This is first time I saw in history log CurrentTimePeriod and CurrentTwilight.
Driver has calculated wrong SunRise and SunSet times using UTC offset 0.
This routine wonβt fire off, any idea why?
In history, it shows Astronomical Twilight happened at 0650 pm, but no notification was sent, and the blinds didnβt close.
now the valures wil be :
βCivil-Twilightβ
βNautical-Twilightβ
βAstronomical-Twilightβ
I have fixed it in this version of the driver.
You will have to redo the routines, sorry.
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Aplicaciones Virtuales Mc
Version 2023-02-19T11:30:26.620768014
Hi @nayelyz I donβt know why the presentation of the capability does not execute the automations when the text value to be compared has a blank space between words.
I already had similar to this problem and reported to with another capability and I didnβt remember
This capability presentation does not fire the automations with condition values have a blank space:
Hola @Mariano_Colmenarejo
Everyday I spend in the community I find more βgreat surprisesβ from your drivers
Today it was the day to discover βAplicaciones Virtualesβ. Iβve read the whole thread and installed it and created the Virtual Calendar.
However I donβt see some of the variables that you added like: βDay/Nightβ, βCivil Twilightβ, etc.
I only see these ones: Local Date, Sun Rise, Sun Set, Day Length, Sun Rise Offset1, Sun Set Offset1 and Local Hour Offset.
My driver version is 2023-01-18T16:48:04.
Am I doing something wrong? I am planning to use this Calendar as Iβve seen many good ideas in this thread.
If you only have created the virtual calendar you can:
delete the calendar device and the main device creator and then delete the old driver from your hub.
Then you go to my channel and install the latest version of the driver
With daylight savings time starting in just under 3 weeks in North America is there a way to automate the βLocal Hour Offsetβ each spring and fall?
In North America daylight savings time starts at 2 AM on the 2nd Sunday in March (March 12th this year) and ends at 2 AM on the 1st Sunday in November (November 5th this year). The problem is that the calendar date changes every year.
I could use IFTTT linked to Google calendar, but I donβt find IFTTT calendar Applets to be very reliable.
Did something happen to switchboards? I have a switchboard-3 and a switchboard-4, which are/were working fine. Iβm trying to consolidate some switches into two switchboard-4s now,
in the 'then' section I can only manipulate switch-1,
I went to edit an existing switchboard, and now Iβve lost control of the other switchesβ¦
Also, can the tile show the name of the switch instead of S1/S2/S3β¦ if only in the max 1 switch mode would be nice. Itβll save me having a text-field-5 wasted to get the max 1 switch label to appear on a tile somewhereβ¦
yup, itβs a bug in the new iOS version. On another device that hasnβt gotten the update yet, it works. (unless itβs also a difference between iOS and ipadOS with the SmartThings App, since it occurred to me the last time I worked on getting my switchboards workingβ¦it was on my iPad while watching my laundry tumbleβ¦)
The connection between the iPad version and the iPhone version is broken now, too. I saw a while back that when I moved a tile on the iPad, it updated the positon on my iPhone. But, now my iPad has everything all jumbled upβ¦while the iPhone still has everything where I want them (and that was since it had logged me out, where I found everything scrambled when I logged back inβ¦)
Are you sure? Maybe this was for Favorites because otherwise there has never been any sync of Device (or Room) orders between iOS devices. It used to on the old ST legacy app.
At least they fixed the issue when creating a routine, the device is only initially placed in the βthenβ section instead of the prior behavior of In both sections. Was annoying when I was creating a bunch of routines where the device was and only the βifβ conditionβ¦ had to think about creating routines differentlyβ¦ though still a pain when thereβs more routines using the device as an βifβ, than the other devices as 'thenβs. Along with the cases where a device is both an βifβ and a βthenβ.
Have a lot of rules of βifβ foo and the light is on, then dim the light to XX%. Though itβs annoying that light has been slowly dimming through the evening, it suddenly flashes at full daylight brightness because I said βAlexa, Good Night.β For my WiFi bulbs, the turn-off routine is to dim them to 1% and then turn them off. That way if thereβs a power outage overnight, theyβll only come back on at 1%. But, now that itβs mandatory to turn it on, in order to dimβ¦ And, this was after I had gone through everything making sure I was only dimming and not also turning on lights. Just as I had gone through to make sure that I was only pressing buttons momentarily, and not also turning them on (randomly, the action triggered by the button would fire twiceβ¦)
Could be a work in progress, 'cause I thought I read somewhere that they were going to do thisβ¦they did sync the order of my rooms recently since I had one room that was either first or last depending on my mood, and slight differences in what was considered my rooms in clockwise order (from the front door.)
The room that is either the first or last one is the room I have the devices that create devices in (and more recently my hub).
I know I had complained last year, that every so often it would scramble the order of my rooms. Hated when Iβd be swiping left to get to some room, only to find that I shouldβve been swiping right because it had moved on me.
We can only hope. But Iβve been bitten by that before by ST, just a few times .
After all this time if they canβt maintain orders after a sign out of the app then I think hoping for a sync of orders across devices might just be a little too hopeful.
Modified the code of the SwitchBoard devices so that it shows the custom name of the switch that is On in the tile, for the type only Max one switch On
new driver version will be updated automatically in the next 12 hours maximum
Version 2023-02-26T10:38:06.719921321
