[EDGE] Moes Smart IR Remote Control
Thanks for your great Software.
I’m writing to kindly ask if you could add support for the the following fingerprint.
TS1201
_TZ3290_nba3knpsarkawgnt
(Powered by USB)
Thank you.
Hi shlee1997,
I’ve added the fingerprint. I hope it works on your device.
Thank you,
Javi.
me too.. plz
I failed.
The keypad learned does not work
hay can you please share the github for your driver ?
Hi otivax,
I got new MOES star ring switch & scene controller (3 switches + 3 buttons).
But adding this device, smartthings hub always identify as 6 switches.
Would you please help add this kind of edge driver?
Thanks in advance!
Following is Z2M simpleDescRsp + endpoint info
{“id”:9,“type”:“Router”,“ieeeAddr”:“0xa4c1388b512ee3b2”,“nwkAddr”:47922,“manufId”:4417,“manufName”:“_TZ3002_vaq2bfcu”,“powerSource”:“Mains (single phase)”,“modelId”:“TS0726”,“epList”:[1,2,3,4,5,6,242],“endpoints”:{“1”:{“profId”:260,“epId”:1,“devId”:4,“inClusterList”:[3,4,5,6,57344,57345,0],“outClusterList”:[25,10],“clusters”:{“genBasic”:{“attributes”:{“65503”:“��g0\u0013��g0\u0012”,“65506”:54,“65508”:0,“65534”:0,“stackVersion”:0,“dateCode”:“”,“manufacturerName”:“_TZ3002_vaq2bfcu”,“zclVersion”:3,“appVersion”:81,“modelId”:“TS0726”,“powerSource”:1}},“genOnOff”:{“attributes”:{“onOff”:0,“onTime”:0,“offWaitTime”:0,“tuyaBacklightMode”:2,“moesStartUpOnOff”:0,“tuyaBacklightSwitch”:1}},“manuSpecificTuya3”:{“attributes”:{“powerOnBehavior”:2,“switchMode”:0}}},“binds”:,“configuredReportings”:,“meta”:{}},“2”:{“profId”:260,“epId”:2,“devId”:4,“inClusterList”:[4,5,6,57345],“outClusterList”:,“clusters”:{“genOnOff”:{“attributes”:{“onOff”:0,“onTime”:0,“offWaitTime”:0}},“manuSpecificTuya3”:{“attributes”:{“powerOnBehavior”:2,“switchMode”:0}}},“binds”:,“configuredReportings”:,“meta”:{}},“3”:{“profId”:260,“epId”:3,“devId”:4,“inClusterList”:[4,5,6,57345],“outClusterList”:,“clusters”:{“genOnOff”:{“attributes”:{“onOff”:0,“onTime”:0,“offWaitTime”:0}},“manuSpecificTuya3”:{“attributes”:{“powerOnBehavior”:2,“switchMode”:0}}},“binds”:,“configuredReportings”:,“meta”:{}},“4”:{“profId”:260,“epId”:4,“devId”:4,“inClusterList”:[4,5,6,57345],“outClusterList”:,“clusters”:{“genOnOff”:{“attributes”:{“onOff”:0,“onTime”:0,“offWaitTime”:0}},“manuSpecificTuya3”:{“attributes”:{“powerOnBehavior”:0,“switchMode”:1}}},“binds”:,“configuredReportings”:,“meta”:{}},“5”:{“profId”:260,“epId”:5,“devId”:4,“inClusterList”:[4,5,6,57345],“outClusterList”:,“clusters”:{“genOnOff”:{“attributes”:{“onOff”:0,“onTime”:0,“offWaitTime”:0}},“manuSpecificTuya3”:{“attributes”:{“powerOnBehavior”:0,“switchMode”:1}}},“binds”:,“configuredReportings”:,“meta”:{}},“6”:{“profId”:260,“epId”:6,“devId”:4,“inClusterList”:[4,5,6,57345],“outClusterList”:,“clusters”:{“genOnOff”:{“attributes”:{“onOff”:0,“onTime”:0,“offWaitTime”:0}}},“binds”:,“configuredReportings”:,“meta”:{}},“242”:{“profId”:41440,“epId”:242,“devId”:97,“inClusterList”:,“outClusterList”:[33],“clusters”:{},“binds”:,“configuredReportings”:,“meta”:{}}},“appVersion”:81,“stackVersion”:0,“hwVersion”:1,“dateCode”:“”,“zclVersion”:3,“interviewCompleted”:true,“interviewState”:“SUCCESSFUL”,“meta”:{“configured”:332242049},“lastSeen”:1758757985461}
Many thanks,
Johnny
Not sure if @otivax can help, since this is not a remote control. 6 switches are OK, since only 3 are actually connected to light the other 3 only generates scenes while pressed.
This is a link for the product in MOES web:
This is a convenient presentation of the End Points of the device
Hi,
dotan_shai you are right, I can’t help johnshao. That device is different and I don’t have one.
Thank you,
Javi.
Hi otivax.
It is possible to include the MQTT port field in configurations for situations where you do not use the default port 1883 ?
Hi Javier
I have bought these to control my led candles.
Zigbee IR Smart WIFI Remote Controller Remote Infrared Tuya Smart Home Control Universal for TV DVD AC
TS1201
_TZ3290_u9xac5rv
I’ve enrolled, and your driver is selected automatically when I add the controller to my hub.
But when I set it to ‘learning’ it doesn’t activate learning mode on the device.
Sometimes it even get “stuck" in learning mode, and only solution is to remove and re-add.
The devise should begin to flash to indicate to begin to give input from the physical remote.
It’s like it’s not really connected at all. I have removed and reconnected a bunch of times. I have two, and it’s the same deal with both.
The remote is a typical multi purpose led candle remote.
Hi Simone,
I added that fingerprint in October 2024, and Warpshock confirmed the driver was working for that device.
You can install Smartthings CLI and get the debug information from the driver. Maybe something is wrong with your devices or the driver isn’t fully compatible.
Thanks,
Javi.
Unfortunately, that’s beyond my abilities.
But as a last‑ditch effort, I restarted my hub again and swapped the controller batteries from 1.2 V to 1.5 V.
And then it worked!
Whether that was just luck, I can’t say.
@otivax Thank you for the edge driver.
Could you add support for the following?
Manufacturer: _TZ3290_yyax9ajf
Model : TS1201
This device uses batteries (1.5V AAA × 2).
Hi @otivax! First of all, thank you for this amazing driver! I have a Zemismart IR blaster that I’d love to use with SmartThings and your driver looks like the perfect fit.
Could you please add support for my device?
  • Model: TS1201
  • Manufacturer: _TZ3290_8xzb2ghn
  • Power: USB powered
I want to use it to control my Panasonic window-type aircon. I still have the physical remote so I can use the learning mode to capture the exact IR codes.
Thank you so much!
Hi virnmer, jryn07,
I added both fingerprints. Please, confirm if the driver works for your devices.
Thanks,
Javi.
Hi!
Is it possible to get this added?
Ir remote controller, battery
Model: TS1201
Manufacturer: _TZ3290_lidgqyzu
I want to use for on/off on LED candles.
Hi. Otivax
I am one of user of IR remote controler.
I found you make the edge drive for this. Unfontunately, My Manufacturer Code is not included in your finger prints.
If you can, Could you please add it in your drive??
the Manufacturer Code : _TZ3290_nba3knpsarkawgnt
I look forward to your favorable response.
Hi @otivax Could you please add my device fingerprint to your Smart IR Remote driver? It’s a Tuya IR Blaster with Temp and Humidity sensors.
Manufacturer: _TZE200_33rdmvgw
Model: ZG-IR01
Thank you!
