(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
@Mariano_Colmenarejo
Thank you!!
Dear @Mariano_Colmenarejo ,
could you please add the following Tuya Motion sensor?
Manufacturer: _TZ3040_fwxuzcf4
Model: TS0202
Server Cluster: 0x01={ 0001,0003,0004,0500,0000 }
Client Clusters: 0x01={ 0004,0006,1000,0019,000A }
Thank you in advance.
Zoltan
Hi @zoltan.yy
Added to this driver version
 Name         Zigbee Motion Sensor Mc
 Version      2023-05-31T22:14:46.21142265
- id: "_TZ3040_fwxuzcf4/Motion"
    deviceLabel: TS0202 Motion Sensor
    manufacturer: _TZ3040_fwxuzcf4
    model: TS0202
    deviceProfileName: motion-battery-sens
Thank you very much, Mariano,
it works, including the Battery status. :slight_smile:
(just a sidenote, if anyone is interested:
the sensor has a very low Alarm period: it goes back to β€œNo motion” after 5 seconds, and it doesn’t have a β€œcooldown” or blind period.
The same behaviour is also in the official Tuya environment.
I guess it may have effect on battery life, but can be very useful in some automation scenarios.)
That is the driver version aleady installed and the problem is ongoing.
Will try removing and re installing in the morning.
Hi, Mariano, Can you add this device?
it is Tuya CCT LED Strip and it’s driver.
I ordered it aliexpress.
https://www.aliexpress.com/item/1005005357956700.html
Thank you.
Hi @abdiel.im
Hi @Mariano_Colmenarejo,
I really appreciate your work and your drivers are already in use of some of my devices.
But I’ve got real issues adding this Zigbee Button to SmartThings. Can you please add an Edge driver for this one, too? Thanks a lot in advance! :pray:
Tuya ZigBee Smart Wireless Button (is in fact Moes Smart Button ERS-10TZBVB-AA)
https://de.aliexpress.com/item/1005005238316199.html
Name basic-switch
Mfg Name SmartThingsCommunity
Mfg Code _TZ3000_ja5osu5g
Model TS004F
ocf Type oic.d.switch
Category Switch
Room BΓΌro
Presentation ID dc51981a-71db-3f67-a30b-150d778cd741
Type ZIGBEE
Driver ID f2e891c6-00cc-446c-9192-8ebda63d9898
Driver Name Zigbee Switch
EUI 70AC08FFFEC5D119
Network ID 2044
Provisioning State PROVISIONED
Local Execution yes
Hi mariano,
do you have any driver for finger bot zigbe?
attached link to the product.
Just found this amazing item on AliExpress. Check it out! US $15.63 31%OFF | Tuya Zigbee Smart Fingerbot Plus Switch Button Pusher Touch Arms Fingerbot Smart Life Control Work with Alexa Google Home Alice
https://a.aliexpress.com/_Ey11dK5
Hi @Frank_n_stein
Sorry, I don’t have any button drivers that work with these devices and I don’t know how to make them either.
Hello Sir,
Which edge driver should I use for the for Sylvania Lightify/ OSRAM and Smart+ bulbs? Thank you in advance…
@mrfields2u Use this one. I am using it for very long time. This devices were one of the first couple added to his driver
This device is going offline mode after sometime but actually the device is still active. I am saying this because if the sensor gets wet, I see a notification in smarthings app and device becomes online again. Is there a way to keep the device always online in app?
Hi, Mariano @Mariano_Colmenarejo . Big thanks for your work, really appreciate it.
I have a request for two more Tuya devices. Noticed you already support these models from a different manufacturers.
  1. Temperature and humidity sensor LCD
    Manufacturer: _TZE200_nnrfa68v
    Model: TS0601
    NOUS E6 LCD ZigBee Smart Temperature and Humidity Sensor for smart home - Nous technology
  2. Water leak sensor
    Manufacturer: _TZ3000_0s9gukzt
    Model: TS0207
    NOUS E4 ZigBee Smart Water Leakage Sensor for smart home - Nous technology
Hi @Yaroslav
 Name         Zigbee Moisture Sensor Mc
 Version      2023-06-06T15:47:37.831649725
- id: "_TZ3000_0s9gukzt/Sensor"
    deviceLabel: TS0207 Water Sensor
    manufacturer: _TZ3000_0s9gukzt
    model: TS0207
    deviceProfileName: moisture-battery
This device use TUYA custom cluster EF00 and does nor work with my driver
Try in this thread
Hi @Manoj_Mishra
There are some users who complain that these devices TS0207 stay offline after a while. This is because periodic status messages are not received for the time specified in the hub’s firmware.
It can be due to several reasons:
  • The device itself is not configured correctly and does not send periodic reports.
  • The reports are sent but the signal is very weak and is lost without reaching the Hub, because they are usually in hidden places, stuck to the ground, under metal appliances, which prevent the correct propagation of the radio frequency signal.
  • You can put zigbee repeaters between the device and the Hub and see if that fixes it.
  • You can buy another device that has better features, zwave for example, which uses a much lower frequency and propagates better in these circumstances.
  • You can forget that you are offline, since if it detects water it will notify you correctly. Just check from time to time that it works and has battery
Hi @Mariano_Colmenarejo, really appreciate your work!
Could you add this manufacturer variant for a TUYA door/window sensor?:
Thanks in advance!
Hi @norbertoh
 Name         Zigbee Contact Mc
 Version      2023-06-07T08:40:20.265657155
- id: "_TZ3000_a33rw7ou/Contact Sensor"
    deviceLabel: TS0203 Contact Sensor
    manufacturer: _TZ3000_a33rw7ou
    model: TS0203
    deviceProfileName: contact-battery-profile
Would you add three devices into your drivers?
one is motion sensor and the others are buttions.
Thanks.
It worked!
Thanks a lot for your quick and effective response!!
