(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
I don’t know what model your device is.
Mine is a samjin, (aeotec) and the three profiles work well, Multipurpose, Temperature and vibration
1000012539
1000012538
1000012537
If you were using the old smartthings Multipurpose Sensor Mc and have switched to the Zigbee Contact Mc you may need to pair it directly with this driver for it to configure correctly.
The changes that have been made to the flow of life cycles in driverSwitched may not work correctly with this function.
Good morning @Mariano_Colmenarejo
This morning I produced a video for Wesley M ( @w35l3y ) with the smatthins-cli prompt ouput window for the fingerbot plus zigbee. If you’re interested, I’ll leave you the link to the produced files.
Bye
PS obviously the files are available to all developers who know what they are.
This Zigbee motion sensor don’t work. Anyone got it to work?
_TZ3000_6ygjfyll
Should work with @Mariano_Colmenarejo driver
zigbee motion sensor MC
Thanks working after reset.
Hi @brogio
For what you want to do, you don’t need to modify any drivers.
You just have to do a routine on each device:
If switch is On then turn Off after 2 sec.
I never thought how these scene buttons were working with zigbee.
Now I know some use standard OnOff cluster with toggle effect.
It seems your routine will work well if the driver have a switch instead of a momentary button.
Thanks - I deleted the ST Multipurpose Sensor Mc and switched to the Zigbee Contact Mc. It’s now reflecting the temperature, but the tile is showing this weirdness which is why I was switching from the ST Multipurpose Sensor to begin with:
This is iOS, started after the last app update.
I use Android.
The driver does not control the connected that appears in the mosaic
Hi @Mariano_Colmenarejo
Yes, you are absolutely right, in fact I had used your driver and created a routine which after 2 seconds would turn off the object. (from ON to OFF)
The only drawback is that the servo, in this way, makes two commutations
(UP to DOWN to UP - wait 2seconds - UP to DOWN to UP)
As far as I’m concerned I could easily use it like this, but… why not improve
Interestingly deleting and re-pairing only worked with one of the two identical devices. I can’t get the other to show anything but the contact sensor on the main tile. It is using the Zigbee Contact Mc by default when it pairs. Ugh. This system gets more frustrating every day.
I’ve been having issues with my Centralite temperature/humidity sensors as well. A couple just will not pair correctly, even when switched to stock drivers. They always default to custom drivers. I believe there is something with the custom drivers that is causing them to not pair correctly, or not do an initial sync correctly, and then they fail to work when switched to the desired drivers.
I guess something with the iOS app then. This is the actual Smartthings Multipurpose Sensor device.
Hello @Mariano_Colmenarejo, my Fingerbot Plus seems to have the following manifacturer code: _TZ3210_j4pdtz9v (model TS0001) instead of the one that you mapped (_TZ3210_dse8ogfy).
Hi @Daniele_Ratti
Added to this driver version
 Name         Zigbee Switch Mc
 Version      2023-09-04T12:26:07.568365363
- id: "_TZ3210_j4pdtz9v/Fingerboot"
    deviceLabel: Fingerboot Plus
    manufacturer: _TZ3210_j4pdtz9v
    model: TS0001
    deviceProfileName: switch-battery
Thank you! I’ll wait for the update :slight_smile:
Sorry to bother you again for this object (Fingerbot PLUS zigbee) but it seems that for now your β€œZigbee Switch MC” driver is the best performing one (Wesley is still working on it).
As you said, the routine also resolves the issue of the OFF - ON - OFF state.
The problem remains that the battery level is not displayed… Do you think there is anything you can do?
Thank you for your job.
I have one identical to that one and the battery reports every 4 hours.
It may be that you have been changing it from one driver to another and it has been misconfigured.
Delete it, reset the device and put it in pairing mode to add it directly to the driver so that it is configured correctly
Works! As you predicted, after a few hours it started displaying the battery percentage
@Mariano_Colmenarejo - Hi, do you know if the Halo RL56 Zigbee lights are compatible with your driver? If not, what do you need to add them? I see other posts providing screenshots of the light details, but can seem to find that in my ST app for my Halo lights. Below is a link to their website.
You can search for the fingerprints, manufacturer and model at my.smartthings.com, advanced users
Or installing zigbee thing Mc driver from my channel and perform a driver change
