In the above post are the use instructions when i published the beta version
Yeah perhaps itβs me. I create the group from a light. Assign all desired lights to the group (ie example group 1) insure that itβs clicked active on each desired light, and the mirror groups does nothing for me. Can turn it on and off all day and it has zero effect on the lights theoretically paired to it .
Which one turns on and off, the child mirror group or the parent light?
Is the mirror group also activated on the child mirror device?
Group is activated on both child and group. Itβs group 0 (Iβve tried changing to 1 it does the same) however one thing I notice if I change the color on the actual light it changes the color on the mirror group. But thatβs it.
Changing on the mirror group does nothing, and adding a second light also does nothing, meaning that second light has no control over the mirror group, and the first light has no control over the second light.
Wait itβs suddenly working now, ha!
@Mariano_Colmenarejo Profile request! I got a zigbee βartifical skylightβ that has a very wide color range to mimic the sun. It goes up to 8000k, but as best I can tell the Color Temperature Profiles in your driver only go up to 6500. Can you expand the limit or add a new profile?
Wath are your device model for assign a new profile?
Sure! Itβs a niche product called Blue Sky Light from Empowline.
However, the name in Smartthings is quite different. Is this what you need?
Manufacturer: _TZ3210_s1x7gcq0
Model: TS0502B
Could you post a screenshot of the device history to see the supported clusters?
Is a dimmer and color temperature device?
Added to this driver version
You need uninstall device and reinstall with this driver version installed
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Light Multifunction Mc
Version 2024-11-25T22:23:33.811333984
- id: "_TZ3210_s1x7gcq0/TS0502B"
deviceLabel: TS0502B LED
manufacturer: _TZ3210_s1x7gcq0
model: TS0502B
deviceProfileName: level-colortemp-2000-8000
Hello, Mariano.
First of all, I appologize about my poor English skill.
Can I ask something?
I have four βTRADFRI bulb E14 CWS opal 600lmβ that I bought 2021. That was work with the driver βZigbee Multilight Function MCβ until now. About from over 1 years ago, I canβt control RGB color, color temperature any more. When that time, I had busy days so that was neglect. ;(
I tried to re-connect over 10 times and reset hub. And I tried to re-connect again one more time today. But still I canβt control. The bulb was fixed color temperature 2700K. All I can control is bright level.
I can control the color on the app, but the bulb was not change. Color temperature, neither.
Sir, If you know my trouble or solution, please let me know.
I really want to use bulb that changed color.
- Model : TRADFRI bulb E14 CWS opal 600lm
- Manufacturer Code : IKEA of Sweden
Did you get this worked out with dimming innr bulbs. I have the same problem and innr support was a waste.
Hi @Almond
You need uninstall device and reinstall with this driver version installed in your hub
Version 2024-11-26T22:18:57.046667926
- id: "TRADFRI bulb E14 CWS opal 600lm"
deviceLabel: IKEA E26 Bulb
manufacturer: IKEA of Sweden
model: TRADFRI bulb E14 CWS opal 600lm
deviceProfileName: rgbw-level-colortemp-2000-6500
Can you add Innr Bulb model AE 262? Itβs a dimmable zigbee bulb but using the default SmartThings driver once the bulb is dimmed you canβt increase the brightness.
It works! Thank you ![]()
@Mariano_Colmenarejo, thanks in advance for creating this driver, working to keep it updated, and supporting the community.
I bought a NEDIS ZBWS40WT Zigbee Smart Wall Switch (SmartLife/Tuya - https://nedis.com/en-us/product/smart-home/energy/switches/550774462/smartlife-wall-switch-zigbee-30-wall-mount-android-ios-plastic-white), a 4 Way switch and I cant find any driver beside the native ST Zigbee switch (1Way).
Can you add this device to your driver?
name: βNEDIS Zigbee Smart Wall Switch ZBWS40WTβ
manufacturer: _TZ3000_wkai4ga5
model: TS0044
Sorry, this device does not work with my driver
It must works with driver in this @erickv channel link
Thank you for your reply, yes, the driver from @erickv is the one that I am using after a fast search, I was just seeing if it could be added to your pool of supported devices (since itβs the non-native ST drivers that I use the most).
It could be my OCD, but I like to interact with the bare minimal non-native drivers/software, itβs easier to keep things updated and reviewed.
And I see that you do a good job on maintaining and developing Edge drivers, kudos for you.
Thanks once again.
