You can put some motions sensors and door/window sensors in your home that will trigger an alarm, if you home is in ARM mode , and will not effect alarm in NOT ARM mode.
Right. I have those. The idea is to only disable the alarm if an access code is used via a routine, not if itās just simply unlocked. My alarm system is in ST as a device already.
Hello,
@Mariano_Colmenarejo
Is it possible to add the following CO to the driver?
Many thanks.
Antoine
Hi @DerAnton
I take note to do it in the month of August, until then I do not have access to the CLI or a pc
Perfect. Please let me know when done.
Hello! Is there a driver that works with this device? It would only be to measure consumption (it has no function, not even a switch, just measure it)
@Mariano_Colmenarejo for the Aqara Open/Close Sensor P1, it will show offline after certain time if no triggering. is that anywhere we can avoid the offline msg showing up? if not really offline, just the sensor go to sleep modeā¦
Hi
Can you add the following device driver into the ZigBee Light Multifunction Mc Driver fingerprints?
Manufacturer: Nue ZigBee Dimmer
Model: FB56+ZSC04HG1.0
Shahab
Hi @Raimundo
More information is needed from the device, fingerprints, clusters, to know if it could work
I donāt know if this manufacturer is the right one
Hi @Steven_Lim
I have read in several posts the problems of the aqara devices with the use of certain repeaters and not using their own hub, I donāt know if it has something to do with this
Hi
Can you please use below details and add to
ZigBee Light Multifunction Mc Driver fingerprint:
Manufacturer Code: Feibit Inc co.
I think it could be paired as a generic dimmer with my zigbee light multifunction Mc or with the stock zigbee switch driver
Stock zigbee switch dimmer doesnt work
Zigbee Light Multifunction Mc doesnt accept finger print
So please update driver fingerprint
YES !!
@w35l3y driver works very well. You can install from his channel here:
Hello - recently got myself a propane/natural gas sensor. Zwave+. Manufacturer Heiman HS1CG. Checking online I do see older device drivers such as: https://github.com/rockberte/SmartThings#heiman-smart-combustible-gas-sensor-hs1cg
As the new platform is Edge, is there any Edge Driver for this product please?
Hereās what I got after I moved the driver to Thing Mc:
The company website is here: https://www.heimantech.com/product/?type=detail&id=34 and confirmed (via them) that this is a US version.
Can you please add:
manufacturer: _TYZB01_8gqspaab
model: TS0003
@zambobmaz already did Edge driver for that, but yours have ability to separate to individual switches
which is preferredā¦
Hi @baivab
I donāt know if it would work, there are only Co and smoke sensors in zwave smoke alarm stock driver
Hi @Michielm71
This device was added to the driver by another user and is supposed to use the EF00 cluster.
I donāt know how this part of the driver used by the EF00 cluster works.
The strange thing is that in the fingerprints that you publish, the EF00 cluster is not present.
I have already seen it on other TUYA devices, which may be hidden. You can try with the Tuya EF00 personal driver from @w35l3y
