Thanks @rubberduck72
I Will change the name, but you donβt need do any.
The driver name will change automatically in next update
Hi @Mariano_Colmenarejo Mariano
Any chance of adding this lamp fingerprint from osram lamp ZLL
(This is not rgb colour)
Thanks in advance
Dave
Added to this version of driver
βββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β Zigbee Light Multifunction Mc β
β Version β 2022-08-31T19:08:14.787305954 β
βββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
- id: "OSRAM/TS0503B"
deviceLabel: OSRAM PAR16 50 TW
manufacturer: OSRAM
model: PAR16 50 TW
deviceProfileName: level-colortemp-2700-6500
Hi @Mariano_Colmenarejo, Can you please include these plug in the driver with consumption metering? Thanks
Hi @Shaikin
Added to this driver version
β Name β Zigbee Switch Power Mc β
β Version β 2022-09-06T17:40:23.662504357 β
- id: "TS011F/_TZ3000_cjrngdr3"
deviceLabel: TS011F Plug
manufacturer: _TZ3000_cjrngdr3
model: TS011F
deviceProfileName: switch-power-energy-plug
Hi @Mariano_Colmenarejo, I am having trouble trying to add a motion, and a contact sensors as Edge Drivers. They are working as DTH SmartSense Motion Sensor, and SmartSense Open/Closed Sensor. Is there any chance of adding their fingerprints? Thanks.
Could you add support for this device, please? Itβs a 4 switch device
Thank you @Mariano_Colmenarejo
Hi @Baranauskas
Added to these drivers versions
β Name β Zigbee Motion Sensor Mc β
β Version β 2022-09-08T16:14:18.789187655 β
- id: "_TZ3000_bsvqrxru/Motion"
deviceLabel: TS0202 Motion Sensor
manufacturer: _TZ3000_bsvqrxru
model: TS0202
deviceProfileName: motion-battery
β Name β Zigbee Contact Mc β
β Version β 2022-09-08T17:21:16.483818193 β
- id: "_TZ3000_2mbfxlzr/Close Sensor"
deviceLabel: TS0203 Close Sensor
manufacturer: _TZ3000_2mbfxlzr
model: TS0203
deviceProfileName: contact-battery-profile
- id: "_TZ3000_402jjyro/Contact Sensor"
deviceLabel: TS0203 Contact Sensor
manufacturer: _TZ3000_402jjyro
model: TS0203
Dear @Mariano_Colmenarejo
could you please add this LIDL Silvercrest Button (with ONE button)?
(model info if other community members will search for it: IAN 377680_2101 SSBM A1 model HG08164 Version 09/2021)
In Tuya/Smartlife it supports Single Press and Double Press (as far as I know, it doesnβt have a HOLD function).
In Smartthings DTH, it works with the built-in βZigbee Buttonβ DTH, but only supports single press.
Raw Description:
01 0104 0104 01 07 0000 0001 0003 0004 0006 1000 E001 08 0019 000A 0003 0004 0005 0006 0008 1000
Many thanks!
Hi @zoltan.yy
I donβt have any drivers for those buttons.
I donβt know if @erickv could add it to his driver
Hi @Mariano_Colmenarejo ,
Could I ask for the following to be added if possible? The device is initially assigned the stock Zigbee Switch driver on adding which produces 1 outlet.
Iβve tried using your Integrated Zigbee Swith DTH which produced 5 outlets, but they all control the whole strip, not individual outlets.
Xenon 4 outlet + usb
Amazon Link: https://www.amazon.co.uk/gp/product/B09JWP6TJG/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Data * application: 43
Raw Description 01 0104 010A 01 07 0003 0004 0005 0006 E000 E001 0000 02 0019 000A
Thank youβ¦
Mark
I think you asked me yesterday and I didnβt, sorry I missed it.
Could you install the Zigbee Thing Mc driver and send me a screenshot?
I want to see how many endpoints it has 4 or 5.
You have to unistall the custom DTH integrated zigbee switch to pair strip with the driver
I have a 3 + 2 USB power strip and the USBs cannot be controlled, it only has 3 endpoints
Sorry Mariano but youβre going to have to help me out hereβ¦
Iβve removed your integrated DTH, installed Zigbee Thing Mc driver and removed my power strip.
On discovering the power strip again, the Stock Zigbee driver is picking up the deviceβ¦giving me 1 outlet.
Am I missing something?
Added to this driver version as 4 plugs profile.
If device need 5 switches I will make a new profile for 5 plugs and modify the code. Now support max 4 components
β Name β Zigbee Multi Switch Mc β
β Version β 2022-09-08T20:51:39.018278365 β
- id: "TS011F/_TZ3000_cfnprab5"
deviceLabel: TS011F Switch
manufacturer: _TZ3000_cfnprab5
model: TS011F
deviceProfileName: four-outlet
Ok, so I now have the driver installed butβ¦
The behaviour is still the same, i.e Switching all outlets on, regardless of which switch is selected
Any more info I can give you to help?
Yes Please
Install driver Zigbee Thing Mc and perform a driver change ans send me a screenshoot
I donβt know why they are not controlled individually.
Try to reset it and re-pair it.
I donβt know if it will have any manufacturer specific configuration
If not works i need see the logs for the switch on and off
It has 5 final points, I have to add another profile and modify the driver, when I have it done I will notify you
Iβve reset & repaired a couple of times but still the same behaviour.
Iβll upload the recent eventsβ¦
If this is going to be hassle for you Mariano, Iβll find another device as I know you are busy and have helped many people here!
I would need the log captured with the CLI directly from the Hub since these are only the final events but the messages and commands between the device and the driver are not seen.
Tomorrow I will try to do the 5th component and if you want to look at the forum how to use the CLI to capture the logs tomorrow we will look at it
It seems that this is happening to more users with some multiple devices both on the DTH and with the driver and I would like to know what is the cause.
It could be something that the manufacturer configures by default and unconfigures it when installing it in its own app
