Please try installing wit CLI this driver version
Name Z-Wave Switch and Childs Mc
Version 2022-09-27T20:58:16.508362979
Basis switch is working as expected.
I will try to create child switches next.
Try this version to childs works fine
Version 2022-09-27T21:13:05.645321689
Childs work fine with 2022-09-27T20:58:16.508362979.
I will try 2022-09-27T21:13:05.645321689 next.
Things are working well with version 2022-09-27T21:13:05.645321689.
Thank you very much for getting this working.
If you want to fix the Multi-Tile Display, I am more than happy to test it for you.
With this version multi tile will works fine. A copy and paste failed, jajajaja…
Version 2022-09-27T21:35:17.034011845
That fixed it.
Thanks again. It’s always fun debugging things with you.
I’m glad it works well!
Also, delighted to collaborate with you
It child devices works really fast, no comparison with the much slower virtual mirror
If you want you can delete the posts with the logs, they are no longer useful for anything.
There is a way to put the log that does not take up space, click and the log or photos are displayed
Clicking on the gear and selecting Hide details
2022-09-27T21:24:40.998451033+00:00 DEBUG Z-Wave Switch and Childs Mc Luz Terraza-Switch1 device thread event handled
2022-09-27T21:44:15.459509298+00:00 TRACE Z-Wave Switch and Childs Mc Received event with handler device_lifecycle
2022-09-27T21:44:15.493020201+00:00 INFO Z-Wave Switch and Childs Mc <ZwaveDevice: ac895f6b-9e11-4a96-83a6-c4b8f175422b [20] (Luz Escalera)> received lifecycle event: infoChanged
2022-09-27T21:44:15.568906905+00:00 TRACE Z-Wave Switch and Childs Mc Found DeviceLifecycleDispatcher handler in zwave_switch
2022-09-27T21:44:15.576560743+00:00 PRINT Z-Wave Switch and Childs Mc Memory >>>>>>> 2155.546875 Kbytes
Just to update everyone Mariano has updated his “Z-Wave Switch and Childs Mc” driver to work with the Inovelli 2 Channel Smart Plug (NZW37) also sold as the Show Home 2 Channel. It works very well.
Thank you Mariano.
Yes the Z-Wave sensor driver works well open and closed. While this is not
That would be perfect! Fingerprints?
Hello @Mariano_Colmenarejo.
I have this device:
Data
MSR: 0258-0200-1027
networkSecurityLevel: ZWAVE_S2_FAILED
Raw Description
zw:L type:1001 mfr:0258 prod:0200 model:1027 ver:2.21 zwv:6.04 lib:03 cc:5E,98,9F,55,73,86,85,8E,59,72,5A,25,32,71,70,6C
which is a Neo Coolcam plug with metering.
Could you add it to your Z-Wave Switch Mc or Z-Wave Switch and Childs Mc? I don’t know which one is the best. This device has no child, so I guess it should be Z-Wave Switch Mc. Unless the Z-Wave Switch and Childs Mc replaces the other one
Hi @yosarian
some like this
Raw Description
Added to this driver version. This driver is the one that will keep updating
Version 2022-09-28T13:19:50.881297248
- id: 0258/0200/1027
deviceLabel: NEO Coolcam Outlet
manufacturerId: 0x0258
productType: 0x0200
productId: 0x1027
deviceProfileName: metering-plug
I get a few different ones (all for different SGD-211 modules):
zw:L type:1101 mfr:010F prod:0100 model:0109 ver:1.09 zwv:3.42 lib:03 cc:72,86,70,85,8E,26,27,73 ccOut:26,2B
zw:L type:1101 mfr:010F prod:0100 model:100A ver:2.02 zwv:3.52 lib:03 cc:72,86,70,85,8E,26,7A,27,73 ccOut:26,2B
zw:L type:1101 mfr:000F prod:0000 model:100A ver:0.00 zwv:0.00 lib:00 cc:72,86,70,85,8E,26,7A,27,73 ccOut:26,2B
Can you add this device to your library? (Z-Wave Bulb Mc)
Then I make a return on its operation.
zw:L type:1101 mfr:0159 prod:0001 model:0054 ver:2.95 zwv:4.24 lib:03 cc:5E,86,72,5A,73,26,33,70,85,59,25,7A role:05 ff:8600 ui:8600
Thanks!!
Hi @fido
I passed it to this thread
You can try this other Z-Wave Swich and Child Mc controller, it has some changes to see if it works better.
You can also read all the parameters to see what values they have and check them with the documentation
Added to this driver version as generic dimmer
Name Z-Wave Switch and Child Mc
Version 2022-09-28T19:25:13.56930109
- id: 010F/0100
deviceLabel: Fibaro Dimmer 1
manufacturerId: 0x010F
productType: 0x0100
deviceProfileName: switch-level
- id: 010F/0000/100A
productType: 0x0000
productId: 0x100A
