Stupid me. I though that it was enough te enroll the channel on my hub. I indeed need to install a driver still. But are you saying that there is no driver in this channel that supports this Aqara door/window sensor (MCCGQ11LM)?
The stock smartthings beta driver support this model
- id: "LUMI/lumi.magnet.agl02"
deviceLabel: Aqara Door and Window Sensor T1
manufacturer: LUMI
model: lumi.magnet.agl02
deviceProfileName: contact-battery-profile
@veonua or @ygerlovin could have drivers for this manufacturer
nope, I switched to Yakovs drivers with movement and door sensors.
I donβt own any Aqara door sensors to test.
Not sure what you are saying here. By default my sensor is now included as being a switch. Should I use those beta driver? How to?
Hi @slagterbas
I donβt know what fingerprint model your business model (MCCGQ11LM) corresponds to.
If you want to test if it works with the Zigbee Contact beta stock driver, go to this link and enroll your hub in the channel.
https://api.smartthings.com/invitation-web/accept?id=450930c1-02a6-43d8-adaa-4cbc51027956
Then install the Zigbee Contact driver from that channel.
Uninstall the device from the app
Add the device from the app with the search nearby option and if your model matches the model registered in the driver, it will be paired with it and will appear in an unassigned room
If You can try with @ygerlovin driver Channel enroll You hub in his shared channel
Install Zigbee Sensors Edge Driver [YG] and perform same previous step for install device
Cool! The Smartthings beta driver gave same result (showing the Aqara door sensor as a switch) but the driver from @ygerlovin did the trick. Its now a contact sensor. Awesome! Thanks a lot
Sorry for the late reply!
Well no I havenβt had a chance, a bit busy nowadays. Will let you know as soon as I tried it.
I havenβt done anything unusual!
Just added the device to smatthings and it was installed with one of the drivers.
I am using Marianoβs driver. HTe initialization doesnβt work but I donβt have any automation that requires the state of the blind. I just use it to open and close the blind and it works fine for me.
Thatβs very strange, I donβt know why my doesnβt seem to work.
Sometimes, it works one way - ie it will close the blind, but not open. Most of the time, it just doesnβt respond.
I wonder @Mariano_Colmenarejo if youβve any idea why it is behaving like this?
We both have the same device, one seems to work, the other just responds one way at times ![]()
@kaveh_amouzgar @Nishantshekhar
Iβm sorry, itβs nothing personal with you, but Iβm not going to fix and waste my time on anything from aqara, tuya, xiaomi,β¦for any function in which do not want to follow the zigbee standard or it is well documented.
It is a problem for aqara or the manufacturer to solve it, if they want it to work with smartthings, let them integrate it.
There are also other developers who know of those manufacturers and have drivers for them.
There are also more manufacturers or models that use the standard zigbee, you can buy things that can easily work with smartthings or return it.
@Mariano_Colmenarejo ,
Can you please add the following two-switch module:
Manufacturer: TYZB01_uqkphoed
Model: TS0003
Hi @dotan_shai
Added to this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2022-12-22T10:46:43.654705138
- id: "TS0003/_TYZB01_uqkphoed"
deviceLabel: TS0003 2 Switch
manufacturer: _TYZB01_uqkphoed
model: TS0003
deviceProfileName: two-switch
Hi @Kowalski
Enter the details of the your 2 gang device and open the three dots menu, top right, click the driver option and check that the driver version in your hub is 2022-12-21T22:12:49.863103217 or higher.
This ensures that the driver is updated for your device and you can add it
Is the one you mentioned, but isnβt able to see the 3 gang, Iβve deleted them few times and readded, and can only be seen as thing
At 1 and 2 gang along the thing driver will pop-up also the driver for them, but not in the case of 3 gang ones
Sorry I wrote an βaβ too many _TZ3000_jfha4mdia
Fixed in this version
Version 2022-12-22T11:00:16.25047088
- id: "TS0003/_TZ3000_jfh4mdia"
deviceLabel: TS0003 3 Switch
manufacturer: _TZ3000_jfh4mdia
model: TS0003
deviceProfileName: three-switch
roger that, I thought maybe my switches are defective or something (thatβs why Iβve reset the second one)
Thanks for spotting out.
Hi,
Can you please add the following ZigBee Range extenders.
[{modelID: 'TS0207', manufacturerName: '_TZ3000_m0vaazab'},
{modelID: 'TS0207', manufacturerName: '_TZ3000_ufttklsz'},
{modelID: 'TS0207', manufacturerName: '_TZ3000_nkkl7uzv'},
{modelID: 'TS0207', manufacturerName: '_TZ3000_gszjt2xx'},
{modelID: 'TS0207', manufacturerName: '_TZ3000_5k5vh43t'}],
some of them already included and supported. I need for _TZ3000_nkkl7uzv . But it will be excellent to have them allβ¦
