Ive tested the updated driver and it works great! Thank you very much for your help ![]()
This contact sensor also has an βAnti-Tamperβ functionality. Is it possible to add that functionality too?
Iβm glad it works well
Tamper alert information is sent with the same cluster number and attribute as the open/close information.
smartthings has not default tamper function in the zigbee hub libraries.
This means that I have to write that code in the driver itself and since the functions to handle open/close are in the hub libraries then I would also have to rewrite this code in the driver, which now runs on the hub, and change the entire structure of the current driver.
When smartthings adds tamper to the zigbee defaults like it has done for zwave, then it will be very easy to add it to the driver.
Its a shame they hadnβt done that alreadyβ¦ hopefully itβll be added sometime soon.
Anyways, thanks again for your help ![]()
Hi @Mariano_Colmenarejo ,
Thank you for your driver. I have used your Zigbee Motion Sensor Mc to run the Bosch ISW-ZPR1-WP13. I realized there was no history of the motion and only had the temperature. I removed the device and tried to repair again. No matter what Iβve tried, it canβt be seen from the paring. I have reset the device multiple times and have rebooted my v2 hub and changed the zigbee channel to 11. None of the tricks work for me. Do you have any suggestion? Please let me know what extra information I need to provide. Thank you again
Hi @msazone
Sorry, I donβt use that device and I donβt know how to pair it.
According to the comments of several users, it is always quite problematic to put it in pairing mode and to pair.
On the other hand, I have read todayβs post from some users who also have problems pairing devices to the hub, I donβt know if it has any relation.
Thank you so much taking time to reply.
Itβs suddenly working again just FYI.
Could it have something to do with this?
I am not sure when did the firmware get updated on my hub. I couldnβt find a history log feature to track it. The current firmware is 000.054.00013 which should be 0.54.13. According to my email, this firmware was scheduled to process on Sep 24, 2024 - 14:00 UTC.
Could you please add the new Sonoff SNZB-04P contact sensor to your list
Manufacturer: eWeLink
Model: SNZB-04P
FingerPrinted_EndPoint.Id: 0x01
App Version: 0x00
ZCL Version: 0x08
Network ID: 0xEDFD
Zigbee EUI: 0CEFF6FFFE75278A
Device ID: b3583e22-d87c-44c3-8c1f-43cafd8aa5b7
Server Cluster:
Ep: 0x01={ 0000,0001,0003,0020,0500,FC57,FC11 }
Client Clusters:
Ep: 0x01={ 0003,0006,0019 }
Signal Metrics:
LQI: 204 β¦ RSSI: -72 dbm
Thank you!
Hi @Warrdif
Added to this driver version
You need uninstall device
Install this driver version in your Hub
Pair device with with this driver version, you do not perform a driver change from zigbee thing
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Contact Mc
Version 2024-11-15T21:09:40.416190022
- id: "eWeLink/SNZB-04P"
deviceLabel: eWeLink Open/Closed Sensor
manufacturer: eWeLink
model: SNZB-04P
deviceProfileName: contact-battery-profile
Thank you so much! You are amazing
Agree, @Mariano_Colmenarejo is amazing and helping everyone. For SNZB-04P , Sonoff also release an Edge Driver. You can find more information here:
Thank you for this one as well. Iβve actually been using their own driver for a week before asking but it had some problems on reporting battery status (tried it on 2 sensors and got the same result) even after resetting and reconnecting multiple times. All that plus I really need signal metrics too.
Havenβt thought about sending some feedback to them but might do that as well.
What problems?
It wasnβt showing any battery info and it said something like βupdatingβ (I canβt really remember what it said and unfortunately I didnβt take any screenshots of it). Tried pairing it multiple times close to the hub as well as in the final position but it was the same.
Also wanted to test it again today with the official Sonoff driver to see if anything changed after Iβve used it with yours and had no problems with it, itβs flawless, and to my surprise the Sonoff driver now works as well, it shows the battery at 100% so I have no idea why it didnβt from the start. But Iβll continue to use your version going further. If Iβll encounter any problems with it Iβll let you know ![]()
Hello, Mariano! How are you?
Could you please help me with this device? It is recognizing but not working well. Itβs a presence sensor
Thanks a lot!
Hi,
Name Zigbee Motion Sensor Mc
Version 2024-11-28T10:27:48.997179295
- id: "_TZ3000_5kwwrk7a/TS0202"
deviceLabel: TS0202 Motion Sensor
manufacturer: _TZ3000_5kwwrk7a
model: TS0202
deviceProfileName: motion-battery
Hi, Mariano.
Thanks for your reply, but unfortunately itβs still not working. Should I wait some time?
Hello all,
I really need some clarifications:
1- from where i can install an edge driver for my Aqara temp & humidity sensor? It is not T1 model, it is WSDCGQ11LM model.
2- what are the differences for edge drivers, between Child Thermostat Mc and Thermostat Mc? Basically, what is that Child in the name of edge driver?
Thank you guys in advance!
