(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
Hi @Mariano_Colmenarejo,
Wow that was quick, thank you so much!
The driver works initially, but then something goes wrong. Same behaviour I was having with the driver I created. I’ll try to explain as it’s a very strange issue and I couldn’t see anyone else having the same problems.
Initial setup:
  1. Attach device to hub, driver is assigned automatically.
  2. Switch works fine both manually on the switch and in app.
  3. Turn off power at the light circuit and turn on after a while (to simulate power failure)
  4. Switch becomes unresponsive, both in the app and on the wall switches.
  5. Turning power off and on again and the switch works for 1 or 2 button presses on the wall then stops responding again.
Switch can be recovered although the process isn’t easy!!
  1. Remove from SmartThings app.
  2. Turn off power circuit.
  3. Put SmartThings app in discover mode.
  4. Turn on power.
  5. After a couple of tries of step 3 and 4 switch is detected again and will function normally until power is turned off again.
  6. Removing switch from SmartThings. Switch works from wall if power is turned on and off many times.
I’m only guessing, but it seems the switch is trying to complete an initial handshake or is being flooded with messages and firmware is crashing.
Any help or guidance is very much appreciated.
It’s very strange, I don’t know what can happen.
you can see the logs with the CLI after recovering the power of the device, without touching it
Hi @Mariano_Colmenarejo , should this motion sensor work out-of-the-box?
I’ve got it paired but It doesn’t detect any motion.
Any ideas what could be wrong?
I’ve got it working with official Zigbee motion sensor driver and it works ok.
Now how about this guy:
A plug without power measurement. Aside from wanting to change the icon to something that resembles the appliance it manages, wondering there’s an option to turn off the light.
More
Also have these screen grabs…
Would you add two devices into your drivers?
one is door sensor and the other is motion sensor.
Thanks.
Hi @TheDreamer
Added to this driver version
E1C-NB6 and E1C-NB7 are in stock Zigbee Switch stock driver too
 Name         Zigbee Switch Mc
 Version      2023-02-15T10:54:41.112034286
- id: "sengled/E1C-NB6"
    deviceLabel: sengled Plug
    manufacturer: sengled
    model: E1C-NB6
    deviceProfileName: single-switch-plug
Hi @JayN
Added to these driver versions
 Name         Zigbee Contact Mc
 Version      2023-02-15T11:06:22.424985305
- id: "_TZ3000_suiggvyhClose Sensor"
    deviceLabel: TS0203 Close Sensor
    manufacturer: _TZ3000_suiggvyh
    model: TS0203
    deviceProfileName: contact-battery-profile
 Name         Zigbee Motion Sensor Mc
 Version      2023-02-15T11:03:12.450134847
- id: "_TZ3000_0b0c7d6h/Motion"
    deviceLabel: TS0202 Motion Sensor
    manufacturer: _TZ3000_0b0c7d6h
    model: TS0202
    deviceProfileName: motion-battery
Any driver for Orvibo Motion sensor?
  • deviceId: “933be75a-83ff-442b-86e3-02854466ae4f”,
  • name: “zigbee-thing”,
  • label: “Zigbee Thing”,
  • manufacturerName: “SmartThingsCommunity”,
  • presentationId: “0b49a9a6-e730-357d-a9f6-6ad05a24b5c9”,
  • deviceManufacturerCode: “欧瑞”,
  • locationId: “e37269d3-e85e-4999-a821-299d9ca288c6”,
  • roomId: “a7cfd7b8-553a-402a-8145-e26d1917336c”,
  • [components: (javascript:void(0))
    • [{4 items](javascript:void(0))}],
  • createTime: “2023-02-15T07:24:39.113Z”,
  • parentDeviceId: “195012b3-a20c-4afb-8cb3-309b82e88893”,
  • [profile: {](javascript:void(0))
    • id: “5d4f8398-35aa-3801-8e64-427aad9f7e59”},
  • [zigbee: {](javascript:void(0))
    • eui: “00124B000943DABB”,
    • networkId: “8083”,
    • driverId: “d692640b-402a-4d91-9151-d643ad4771f0”,
    • executingLocally: true,
    • hubId: “195012b3-a20c-4afb-8cb3-309b82e88893”,
    • provisioningState: “NONFUNCTIONAL”},
  • type: “ZIGBEE”,
  • restrictionTier: 0,
  • allowed:
Close
Hi @mickfff
fingerprint model is missing in this info
I couldnt remember how to get it from browser… had to screenshot!
You can capture in text from my.smartthings.com history.
I need copy and paste the manufacturer in this language
DeviceInfo:
Manufacturer: 欧瑞
Model: 585fdfb8c2304119a2432e9845cf2623
FingerPrinted_EndPoint.Id: 0x01
App Version: Unknown
ZCL Version: 0x01
Network ID: 0x8083
Zigbee EUI: 00124B000943DABB
Device ID: 933be75a-83ff-442b-86e3-02854466ae4f
Server Cluster:
Ep: 0x01={ 0000,0001,0003,0500 }
Client Clusters:
Ep: 0x01={ 0003 }
Signal Metrics:
LQI: 255 … RSSI: -51 dbm
 Version      2023-02-15T18:54:32.646064999
- id: "585fdfb8c2304119a2432e9845cf2623"
    deviceLabel: Orvibo Motion Sensor
    manufacturer: 欧瑞
    model: 585fdfb8c2304119a2432e9845cf2623
@Mariano_Colmenarejo This driver stopped working for me at some point this afternoon. I use it on six sets of Sylvania/Osram LED strips. I’ve been using the driver on two of the sets since December and all has been well. ST converted my other 4 sets to the stock driver a few days ago so I then switched those to your driver and all was well until this afternoon.
When on the device in the ST app I get the ‘This device hasn’t updated all of it’s …’ message. And if i try to turn on or off I get absolutely nothing in the CLI logcat.
I did try swapping back to the ST stock driver on one set and that is working.
Hi @Nezmo
I assume you mean the zigbee light multifunction Mc
The driver was updated yesterday at 12:12 utc. More than 24 hours have passed.
The new driver has a new capability to optionally control lights by groups. You may need to clear the app’s cache.
There have been several incidents of smartthings these days, have you tried to reboot the hub or reinstall the driver with the CLI?
Yes, sorry for the confusion.
I’m pretty sure the driver updated for me and was fine initially.
I’ve tried a reboot which did not resolve it. I will try a reinstall via the CLI now and then I’ll report back.
And just like that … this fixed it.
Thank you.
UPDATE: Something obviously went south today as I also had to reinstall the Aplicaciones Virtuales Mc driver as that had quit working for me too.
Hi. Would you add this devices into your drivers?
This device is motion sensor
thanks!!
