Sorry, I don’t know how smartthings devices are exported to Google home.
I figure it is a smartthigs or Google problem, but I don’t know how to solve it.
Changing the profile category is equivalent to creating another new profile, but in smartthings I don’t think there is a single category for humidity sensor
Temperature and humidity devices (z-wave, zigbee, c2c) connected to SmartThings do not display humidity in Google Home for some reason.
Temperature and Humidity devices connected to SwitchBot and Tuya/SmartLife do display humidity in Google Home but only as a small secondary number on the detail page.
Thanks Paul. It looks like that’s indeed the case here. I tried with a virtual weather station device and it comes up with only the temperature in Google Home though Smartthings is able to display a lot more.
Found out Google Home is rolling out support to multi-sensors now, so fingers crossed
Install this driver TEST in your hub from my Channel and pair device
The thermostat has Off, Heat and Sleep modes
The sleep mode, I don’t know if they have lower set heat points programmed internally for operation, the manual only says that it saves energy.
The heat set point limits are from 5ºc to 32ºc, according to the manual
When paired, the thermostat operating mode is established.
According to manual after thermostat mode is set, you need to perform a power reset of the plug. Ten after correct device pairing you need to perform a power reset so that it works as a thermostat
To work as a plug I will add it to the Zigbee switch power Mc driver
You’ll tell me if it works
Name Zigbee Thermostat Mc-TEST
Version 2023-11-29T15:12:01.849966137
- id: "NAMRON AS/4512749-N"
deviceLabel: NAMRON Plug Thermostat
manufacturer: NAMRON AS
model: 4512749-N
deviceProfileName: namrom-plug
For the Namron Thermostat they have different model numbers on the white and black version of the thermostat. Using our driver i have managed to get the white version working.
Could you please add fingerprint for the black version as well.
The model number for the black version is 4512738.
Hello @Mariano_Colmenarejo, you think you could add IKEA’s VINDSTYRKA?
I’d be nice to have the PM2.5 data as well but I’m not sure it can be done if you don’t own the device…?
What I’m really interested in is to have decimals for the temperature like it does with my aqara sensors using your driver.
If your device uses the stock zigbee Humidity Sensor driver and does not show decimals, then with my driver it will not show them either.
The default libraries used by the stock driver and mine show the value that the device sends divided by 100, if it does not show decimals, then the device does not send them, as @Trakker2 said you in other thread.
If you want, I can add it and try it, but I don’t think it shows decimals in temperature.
As far as I know, smartthinhs there is no standard capability for PM2.5, there is an Air Quality Sensor capability, with a range from 0 to 100, I don’t know the range that your device uses, I would have to look for information on other platforms and possibly I would have to create a custom capabilty.
I also don’t have a device to test and debug.
DP
2 is mode (2 off, 1 is auto, 0 programmed) (not completely sure about these though)
3 is heating (1 off, 0 on)
4 is set temp * 10
5 is current temp * 10
7 is childlock ( true is locked, false unlocked)
New version of Zigbee Temp Sensor and Child Thermostat Mc
At the request of @RebelMagpie, I have modified the Tile Type preference to be able to show in a simple mosaic the Temperature or Humidity or illuminance or Atmospheric Pressure or Atmospheric Pressure rate change capability
Only the options of the capabilities supported by the device will be displayed
This version will be updated automatically in 12 hours maximum
Name Zigbee Temp Sensor and Child Thermostat Mc
Version 2024-01-22T17:47:55.94058266
is there any problem with this new version 2024-01 22T17… and sonoff snzb02 devices. My devices have lost connection for the past 24 hours.
Do you have any advice or things I can try to solve my problems?
@TapioX do you hav any advices for solving this typ of problems when the devices stops sending and reporting. I am quit new at smartthins so if you have som smart tips i will be grateful
