DusanH:
Can you please add this LIDL Livarno E14 CCT bulb :
Data
application: 50
endpointId: 01
manufacturer: _TZ3000_oborybow
model: TS0502A
zigbeeNodeType: ROUTER
Raw Description
01 0104 010C 01 08 0000 0003 0004 0005 0006 0008 0300 1000 02 0019 000A
Added to this driver version
│ Name │ Zigbee Light Multifunction Mc │
│ Version │ 2022-01-28T13:20:02.481826 │
- id: "_TZ3000_oborybow/TS0502A"
deviceLabel: TS0502A RGBW
model: TS0502A
deviceProfileName: rgbw-level-colortemp-2700-6500
- id: "_TZ3000_th6zqqy6/TS0505B"
deviceLabel: TS0505B RGBW
manufacturer: _TZ3000_th6zqqy6
model: TS0505B
This TS0502A
deviceProfileName: level-colortemp-2000-6500
Not RGBW
Sorry, I must be a bit thick,
I was surprised, since I have the same model, but type E27
│ Version │ 2022-01-28T19:22:57.317676 │
deviceLabel: TS0502A LIDL
model: TS0502A
All Lidl bulbs are color 2200-6500 k. Sorry.
LIVARNO LUX® LED-pære - hos Lidl Danmark - www.lidl.dk this is the danish site
THX for your Work.
So try it like 2000-6500k
I have that same model for months and it works very well
- id: "LIDL/TS0502A"
deviceLabel: Lidl Bulb
manufacturer: _TZ3000_49qchf10
model: TS0502A
Will you also change TS0505B to RGBW Level colortemp 2000-6500 k?
For the RGBW profile you can choose colortemperature range in preferences.
So, you close the app, clear the cache if it’s Android and that’s it.
Hi again. I have a problem with the TS0502a cct. It do not remember the settings for colortemp or dimmer.
I don’t know very well what you mean
Mine works fine, they remember the last level and color temperature.
Except when I turn them off by removing the power
Hi
Can you add this one for us please
RGBW
application: 01
endpointId: 0B
manufacturer: GLEDOPTO
model: GL-S-007Z
Raw Description 0B C05E [0210 02 07 0000 0003](tel:0210 02 07 0000 0003) [0004 0005 0006 0008](tel:0004 0005 0006 0008) 0300 00
Perhaps a bad explanation. When I change dimmer level and colortemp it keeps loading and do not save the changes.
I can not change to 100 pct dimmer level only less than 90 pct.
It doesn’t make much sense for that to happen.
I don’t know if you’ve already tried uninstalling it and reinstalling it. Sometimes it doesn’t install correctly.
When you install it, give it time to install and configure itself completely, Edge drivers take longer to install than it seems in the app.
when the device appears, don’t handle it, wait about 30 sec or more, go back and open the device, it should work
│ Version │ 2022-02-09T16:21:01.894464 │
- id: "GLEDOPTO/GL-S-007Z"
deviceLabel: GLEDOPTO GL-S-007Z
model: GL-S-007Z
WolframF
(Wolfram)
February 10, 2022, 11:01am
54
Hi,
it would be really nice if you could also add the following devices.
firmwareManufacturerCode: 4489
firmwareFullVersion: 00203045
application: 00
endpointId: 01
firmwareImageType: 138
manufacturer: LEDVANCE
model: A60 RGBW Value II
Raw Description: 01 0104 010D 01 09 0000 0003 0004 0005 0006 0008 0300 0B05 1000 01 0019
firmwareFullVersion: 00103101
application: 01
endpointId: 01
firmwareImageType: 17
model: CLA60 RGBW Z3
Raw Description: 01 0104 010D 01 0A 0000 0003 0004 0005 0006 0008 0300 0B05 1000 FC0F 01 0019
application: 01
endpointId: 0B
model: GL-C-008
Raw Description: 0B C05E 0210 02 07 0000 0003 0004 0005 0006 0008 0300 00
Many thanks for your great work!
Wolfram
WolframF:
application: 00
endpointId: 01
application: 01
endpointId: 01
application: 01
endpointId: 0B
model: GL-C-008
Adde to this driver version
│ Version │ 2022-02-10T16:01:45.721749 │
- id: "LEDVANCE/A60 RGBW Value II"
deviceLabel: LEDVANCE A60 RGBW
- id: "LEDVANCE/CLA60 RGBW Z3"
deviceLabel: LEDVANCE CLA60 RGBW
WolframF:
model: GL-C-008
Already exit in the previous versions
Hi
Can you add this one please
RGBW Bulb
application: 00
endpointId: 0B
manufacturer: Ajax online Ltd
model: AJ_ZB30_GU10
Raw Description 0B 0104 010D 01 [08 0000 0003 0004](tel:08 0000 0003 0004) [0005 0006 0008 0300](tel:0005 0006 0008 0300) 1000 00
│ Version │ 2022-02-11T18:05:43.166745 │
- id: "Ajax online/AJ_ZB30_GU10"
deviceLabel: RGBW AJ_ZB30_GU10
model: AJ_ZB30_GU10
IVIik
(Michael Anderson )
February 12, 2022, 1:37pm
59
Any chance of an add pls.
Data:
application: 10
endpointId: 03
manufacturer: OSRAM
model: Ceiling TW OSRAM
Raw Description 03 C05E 0220 02 09 1000 0000 0003 0004 0005 0006 0008 0300 FC0F 01 0019
Is RGBW or color temperature only?
