Thanks @Mariano_Colmenarejo - this is looking positive.
The basic actuator functions seem to be working correctly, certainly for the temperature settings.
As you identified - there is something unusual about the boost function - pressing the physical button (twice) opens the valve fully but there are no logs generated; the same in reverse - closes or reverts to temperature set point. For me, that function isnt really necessary - I can set the temperature higher or lower of course to have the valve open.
Howerver, the App is not reporting the value of something called “State” or the “Battery” level - these would be useful.
? Select a driver. 17
connecting… connected
2022-12-27T12:21:28.668836414+00:00 DEBUG Zigbee Thermostat Mc driver device thread event handled
2022-12-27T12:21:47.575394756+00:00 TRACE Zigbee Thermostat Mc Received event with handler capability
2022-12-27T12:21:47.738126756+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received command: {“args”:{},“capability”:“refresh”,“command”:“refresh”,“component”:“main”,“positional_args”:{}}
2022-12-27T12:21:47.814890423+00:00 TRACE Zigbee Thermostat Mc Found CapabilityCommandDispatcher handler in zigbee-thermostat
2022-12-27T12:21:47.921874090+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x430B, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0011 > > >
2022-12-27T12:21:48.063173090+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x430B, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0012 > > >
2022-12-27T12:21:48.215494090+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x430B, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-12-27T12:21:48.378374090+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x430B, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x001B > > >
2022-12-27T12:21:48.442399423+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x430B, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0029 > > >
2022-12-27T12:21:48.545456423+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x430B, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x001E > > >
2022-12-27T12:21:48.639591757+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x430B, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x001C > > >
2022-12-27T12:21:48.672207423+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x430B, dest_endpoint: 0x01, profile: 0x0104, cluster: FanControl >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0001 > > >
2022-12-27T12:21:48.742780757+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x430B, dest_endpoint: 0x01, profile: 0x0104, cluster: FanControl >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-12-27T12:21:48.817038423+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x430B, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0020 > > >
2022-12-27T12:21:48.937769757+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x430B, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x003E > > >
2022-12-27T12:21:48.979938090+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:51.038410091+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:51.060133091+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xC6, rssi: -77, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5A, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0011, ZclStatus: SUCCESS, DataType: Int16, OccupiedCoolingSetpoint: 2600 > > > >
2022-12-27T12:21:51.534755758+00:00 TRACE Zigbee Thermostat Mc Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2022-12-27T12:21:51.578718758+00:00 INFO Zigbee Thermostat Mc Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: OccupiedCoolingSetpoint
2022-12-27T12:21:51.653646758+00:00 WARN Zigbee Thermostat Mc Attempted to generate event for 07836e1e-4bb9-4e56-8bbe-17af82dba00b.main but it does not support capability Thermostat Cooling Setpoint
2022-12-27T12:21:51.871956758+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:51.895280091+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:51.914004091+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xD0, rssi: -74, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5B, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0012, ZclStatus: SUCCESS, DataType: Int16, OccupiedHeatingSetpoint: 2000 > > > >
2022-12-27T12:21:52.077160425+00:00 TRACE Zigbee Thermostat Mc Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2022-12-27T12:21:52.149226092+00:00 INFO Zigbee Thermostat Mc Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: OccupiedHeatingSetpoint
2022-12-27T12:21:52.206675092+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> emitting event: {“attribute_id”:“heatingSetpoint”,“capability_id”:“thermostatHeatingSetpoint”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:20.0}}
2022-12-27T12:21:52.415346092+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:52.516390092+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:52.598218092+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xC8, rssi: -74, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5D, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x001B, ZclStatus: SUCCESS, DataType: Enum8, ControlSequenceOfOperation: ControlSequenceOfOperation[HEATING_ONLY] > > > >
2022-12-27T12:21:52.828479092+00:00 TRACE Zigbee Thermostat Mc Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2022-12-27T12:21:52.878038425+00:00 INFO Zigbee Thermostat Mc Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: ControlSequenceOfOperation
2022-12-27T12:21:52.967999759+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> emitting event: {“attribute_id”:“supportedThermostatModes”,“capability_id”:“thermostatMode”,“component_id”:“main”,“state”:{“value”:[“off”,“heat”,“emergency heat”]},“visibility”:{“displayed”:false}}
2022-12-27T12:21:53.011728759+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:53.039846425+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:53.083547425+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCC, rssi: -74, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0029, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-12-27T12:21:53.150874425+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:53.186044759+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:53.305503759+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xD2, rssi: -74, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5F, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x001E, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-12-27T12:21:53.405549759+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:53.438308425+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:53.543015092+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCE, rssi: -73, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x60, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x001C, ZclStatus: SUCCESS, DataType: Enum8, SystemMode: SystemMode[HEAT] > > > >
2022-12-27T12:21:53.717545092+00:00 TRACE Zigbee Thermostat Mc Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2022-12-27T12:21:53.725960092+00:00 INFO Zigbee Thermostat Mc Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: SystemMode
2022-12-27T12:21:53.750266092+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> emitting event: {“attribute_id”:“thermostatMode”,“capability_id”:“thermostatMode”,“component_id”:“main”,“state”:{“value”:“heat”}}
2022-12-27T12:21:53.812943426+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:53.818834426+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:53.855500092+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: FanControl >, lqi: 0xCC, rssi: -73, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x61, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: UNSUPPORTED_CLUSTER > > >
2022-12-27T12:21:53.880149426+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:53.888758092+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:53.906212426+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: FanControl >, lqi: 0xD0, rssi: -73, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x62, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: UNSUPPORTED_CLUSTER > > >
2022-12-27T12:21:53.926041759+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:53.948670092+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:53.966167759+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x9C, rssi: -70, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x63, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0020, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-12-27T12:21:53.996943759+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:54.008247092+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:54.048874426+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0xD0, rssi: -74, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x64, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x003E, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-12-27T12:21:54.065500092+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:54.071570759+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:54.081749092+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCC, rssi: -72, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5A, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0011, ZclStatus: SUCCESS, DataType: Int16, OccupiedCoolingSetpoint: 2600 > > > >
2022-12-27T12:21:54.097983092+00:00 TRACE Zigbee Thermostat Mc Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2022-12-27T12:21:54.104900092+00:00 INFO Zigbee Thermostat Mc Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: OccupiedCoolingSetpoint
2022-12-27T12:21:54.111944426+00:00 WARN Zigbee Thermostat Mc Attempted to generate event for 07836e1e-4bb9-4e56-8bbe-17af82dba00b.main but it does not support capability Thermostat Cooling Setpoint
2022-12-27T12:21:54.117719759+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:54.123204759+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:54.133967426+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xD2, rssi: -73, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5B, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0012, ZclStatus: SUCCESS, DataType: Int16, OccupiedHeatingSetpoint: 2000 > > > >
2022-12-27T12:21:54.154235093+00:00 TRACE Zigbee Thermostat Mc Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2022-12-27T12:21:54.159547426+00:00 INFO Zigbee Thermostat Mc Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: OccupiedHeatingSetpoint
2022-12-27T12:21:54.166522093+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> emitting event: {“attribute_id”:“heatingSetpoint”,“capability_id”:“thermostatHeatingSetpoint”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:20.0}}
2022-12-27T12:21:54.192662759+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:54.201210093+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:54.213350759+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xD0, rssi: -74, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5C, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Int16, LocalTemperature: 1796 > > > >
2022-12-27T12:21:54.233602093+00:00 TRACE Zigbee Thermostat Mc Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2022-12-27T12:21:54.241538759+00:00 INFO Zigbee Thermostat Mc Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: LocalTemperature
2022-12-27T12:21:54.248394093+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:17.96}}
2022-12-27T12:21:54.270986093+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:54.278994093+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:54.290599759+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xD2, rssi: -72, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5D, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x001B, ZclStatus: SUCCESS, DataType: Enum8, ControlSequenceOfOperation: ControlSequenceOfOperation[HEATING_ONLY] > > > >
2022-12-27T12:21:54.308056426+00:00 TRACE Zigbee Thermostat Mc Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2022-12-27T12:21:54.314336759+00:00 INFO Zigbee Thermostat Mc Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: ControlSequenceOfOperation
2022-12-27T12:21:54.335299093+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> emitting event: {“attribute_id”:“supportedThermostatModes”,“capability_id”:“thermostatMode”,“component_id”:“main”,“state”:{“value”:[“off”,“heat”,“emergency heat”]},“visibility”:{“displayed”:false}}
2022-12-27T12:21:54.354483093+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:54.362491759+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:54.371697759+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xD0, rssi: -76, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0029, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-12-27T12:21:54.389489426+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:54.395483093+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:54.409477093+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xCC, rssi: -73, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5F, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x001E, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-12-27T12:21:54.446999093+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:54.452691759+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:54.461251426+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xC6, rssi: -72, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x60, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x001C, ZclStatus: SUCCESS, DataType: Enum8, SystemMode: SystemMode[HEAT] > > > >
2022-12-27T12:21:54.478351093+00:00 TRACE Zigbee Thermostat Mc Found ZigbeeMessageDispatcher handler in zigbee-thermostat
2022-12-27T12:21:54.484633426+00:00 INFO Zigbee Thermostat Mc Executing ZclClusterAttributeValueHandler: cluster: Thermostat, attribute: SystemMode
2022-12-27T12:21:54.491187093+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> emitting event: {“attribute_id”:“thermostatMode”,“capability_id”:“thermostatMode”,“component_id”:“main”,“state”:{“value”:“heat”}}
2022-12-27T12:21:54.509695093+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:54.517492426+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:54.530238759+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: FanControl >, lqi: 0xC6, rssi: -73, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x61, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: UNSUPPORTED_CLUSTER > > >
2022-12-27T12:21:54.546966093+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:54.552670759+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:54.560746093+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: FanControl >, lqi: 0xCC, rssi: -72, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x62, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: UNSUPPORTED_CLUSTER > > >
2022-12-27T12:21:54.577781093+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:54.583254759+00:00 TRACE Zigbee Thermostat Mc Received event with handler zigbee
2022-12-27T12:21:54.591701426+00:00 INFO Zigbee Thermostat Mc <ZigbeeDevice: 07836e1e-4bb9-4e56-8bbe-17af82dba00b [0x430B] (Eurotronic Thermostat)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x430B, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0xCA, rssi: -72, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x63, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0020, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-12-27T12:21:54.618507093+00:00 DEBUG Zigbee Thermostat Mc Eurotronic Thermostat device thread event handled
2022-12-27T12:21:58.686256095+00:00 DEBUG Zigbee Thermostat Mc driver device thread event handled
