(EDGE Driver-Mc): Zigbee Light Multifunction Mc
IDE told me I’m using the
manufacturer: GLEDOPTO
model: GL-C-006P
Should be this one:
LED controller ZigBee 3.0 Standard [SHOP] - Gledopto ZigBee Light and
Added to this driver version
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ Name        β”‚ Zigbee Light Multifunction Mc        β”‚
β”‚ Version     β”‚ 2022-08-14T20:55:18.750552281        β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
  - id: "GL-C-006P/Gledopto"
    deviceLabel: Light Gledopto
    model: GL-C-006P
    deviceProfileName: level-colortemp-2700-6500
Did someone already told you how great you are?
No?
YOU ARE GREAT!
Up and running!
Settings will be for next weekend.
If you change mode, each mode will give you different model number. You can end up with 5 different models. However Gledopto made it easy as those mode modedel numbers are same as single mode units.
What modes do you mean?
As far as I can tell if I select a different use on the gledopto website the model also changes?
Mine is functioning now so I’m happy.
Do you have 5in1 model as shown above?
5 in 1 model changes modes as shown below
If you change mode, you have to re-add device each time as it changes model number.
Good to know in case I ever decide to use it for something else!
Sorry for offtopic.
This is the link. is in the post you sent my
Can you add Innr β€ŽOSL 130 C /17 US to this edge driver?
Hi @swdeason
Before I answered you in the wrong thread, sorry
I nee the exacte manufacturer and model that appears in IDE page
  • application: 28
  • endpointId: 01
  • firmwareFullVersion: 28002162
  • firmwareImageType: 1795
  • firmwareManufacturerCode: 4454
  • manufacturer: innr
  • model: OSL 130 C
  • zigbeeNodeType: ROUTER
β”‚ Version     β”‚ 2022-08-17T15:38:52.430329123        β”‚
  - id: "OSL 130 C/innr"
    deviceLabel: Light OSL 130 C
    manufacturer: innr
    model: OSL 130 C
    deviceProfileName: rgbw-level-colortemp-2000-6500
Thank you, Was able to connect the OSL 130 C to Smartthings on the Edge drivers. Do we have the capability to change the colors to our choice… for example would like red, white, and blue?
Hi @swdeason
Sorry, I don’t quite understand what you mean by this.
On the edge driver portion there is a color change mode, is there a way to change the color to what the user wants not the preset colors?
Hello Mariano!
I think this time, I did a thorough search of the fingerprints.
I believe this controller is the same as many others (RGBCCT) in the .yml file, but has a different manufacturer.
Data * application: 42
  • endpointId: 01
  • manufacturer: _TZ3000_qqjaziws
  • model: TS0505B
    Raw Description 01 0104 010D 01 08 0000 0003 0004 0005 0006 1000 0008 0300 02 0019 000A
***Said to be CCT 2000K-6500K
If you can add this sometime, I would be grateful as always.!
Not at this time. Only presets.
Thank you very much
@blkwll, @Helder_Rodrigues, @JP3000
Added to this driver version:
β”‚ Version     β”‚ 2022-08-18T16:30:29.043778551        β”‚
  - id: "_TZ3000_qqjaziws/TS0505B"
    deviceLabel: RGBW TS0505B
    model: TS0505B
  - id: "innr/POR 265"
    deviceLabel: POR 265 Bulb
    manufacturer: innr
    model: POR 265
    deviceProfileName: switch-level
  - id: "eWeLight/ZB-DL01"
    deviceLabel: ZB-DL01 Bulb
    manufacturer: eWeLight
    model: ZB-DL01
Sorry it is not possible to do that at the moment
