Hi TAustin,
Thanks a lot for your great work! I’m using your Edgebridge+LanTrigger, and now looking into these Shelly edge drivers. I would like to use the Shelly Gen 2 relays as garage good openers, and modify the driver so that it shows the “input state” (Open/Closed) state instead of the “switch state” (On/Off) on the device card in the ST app. I could do this modification just for myself as using the Smartthings CLI did not look too difficult. However, if I understand correctly, it is not possible without having the Edge Driver source code. Is this right?
If that indeed is the case, is the source available somewhere, or could you share it or invite me to that repo in github? My github username is same as here.
