(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
@Luis_Mijares and @Mario_Machado,
Try this driver version with conversion tables as DTH
Only need install driver XY and perform a driver change in app
│ Name        │ Zigbee Light Multifunction XY        │
│ Version     │ 2022-05-02T20:41:06.613013           │
This one works perfect changing colours. Great job again @Mariano_Colmenarejo.
It work just like the last DTH (I have another bulb still with groovy) In colour mode are so dimmed but I think that it is a bulb problem.
Perfect colours also in a Lidl led strip.
Gracias Mariano.
@amin300,
I things the logs are not the correct version
Please, install this date version with CLI and try it
│ Name        │ Zigbee Multi Switch Test             │
│ Version     │ 2022-05-02T21:03:39.313036           │
Ok,
When @Mario_Machado answer, I merge the changes with the Mc driver
I’ll let you know when I’m
Logs
Part 1
Summary
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Try the new cross-platform PowerShell Install PowerShell on Windows, Linux, and macOS - PowerShell | Microsoft Docs
PS C:\WINDOWS\System32> cd…
PS C:\WINDOWS> cd…
PS C:> cd users
PS C:\users> cd aminhsm
PS C:\users\aminhsm> cd documents
PS C:\users\aminhsm\documents> cd cli
PS C:\users\aminhsm\documents\cli> .\smartthings edge:drivers:logcat
? Enter hub IP address with optionally appended port number: 192.168.1.58
│ # │ Driver Id │ Name │
│ 1 │ c411db9e-a042-459a-a145-f005c65412ee │ ST Zigbee Button Mc │
│ 2 │ 86d761b1-e962-4756-a9b2-edab02b8567d │ Tasmota Edge │
│ 3 │ 981aab30-6f78-4b31-bf0b-b422bef161ec │ Yeelight.Color │
│ 4 │ 71915c2a-8604-4cd5-aaba-22988490bcbb │ Z-Wave Switch Mc │
│ 5 │ ad9f537d-e2d9-4354-8673-471a5306fad8 │ Zigbee Button Groups │
│ 6 │ 1e45a851-8f07-48d1-bcbf-932fb377e95e │ Zigbee Dimmer Remote │
│ 7 │ ccea734e-e56e-4d2c-a259-3b2e1fdebd82 │ Zigbee Humidity Sensor │
│ 8 │ 6b86005f-95b4-49cb-a3d5-d3a17fd94177 │ Zigbee Light Multifunction Mc │
│ 9 │ d620900d-f7bc-4ab5-a171-6dd159872f7d │ Zigbee Motion Sensor │
│ 10 │ 00425c55-0932-416f-a1ba-78fae98ab614 │ Zigbee Motion Sensor Mc │
│ 11 │ fe12554c-d40f-439c-a57c-cbc0f27b11dd │ Zigbee Multi Switch Test │
│ 12 │ 07e8d581-9c59-4c10-9d06-7e1c75c00f5c │ Zigbee Switch │
│ 13 │ 27a1cfbe-1d4f-4be1-b803-2feb3a645e32 │ Zigbee Switch │
│ 14 │ cf6324c4-22c0-49e0-a761-fa298b510e58 │ Zigbee Switch │
│ 15 │ 580a4441-7d16-437e-8cdc-97c03f59e2df │ Zigbee Switch Mc │
│ 16 │ f732925a-9ae3-462a-9641-f03f474c661e │ Zigbee Switch Power Mc │
│ 17 │ 026385b3-dfa9-43e5-b443-cfc42123f042 │ Zigbee Temp Humidity Sensor Mc │
│ 18 │ bd79913f-0309-4256-b669-74c489b81140 │ Zigbee Temp Humidity Sensor Mc-(OLD) │
│ 19 │ 8bf71a5d-677b-4391-93c2-e76471f3d7eb │ Zigbee Thing │
? Select a driver. 11
connecting… connected
2022-05-02T21:15:34.133073558+00:00 TRACE Zigbee Multi Switch Test Setup driver Zigbee_Multi_Switch with lifecycle handlers:
DeviceLifecycleDispatcher: Zigbee_Multi_Switch
default_handlers:
doConfigure:
init:
infoChanged:
driverSwitched:
configure:
child_dispatchers:
2022-05-02T21:15:34.141324225+00:00 TRACE Zigbee Multi Switch Test Setup driver Zigbee_Multi_Switch with Capability handlers:
CapabilityCommandDispatcher: Zigbee_Multi_Switch
default_handlers:
switch:
on
off
legendabsolute60149.switchAllOnOff1:
setSwitchAllOnOff
refresh:
refresh
child_dispatchers:
2022-05-02T21:15:34.150080558+00:00 TRACE Zigbee Multi Switch Test Setup driver Zigbee_Multi_Switch with Zigbee handlers:
ZigbeeMessageDispatcher: Zigbee_Multi_Switch
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
global:
ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
cluster:
zdo:
child_dispatchers:
2022-05-02T21:15:34.193599225+00:00 TRACE Zigbee Multi Switch Test Zigbee Device: aced45b6-32b1-4509-b877-b19904e446c5
Manufacturer: _TZ3000_fvh3pjaz Model: TS0012
[1]: Basic, Groups, Scenes, OnOff [2]: Groups, Scenes, OnOff
2022-05-02T21:15:34.207013225+00:00 DEBUG Zigbee Multi Switch Test driver device thread event handled
2022-05-02T21:15:34.214760558+00:00 TRACE Zigbee Multi Switch Test Received event with handler _resync
2022-05-02T21:15:34.223134225+00:00 TRACE Zigbee Multi Switch Test Received event with handler environment_info
2022-05-02T21:15:34.236458892+00:00 TRACE Zigbee Multi Switch Test Found DeviceLifecycleDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:15:34.253195558+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x4001, DataType: Uint16, data: 0x0000 > > > >
2022-05-02T21:15:34.271416892+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x4001, DataType: Uint16, data: 0x0000 > > > >
2022-05-02T21:15:34.301314225+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 60A423FFFE651394, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 286D97000200C8A4, dest_endpoint: 0x01 > > >
2022-05-02T21:15:34.328793225+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x0078 > > > >
2022-05-02T21:15:34.346315225+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x02, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 60A423FFFE651394, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 286D97000200C8A4, dest_endpoint: 0x01 > > >
2022-05-02T21:15:34.377620892+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x0078 > > > >
2022-05-02T21:15:34.399743558+00:00 PRINT Zigbee Multi Switch Test <<< Timer read attribute >>>
2022-05-02T21:15:34.417724892+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:34.423826892+00:00 TRACE Zigbee Multi Switch Test Received event with handler environment_info
2022-05-02T21:15:34.434374225+00:00 DEBUG Zigbee Multi Switch Test Z-Wave hub node ID environment changed.
2022-05-02T21:15:34.454068892+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:34.461639892+00:00 TRACE Zigbee Multi Switch Test Received event with handler driver_lifecycle
2022-05-02T21:15:34.476816558+00:00 TRACE Zigbee Multi Switch Test Received event with handler driver_lifecycle
2022-05-02T21:15:34.493308892+00:00 TRACE Zigbee Multi Switch Test Received event with handler device_lifecycle
2022-05-02T21:15:34.504781558+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received lifecycle event: added
2022-05-02T21:15:34.513752225+00:00 TRACE Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received unhandled lifecycle event: added
2022-05-02T21:15:34.529595225+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:34.539319892+00:00 TRACE Zigbee Multi Switch Test Received event with handler device_lifecycle
2022-05-02T21:15:34.554548558+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received lifecycle event: doConfigure
2022-05-02T21:15:34.562473225+00:00 TRACE Zigbee Multi Switch Test Found DeviceLifecycleDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:15:34.568919892+00:00 TRACE Zigbee Multi Switch Test Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:15:34.582436225+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-05-02T21:15:34.610738892+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-05-02T21:15:34.630708558+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 60A423FFFE651394, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 286D97000200C8A4, dest_endpoint: 0x01 > > >
2022-05-02T21:15:34.662030892+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-05-02T21:15:34.682623558+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x02, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 60A423FFFE651394, src_endpoint: 0x02, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 286D97000200C8A4, dest_endpoint: 0x01 > > >
2022-05-02T21:15:34.706512558+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-05-02T21:15:34.723113558+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:34.730056892+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:34.766000558+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x74, rssi: -71, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x04, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2022-05-02T21:15:34.791540558+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:34.800569559+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:34.824928225+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x08, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x4001, DataType: Uint16, OnTime: 0x0000 > > > >
2022-05-02T21:15:34.846228225+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:34.867223892+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:34.886333225+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x05, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2022-05-02T21:15:34.996022559+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:35.117885559+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:35.146991225+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x74, rssi: -71, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x09, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x4001, DataType: Uint16, OnTime: 0x0000 > > > >
2022-05-02T21:15:35.258055225+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:35.440861559+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:35.754969226+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x06, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-05-02T21:15:35.858205226+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:35.891673226+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:35.947836559+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0x78, rssi: -70, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x4C >, < BindRequestResponse || status: 0x00 > > >
2022-05-02T21:15:35.991214559+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
Logs
Part 2
Summary
2022-05-02T21:15:36.010896892+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:36.051606226+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x74, rssi: -71, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x07, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-05-02T21:15:36.083036892+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:36.095416226+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:36.140980892+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x74, rssi: -71, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x08, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2022-05-02T21:15:36.179291559+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:36.185192559+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:36.206246559+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x74, rssi: -71, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x09, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2022-05-02T21:15:36.250906226+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:15:36.261013559+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:15:36.280653226+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:15:36.308702226+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-05-02T21:15:36.373554226+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 1 value = false
2022-05-02T21:15:36.399281893+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:36.429801226+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:36.446619559+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0A, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-05-02T21:15:36.483007559+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:15:36.488359559+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:15:36.494295893+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:15:36.501568893+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“switch2”,“state”:{“value”:“off”}}
2022-05-02T21:15:36.519851893+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 2 value = false
2022-05-02T21:15:36.534893226+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:36.540688226+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:36.548765893+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0x78, rssi: -70, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x4E >, < BindRequestResponse || status: 0x00 > > >
2022-05-02T21:15:36.564563226+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:36.570376226+00:00 TRACE Zigbee Multi Switch Test Received event with handler device_lifecycle
2022-05-02T21:15:36.582894893+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received lifecycle event: infoChanged
2022-05-02T21:15:36.591363559+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:36.598170559+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:36.606858226+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:36.615696893+00:00 TRACE Zigbee Multi Switch Test Found DeviceLifecycleDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:15:36.621255559+00:00 PRINT Zigbee Multi Switch Test device.preferences[infoChanged]= Single
2022-05-02T21:15:36.627344893+00:00 PRINT Zigbee Multi Switch Test << Preference changed: name, old, new >> changeProfileTwoSw nil Single
2022-05-02T21:15:36.642144559+00:00 PRINT Zigbee Multi Switch Test device.preferences[infoChanged]=
2022-05-02T21:15:36.650001226+00:00 PRINT Zigbee Multi Switch Test << Preference changed: name, old, new >> version nil
2022-05-02T21:15:36.657358226+00:00 PRINT Zigbee Multi Switch Test Device ID <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)>
2022-05-02T21:15:36.664008893+00:00 PRINT Zigbee Multi Switch Test Manufacturer >>> _TZ3000_fvh3pjaz Manufacturer_Len >>> 16
2022-05-02T21:15:36.670791226+00:00 PRINT Zigbee Multi Switch Test Model >>> TS0012 Model_len >>> 6
2022-05-02T21:15:36.679186559+00:00 PRINT Zigbee Multi Switch Test Memory >>>>>>> 1303.224609375 Kbytes
2022-05-02T21:15:36.690321559+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:36.733850893+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:36.742130559+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0B, ZCLCommandId: 0x07 >, < ConfigureReportingReponse || ZclStatus: SUCCESS > > >
2022-05-02T21:15:36.758075226+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:38.403492227+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:15:38.410141560+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 0 Total >>> 2
2022-05-02T21:15:38.416870560+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:“All Off”}}
2022-05-02T21:15:38.434532894+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:38.535094894+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:15:38.541182894+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 0 Total >>> 2
2022-05-02T21:15:38.547629227+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:“All Off”}}
2022-05-02T21:15:38.562901894+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:44.244761563+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:44.273671896+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x08, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2022-05-02T21:15:44.302492563+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:15:44.317311563+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:15:44.351232230+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:15:44.360051230+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-05-02T21:15:44.377758230+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 1 value = false
2022-05-02T21:15:44.390409230+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:44.396193896+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:15:44.405842563+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x09, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2022-05-02T21:15:44.423352896+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:44.430676896+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:15:44.438034230+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:15:44.443785563+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:15:44.450312896+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“switch2”,“state”:{“value”:“off”}}
2022-05-02T21:15:44.467298896+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 2 value = false
2022-05-02T21:15:44.479855563+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:44.487762563+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:46.396329897+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:15:46.406515564+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 0 Total >>> 2
2022-05-02T21:15:46.415728231+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:“All Off”}}
2022-05-02T21:15:46.433092231+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:15:46.485674564+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:15:46.491533897+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 0 Total >>> 2
2022-05-02T21:15:46.498482897+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:“All Off”}}
2022-05-02T21:15:46.518345231+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:16:04.176433573+00:00 DEBUG Zigbee Multi Switch Test driver device thread event handled
2022-05-02T21:16:34.196997253+00:00 DEBUG Zigbee Multi Switch Test driver device thread event handled
2022-05-02T21:16:42.687081351+00:00 TRACE Zigbee Multi Switch Test Received event with handler capability
2022-05-02T21:16:42.728733166+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received command: {“args”:{},“capability”:“switch”,“command”:“on”,“component”:“main”,“positional_args”:{}}
2022-05-02T21:16:42.734931264+00:00 TRACE Zigbee Multi Switch Test Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:16:42.745413169+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x01 >, < On || > > >
2022-05-02T21:16:42.759183384+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-05-02T21:16:42.800281256+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:16:42.809866046+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:16:43.014177484+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:16:43.030594355+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x0C, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2022-05-02T21:16:43.045125617+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:16:43.050643374+00:00 INFO Zigbee Multi Switch Test Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2022-05-02T21:16:43.057241005+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-05-02T21:16:43.076855140+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:16:43.084450936+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:16:43.093105928+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0E, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-05-02T21:16:43.108410577+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:16:43.113759250+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:16:43.120776090+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:16:43.127580490+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-05-02T21:16:43.142705716+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 1 value = true
2022-05-02T21:16:43.153243315+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:16:43.160892805+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:16:44.812902064+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:16:44.819535379+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 1 Total >>> 2
2022-05-02T21:16:44.826166693+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:"S1:On "}}
2022-05-02T21:16:44.843874209+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:16:45.163506612+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:16:45.186851278+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 1 Total >>> 2
2022-05-02T21:16:45.226896291+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:"S1:On "}}
2022-05-02T21:16:45.291692006+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
Logs
Part 3
Summary
2022-05-02T21:17:04.207076950+00:00 DEBUG Zigbee Multi Switch Test driver device thread event handled
2022-05-02T21:17:24.427057626+00:00 PRINT Zigbee Multi Switch Test <<< Timer read attribute >>>
2022-05-02T21:17:24.437093626+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-05-02T21:17:24.470968293+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-05-02T21:17:24.486888293+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:17:24.603393960+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:17:24.614384293+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x74, rssi: -71, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-05-02T21:17:24.648363960+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:17:24.654589293+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:17:24.660510960+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:17:24.668138960+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-05-02T21:17:24.685710626+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 1 value = true
2022-05-02T21:17:24.699750960+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:17:24.705870626+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:17:24.714469626+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x7C, rssi: -69, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0F, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2022-05-02T21:17:24.729875626+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:17:24.739321293+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:17:24.744692626+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:17:24.750627293+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:17:24.757049626+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“switch2”,“state”:{“value”:“off”}}
2022-05-02T21:17:24.773945960+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 2 value = false
2022-05-02T21:17:24.786526626+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:17:24.795192626+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:17:26.699576627+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:17:26.706401627+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 1 Total >>> 2
2022-05-02T21:17:26.713528961+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:"S1:On "}}
2022-05-02T21:17:26.746715961+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:17:26.792812961+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:17:26.798862294+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 1 Total >>> 2
2022-05-02T21:17:26.805216294+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:"S1:On "}}
2022-05-02T21:17:26.823546627+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:17:34.217056964+00:00 DEBUG Zigbee Multi Switch Test driver device thread event handled
2022-05-02T21:18:04.217057645+00:00 DEBUG Zigbee Multi Switch Test driver device thread event handled
2022-05-02T21:18:34.217033326+00:00 DEBUG Zigbee Multi Switch Test driver device thread event handled
2022-05-02T21:18:45.069322998+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:18:45.316555332+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0019, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x00, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false >, < AttributeRecord || AttributeId: 0x4001, DataType: Uint16, OnTime: 0x0000 >, < AttributeRecord || AttributeId: 0x4002, DataType: Uint16, OffWaitTime: 0x0000 >, < AttributeRecord || AttributeId: 0x8001, DataType: Enum8, Enum8: 0x01 >, < AttributeRecord || AttributeId: 0x8002, DataType: Enum8, Enum8: 0x00 > > > >
2022-05-02T21:18:45.606893332+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:18:45.789298332+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:18:45.867197332+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:18:45.978144332+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-05-02T21:18:46.032358332+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 1 value = false
2022-05-02T21:18:46.078746332+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:18:46.091588665+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:18:46.125211332+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0011, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x01, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false >, < AttributeRecord || AttributeId: 0x4001, DataType: Uint16, OnTime: 0x0000 >, < AttributeRecord || AttributeId: 0x4002, DataType: Uint16, OffWaitTime: 0x0000 > > > >
2022-05-02T21:18:46.141993332+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:18:46.159110665+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:18:46.164432332+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:18:46.170522999+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:18:46.183954332+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“switch2”,“state”:{“value”:“off”}}
2022-05-02T21:18:46.216899999+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 2 value = false
2022-05-02T21:18:46.235390665+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:18:46.246302999+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:18:48.089235999+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:18:48.106912333+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 0 Total >>> 2
2022-05-02T21:18:48.119686666+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:“All Off”}}
2022-05-02T21:18:48.143406666+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:18:48.238840333+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:18:48.245218333+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 0 Total >>> 2
2022-05-02T21:18:48.252001666+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:“All Off”}}
2022-05-02T21:18:48.267615666+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:18:58.127530338+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:18:58.147086004+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0019, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x03, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false >, < AttributeRecord || AttributeId: 0x4001, DataType: Uint16, OnTime: 0x0000 >, < AttributeRecord || AttributeId: 0x4002, DataType: Uint16, OffWaitTime: 0x0000 >, < AttributeRecord || AttributeId: 0x8001, DataType: Enum8, Enum8: 0x01 >, < AttributeRecord || AttributeId: 0x8002, DataType: Enum8, Enum8: 0x00 > > > >
2022-05-02T21:18:58.166916338+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:18:58.172788004+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:18:58.180752338+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:18:58.194329338+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-05-02T21:18:58.229141004+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 1 value = false
2022-05-02T21:18:58.252466671+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:18:58.265117004+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:18:58.273080671+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:18:58.283309671+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x74, rssi: -71, body_length: 0x0011, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x04, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false >, < AttributeRecord || AttributeId: 0x4001, DataType: Uint16, OnTime: 0x0000 >, < AttributeRecord || AttributeId: 0x4002, DataType: Uint16, OffWaitTime: 0x0000 > > > >
2022-05-02T21:18:58.344200671+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:18:58.355211671+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:18:58.363397004+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:18:58.370351338+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“switch2”,“state”:{“value”:“off”}}
2022-05-02T21:18:58.388447004+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 2 value = false
2022-05-02T21:18:58.401655671+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:18:58.409163671+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:19:00.254451005+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:19:00.269608005+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 0 Total >>> 2
2022-05-02T21:19:00.326860672+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:“All Off”}}
2022-05-02T21:19:00.407106339+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:19:00.465094672+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:19:00.490526005+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 0 Total >>> 2
2022-05-02T21:19:00.517126339+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:“All Off”}}
2022-05-02T21:19:00.614866672+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:19:04.227082007+00:00 DEBUG Zigbee Multi Switch Test driver device thread event handled
2022-05-02T21:19:14.433944679+00:00 PRINT Zigbee Multi Switch Test <<< Timer read attribute >>>
2022-05-02T21:19:14.446880679+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-05-02T21:19:14.464242679+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFB23, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-05-02T21:19:14.492960012+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:19:14.684383012+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:19:14.693638346+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x78, rssi: -70, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x15, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2022-05-02T21:19:14.718674012+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:19:14.724084679+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:19:14.729941679+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:19:14.738439679+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-05-02T21:19:14.756672346+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 1 value = false
2022-05-02T21:19:14.769953679+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:19:14.777784346+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:19:14.894280679+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-05-02T21:19:14.904401679+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB23, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x74, rssi: -71, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x16, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2022-05-02T21:19:14.920948012+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-05-02T21:19:14.926391679+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-05-02T21:19:14.932183679+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-05-02T21:19:14.940526679+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“switch2”,“state”:{“value”:“off”}}
2022-05-02T21:19:14.958144012+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 2 value = false
2022-05-02T21:19:14.978697346+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:19:14.990632679+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:19:16.777750013+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:19:16.784362680+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 0 Total >>> 2
2022-05-02T21:19:16.790872680+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:“All Off”}}
2022-05-02T21:19:16.808427680+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
2022-05-02T21:19:16.972340680+00:00 PRINT Zigbee Multi Switch Test all_switches_status >>>>>
2022-05-02T21:19:16.978898680+00:00 PRINT Zigbee Multi Switch Test Total_on >>>>>> 0 Total >>> 2
2022-05-02T21:19:16.985387013+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: aced45b6-32b1-4509-b877-b19904e446c5 [0xFB23] (TS0012 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:“All Off”}}
2022-05-02T21:19:17.002985680+00:00 DEBUG Zigbee Multi Switch Test TS0012 Switch device thread event handled
@amin300,
Sorry, I’m not able to see anything in the logs that can fix it.
I don’t know if I could see anything if you could send the IDE logs when it is installed with the DTH
Hello again Mariano,
IKEA/TRADFRI on/off switch doesn’t work. Please remove it from Zigbee Switch Mc so we could revert to dth until we found a solution for it.
Best regards.
Deleted in this driver version
│ Name        │ Zigbee Switch Mc                     │
│ Version     │ 2022-05-02T22:14:47.844583           │
  #- id: "IKEA/TRADFRI on/off switch"
  #  deviceLabel: IKEA on/off switch
  #  manufacturer: IKEA of Sweden
  #  model: TRADFRI on/off switch
  #  deviceProfileName: single-switch
Thank you so much. Your efforts are much appreciated
@amin300,
I did a little change for not configure this device in a new version.
Also could try to pair It with DTH and uninstall and repairing with Driver
Sorry, but trying to understand, is it correct the following:
  1. Delete device
  2. Add device with DHT
  3. Delete device again
  4. Add device with driver
    Correct?
Ikea switch works with stock edge driver
:frowning:
Same results
If you can and when you have time try to capture the logs of the IDE when device is paired with the DTH.
could give some useful information
Sure I will
Just if you can provide a hint how exactly i can do it correctly :wink:
IDE logs
Summary
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:07:12 AM: debug checkAllSwtichValue null : on
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:07:12 AM: debug parse - sendEvent parent 01
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:07:12 AM: debug eventMap [name:switch, value:on] | eventDescMap [raw:0104 0006 01 01 0000 00 4B53 00 00 0000 01 01 0000001001, profileId:0104, clusterId:0006, sourceEndpoint:01, destinationEndpoint:01, options:0000, messageType:00, dni:4B53, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, attrId:0000, resultCode:00, encoding:10, value:01, isValidForDataType:true, data:[00, 00, 00, 10, 01], clusterInt:6, attrInt:0, commandInt:1]
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:07:12 AM: debug parse - sendEvent child 02
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:07:12 AM: debug eventMap [name:switch, value:off] | eventDescMap [raw:0104 0006 02 01 0000 00 4B53 00 00 0000 01 01 0000001000, profileId:0104, clusterId:0006, sourceEndpoint:02, destinationEndpoint:01, options:0000, messageType:00, dni:4B53, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, attrId:0000, resultCode:00, encoding:10, value:00, isValidForDataType:true, data:[00, 00, 00, 10, 00], clusterInt:6, attrInt:0, commandInt:1]
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:07:11 AM: debug refresh 02
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:07:11 AM: debug Tuya Multi Switch 2
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:07:11 AM: debug getEndpointCount[TS0012] : 2
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:07:11 AM: debug healthPoll()
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:29 AM: debug checkAllSwtichValue null : on
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:29 AM: debug parse - sendEvent parent 01
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:29 AM: debug eventMap [name:switch, value:on] | eventDescMap [raw:0104 0006 01 01 0000 00 4B53 00 00 0000 0A 01 00001001, profileId:0104, clusterId:0006, sourceEndpoint:01, destinationEndpoint:01, options:0000, messageType:00, dni:4B53, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0A, direction:01, attrId:0000, encoding:10, value:01, isValidForDataType:true, data:[00, 00, 10, 01], clusterInt:6, attrInt:0, commandInt:10]
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:28 AM: debug checkAllSwtichValue null : on
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:28 AM: debug parse - sendEvent parent 01
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:28 AM: debug eventMap [name:switch, value:on] | eventDescMap [raw:0104 0006 01 01 0000 00 4B53 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, sourceEndpoint:01, destinationEndpoint:01, options:0000, messageType:00, dni:4B53, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00], clusterInt:6, commandInt:11]
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:28 AM: debug on
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:26 AM: debug checkAllSwtichValue null : off
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:26 AM: debug parse - sendEvent child 02
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:26 AM: debug eventMap [name:switch, value:off] | eventDescMap [raw:0104 0006 02 01 0000 00 4B53 00 00 0000 0A 01 00001000, profileId:0104, clusterId:0006, sourceEndpoint:02, destinationEndpoint:01, options:0000, messageType:00, dni:4B53, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0A, direction:01, attrId:0000, encoding:10, value:00, isValidForDataType:true, data:[00, 00, 10, 00], clusterInt:6, attrInt:0, commandInt:10]
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:26 AM: debug eventMap [name:switch, value:off] | eventDescMap [raw:0104 0006 02 01 0000 00 4B53 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, sourceEndpoint:02, destinationEndpoint:01, options:0000, messageType:00, dni:4B53, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00], clusterInt:6, commandInt:11]
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:25 AM: debug child off 4B53:02
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:20 AM: debug checkAllSwtichValue null : off
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:20 AM: debug parse - sendEvent parent 01
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:20 AM: debug eventMap [name:switch, value:off] | eventDescMap [raw:0104 0006 01 01 0000 00 4B53 00 00 0000 0A 01 00001000, profileId:0104, clusterId:0006, sourceEndpoint:01, destinationEndpoint:01, options:0000, messageType:00, dni:4B53, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0A, direction:01, attrId:0000, encoding:10, value:00, isValidForDataType:true, data:[00, 00, 10, 00], clusterInt:6, attrInt:0, commandInt:10]
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:20 AM: debug eventMap [name:switch, value:off] | eventDescMap [raw:0104 0006 01 01 0000 00 4B53 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, sourceEndpoint:01, destinationEndpoint:01, options:0000, messageType:00, dni:4B53, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00], clusterInt:6, commandInt:11]
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:05:18 AM: debug off
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:05:02 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:05:02 AM: debug updated called
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:05:00 AM: debug No devices to add, verified devices: [:]
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:05:00 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:05:00 AM: trace in ssdpDiscover
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:05:00 AM: debug scheduled run, numberOfRuns: 1
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:05:00 AM: trace in discovery
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:28 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:28 AM: debug updated called
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:17 AM: debug No devices to add, verified devices: [:]
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:17 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:17 AM: trace in ssdpDiscover
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:17 AM: debug scheduled run, numberOfRuns: 9
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:17 AM: trace in discovery
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:04:05 AM: debug refresh 02
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:04:05 AM: debug Tuya Multi Switch 2
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:04:05 AM: debug getEndpointCount[TS0012] : 2
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:04:05 AM: debug Configuring Health Check, Reporting
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:04:05 AM: debug configure()
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:04:05 AM: debug ===========Need to createChildDevice: 4B53:02
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:04:05 AM: debug =============createChildDevices of 4B53
e64844fc-d139-49e4-8ad3-dfbf6ac832fe 6:04:05 AM: debug installed()
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:02 AM: debug No devices to add, verified devices: [:]
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:02 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:02 AM: trace in ssdpDiscover
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:02 AM: debug scheduled run, numberOfRuns: 8
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:04:02 AM: trace in discovery
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:47 AM: debug No devices to add, verified devices: [:]
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:47 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:47 AM: trace in ssdpDiscover
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:47 AM: debug scheduled run, numberOfRuns: 7
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:47 AM: trace in discovery
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:32 AM: debug No devices to add, verified devices: [:]
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:32 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:32 AM: trace in ssdpDiscover
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:32 AM: debug scheduled run, numberOfRuns: 6
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:32 AM: trace in discovery
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:25 AM: debug No devices to add, verified devices: [:]
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:25 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:25 AM: trace in ssdpDiscover
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:25 AM: debug scheduled run, numberOfRuns: 5
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:25 AM: trace in discovery
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:18 AM: debug No devices to add, verified devices: [:]
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:18 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:18 AM: trace in ssdpDiscover
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:18 AM: debug scheduled run, numberOfRuns: 4
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:18 AM: trace in discovery
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:11 AM: debug No devices to add, verified devices: [:]
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:11 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:11 AM: trace in ssdpDiscover
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:11 AM: debug scheduled run, numberOfRuns: 3
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:11 AM: trace in discovery
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:04 AM: debug No devices to add, verified devices: [:]
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:04 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:04 AM: trace in ssdpDiscover
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:04 AM: debug scheduled run, numberOfRuns: 2
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:03:04 AM: trace in discovery
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:02:57 AM: debug No devices to add, verified devices: [:]
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:02:57 AM: debug detecting status for 7e1d15b0-25e7-4326-8546-57b92ade4583 : true
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:02:57 AM: trace in ssdpDiscover
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:02:57 AM: debug scheduled run, numberOfRuns: 1
0f934bd3-152c-40e1-8169-45b26d94b3d5 6:02:57 AM: trace in discovery
6:02:26 AM: info Waiting on events…
6:02:26 AM: info For past logs for individual things go to the My Devices section, find the device and click on the Events link on the device information page.
6:02:26 AM: info This console provides live logging of your SmartThings.
Thanks a lot for your sharing all your drivers.
Tried on of them, it works fine!
Can you please add a fingerprint of TUYA power plug below?
Data
  • application: 42
  • endpointId: 01
  • manufacturer: _TZ3000_8nkb7mof
  • model: TS0121
  • zigbeeNodeType: ROUTER
Raw Description
01 0104 010A 01 09 0000 0003 0004 0005 0006 0702 0B04 E000 E001 02 0019 000A
No log of the writing and response of the attribute 0x0099 to value 1 is seen, it is supposed to do so but the response is not displayed.
I have made some changesin this version to see what it does
│ Name        │ Zigbee Multi Switch Test             │
│ Version     │ 2022-05-03T10:53:59.853135           │
