled on the Shelly device.
Thanks to @Tamas_Hegedus for reporting this and providing logs!
** Shelly GEN 1 Driver Update Notice **
Driver Name: Shelly Device Driver V1.9
Driver Version: 2024-01-11T01:58:40.857115046
This version adds support for the Shelly Duo. Thanks to @wquraini for testing.
The driver will be automatically updated on your hub.
First of all, thank you @TAustin for developing Edge driver for Shelly devices :smiling_face_with_three_hearts:. It’s indeed better and has more features / information than the built-in driver.
I’m currently exploring shelly devices before making my mind on which devices I’ll be using with both SmartThings and Homey for my entire renovation projects. I recently acquired a Shelly Plug S v2 and used your Edge Driver for 2nd Gen devices.
I searched for the info but without success :frowning_face:. Do you know if I’m supposed to see the Shelly Plug S v2 under “ENERGY” (part of SmartThings “LIFE”) so that this plug energy consumption counts against my total energy consumption?
The 4 devices correctly reporting the energy usage are all from TP-Link and I was hoping to get the same with Shelly.
Thank you in advance,
Didier
@Didier_SmartHome
The Energy features within the SmartThings mobile app only work with Samsung appliances and other selected partners. The last I’ve looked at it, it does not recognize community-created device types. I’ll confirm that again.
The Eve Energy Matter smart plug also shows up in the Energy panel because of a collaboration between ST and Eve.
Thank you for your prompt answer.
:frowning: I hope it has changed
