tank you for your help!!
try to do it still didnt work.
also turn off wifi and open the electrical box still noting ):
thts the log
? Select a driver. 24
connecting… connected
2022-11-26T17:25:54.881369693+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler driver_lifecycle
2022-11-26T17:26:06.056694361+00:00 TRACE Zigbee Multi Switch and Child Mc Setup driver Zigbee_Multi_Switch with lifecycle handlers:
DeviceLifecycleDispatcher: Zigbee_Multi_Switch
default_handlers:
removed:
infoChanged:
driverSwitched:
init:
doConfigure:
added:
child_dispatchers:
2022-11-26T17:26:06.104748361+00:00 TRACE Zigbee Multi Switch and Child Mc Setup driver Zigbee_Multi_Switch with Capability handlers:
CapabilityCommandDispatcher: Zigbee_Multi_Switch
default_handlers:
refresh:
refresh
energyMeter:
resetEnergyMeter
switchLevel:
setLevel
switch:
off
on
legendabsolute60149.switchAllOnOff1:
setSwitchAllOnOff
child_dispatchers:
2022-11-26T17:26:06.112957028+00:00 TRACE Zigbee Multi Switch and Child Mc Setup driver Zigbee_Multi_Switch with Zigbee handlers:
ZigbeeMessageDispatcher: Zigbee_Multi_Switch
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerMultiplier
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerDivisor
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: InstantaneousDemand
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Multiplier
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Divisor
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: CurrentSummationDelivered
ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
global:
ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
cluster:
zdo:
child_dispatchers:
2022-11-26T17:26:06.201382361+00:00 TRACE Zigbee Multi Switch and Child Mc Zigbee Device: f70a5200-5516-40bc-ab5a-39ed5c6bc8a6
Manufacturer: _TYZB01_gzhgaaqi Model: TS0003
[1]: Basic, Groups, Identify, OnOff, Scenes, TouchlinkCommissioning, Level [2]: Basic, Groups, Identify, OnOff, Scenes, TouchlinkCommissioning, Level [3]: Basic, Groups, Identify, OnOff, Scenes, TouchlinkCommissioning, Level
2022-11-26T17:26:06.238418361+00:00 TRACE Zigbee Multi Switch and Child Mc Zigbee Device: fe92f059-db6f-427a-8ff8-c8de85bb1f1e
2022-11-26T17:26:06.246342028+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler _resync
2022-11-26T17:26:06.252200028+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler environment_info
2022-11-26T17:26:06.302651361+00:00 TRACE Zigbee Multi Switch and Child Mc Found DeviceLifecycleDispatcher handler in Zigbee_Multi_Switch
2022-11-26T17:26:06.307849361+00:00 PRINT Zigbee Multi Switch and Child Mc device_network_id >>> 86F6
2022-11-26T17:26:06.313291028+00:00 PRINT Zigbee Multi Switch and Child Mc label >>> TS0003 Switch
2022-11-26T17:26:06.319000361+00:00 PRINT Zigbee Multi Switch and Child Mc parent_device_id >>> 4d626778-721c-4f13-a27d-1f908e8880bf
2022-11-26T17:26:06.324321028+00:00 PRINT Zigbee Multi Switch and Child Mc manufacturer >>>
2022-11-26T17:26:06.329341361+00:00 PRINT Zigbee Multi Switch and Child Mc model >>>
2022-11-26T17:26:06.335151361+00:00 PRINT Zigbee Multi Switch and Child Mc vendor_provided_label >>>
2022-11-26T17:26:06.340807361+00:00 PRINT Zigbee Multi Switch and Child Mc Parent_devices[f70a5200-5516-40bc-ab5a-39ed5c6bc8a6]>>>>>> <ZigbeeDevice: f70a5200-5516-40bc-ab5a-39ed5c6bc8a6 [0x86F6] (TS0003 Switch)>
2022-11-26T17:26:06.346056028+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> changeProfileThreeSw Preference value: Single
2022-11-26T17:26:06.358967361+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> version Preference value:
2022-11-26T17:26:06.366279028+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> switch2Child Preference value: No
2022-11-26T17:26:06.371454361+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> signalMetricsVisibles Preference value: No
2022-11-26T17:26:06.377504028+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> switch1Child Preference value: No
2022-11-26T17:26:06.382804028+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> switch3Child Preference value: No
2022-11-26T17:26:06.387924695+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> restoreState Preference value: 255
2022-11-26T17:26:06.393232695+00:00 PRINT Zigbee Multi Switch and Child Mc <<< Read Basic clusters attributes >>>
2022-11-26T17:26:06.400215361+00:00 PRINT Zigbee Multi Switch and Child Mc <<<< attr_id >>>> {4, 0, 1, 5, 7, 65534}
2022-11-26T17:26:06.419425361+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: f70a5200-5516-40bc-ab5a-39ed5c6bc8a6 [0x86F6] (TS0003 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x86F6, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0004, AttributeId: 0x0000, AttributeId: 0x0001, AttributeId: 0x0005, AttributeId: 0x0007, AttributeId: 0xFFFE > > >
2022-11-26T17:26:06.447926695+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0003 Switch device thread event handled
2022-11-26T17:26:06.454568695+00:00 TRACE Zigbee Multi Switch and Child Mc Found DeviceLifecycleDispatcher handler in Zigbee_Multi_Switch
2022-11-26T17:26:06.460096028+00:00 PRINT Zigbee Multi Switch and Child Mc device_network_id >>> 6F80
2022-11-26T17:26:06.465896028+00:00 PRINT Zigbee Multi Switch and Child Mc label >>> TS0003 Switch
2022-11-26T17:26:06.471251695+00:00 PRINT Zigbee Multi Switch and Child Mc parent_device_id >>> 4d626778-721c-4f13-a27d-1f908e8880bf
2022-11-26T17:26:06.483652028+00:00 PRINT Zigbee Multi Switch and Child Mc manufacturer >>>
2022-11-26T17:26:06.491771028+00:00 PRINT Zigbee Multi Switch and Child Mc model >>>
2022-11-26T17:26:06.497103361+00:00 PRINT Zigbee Multi Switch and Child Mc vendor_provided_label >>>
2022-11-26T17:26:06.502575361+00:00 PRINT Zigbee Multi Switch and Child Mc Parent_devices[fe92f059-db6f-427a-8ff8-c8de85bb1f1e]>>>>>> <ZigbeeDevice: fe92f059-db6f-427a-8ff8-c8de85bb1f1e [0x6F80] (TS0003 Switch)>
2022-11-26T17:26:06.508637361+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> changeProfileThreeSw Preference value: Single
2022-11-26T17:26:06.521370695+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> version Preference value:
2022-11-26T17:26:06.528710361+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> switch2Child Preference value: No
2022-11-26T17:26:06.543109028+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> signalMetricsVisibles Preference value: No
2022-11-26T17:26:06.550262028+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> switch1Child Preference value: No
2022-11-26T17:26:06.556779028+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> switch3Child Preference value: No
2022-11-26T17:26:06.562344028+00:00 PRINT Zigbee Multi Switch and Child Mc << Preference name: >> restoreState Preference value: 255
2022-11-26T17:26:06.567559695+00:00 PRINT Zigbee Multi Switch and Child Mc <<< Read Basic clusters attributes >>>
2022-11-26T17:26:06.573012028+00:00 PRINT Zigbee Multi Switch and Child Mc <<<< attr_id >>>> {4, 0, 1, 5, 7, 65534}
2022-11-26T17:26:06.580355362+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: fe92f059-db6f-427a-8ff8-c8de85bb1f1e [0x6F80] (TS0003 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6F80, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0004, AttributeId: 0x0000, AttributeId: 0x0001, AttributeId: 0x0005, AttributeId: 0x0007, AttributeId: 0xFFFE > > >
2022-11-26T17:26:06.625009695+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0003 Switch device thread event handled
2022-11-26T17:26:06.630760028+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler environment_info
2022-11-26T17:26:06.643808695+00:00 DEBUG Zigbee Multi Switch and Child Mc Z-Wave hub node ID environment changed.
2022-11-26T17:26:35.812603698+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-11-26T17:26:35.913883365+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: f70a5200-5516-40bc-ab5a-39ed5c6bc8a6 [0x86F6] (TS0003 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x86F6, src_endpoint: 0x03, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x88, rssi: -59, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x0A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-11-26T17:26:35.971193032+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-11-26T17:26:35.985018032+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-11-26T17:26:35.991172698+00:00 PRINT Zigbee Multi Switch and Child Mc function: on_off_attr_handler
2022-11-26T17:26:36.001219032+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: f70a5200-5516-40bc-ab5a-39ed5c6bc8a6 [0x86F6] (TS0003 Switch)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2022/11/26 Time: 17:26
DNI: 0x86F6 LQI: 136 RSSI: -59dbm
”},“visibility”:{“displayed”:false}}
2022-11-26T17:26:36.043962365+00:00 PRINT Zigbee Multi Switch and Child Mc src_endpoint = 3 value = false
2022-11-26T17:26:36.052017032+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: f70a5200-5516-40bc-ab5a-39ed5c6bc8a6 [0x86F6] (TS0003 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“switch3”,“state”:{“value”:“off”}}
2022-11-26T17:26:36.089436365+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0003 Switch device thread event handled
2022-11-26T17:26:36.095233032+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-11-26T17:26:36.105461365+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: f70a5200-5516-40bc-ab5a-39ed5c6bc8a6 [0x86F6] (TS0003 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x86F6, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x90, rssi: -57, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x09, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-11-26T17:26:36.144827365+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0003 Switch device thread event handled
2022-11-26T17:26:36.152654698+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-11-26T17:26:36.157880365+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-11-26T17:26:36.163909365+00:00 PRINT Zigbee Multi Switch and Child Mc function: on_off_attr_handler
2022-11-26T17:26:36.170939698+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: f70a5200-5516-40bc-ab5a-39ed5c6bc8a6 [0x86F6] (TS0003 Switch)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2022/11/26 Time: 17:26
DNI: 0x86F6 LQI: 144 RSSI: -57dbm
2022-11-26T17:26:36.189426698+00:00 PRINT Zigbee Multi Switch and Child Mc src_endpoint = 2 value = false
2022-11-26T17:26:36.197515032+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: f70a5200-5516-40bc-ab5a-39ed5c6bc8a6 [0x86F6] (TS0003 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“switch2”,“state”:{“value”:“off”}}
2022-11-26T17:26:36.224561698+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0003 Switch device thread event handled
2022-11-26T17:26:36.235460032+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0003 Switch device thread event handled
2022-11-26T17:26:38.097557699+00:00 PRINT Zigbee Multi Switch and Child Mc all_switches_status >>>>>
2022-11-26T17:26:38.104380699+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: f70a5200-5516-40bc-ab5a-39ed5c6bc8a6 [0x86F6] (TS0003 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:"S1:On "}}
2022-11-26T17:26:38.123732365+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0003 Switch device thread event handled
2022-11-26T17:26:38.246734032+00:00 PRINT Zigbee Multi Switch and Child Mc all_switches_status >>>>>
2022-11-26T17:26:38.293522365+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: f70a5200-5516-40bc-ab5a-39ed5c6bc8a6 [0x86F6] (TS0003 Switch)> emitting event: {“attribute_id”:“switchAllOnOff”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“component_id”:“main”,“state”:{“value”:"S1:On "}}
2022-11-26T17:26:38.391005699+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0003 Switch device thread event handled
