Thanks Milan
I used WebCore to make a setup with master/slave lights so that in Actiontiles I had a tile with one bulb that I could turn on/of and dim and other bulbs followed this through a piston in WebCore that copied the parameters from the master bulb. I miss this opportunity after WebCore and that ActionTiles doesn’t support groups of lights.
Maybe I could recreate it with a virtual device and routines - but how do you make the routine that changes in relative numbers (+/-5%)? As I see it, I can only make routines with absolute numbers
Others that have solved the master/slave issue in other ways?
@Mariano_Colmenarejo my understanding was that he wanted to switch the colors with push of single button. Every time he presses the physical button to change the color.
Fantastic! It work very well and I can use whatever color I want… thanks you @Mariano_Colmenarejo… now i don’t need anymore a boardswitch with 8 switch… now I have my new textfield cyrcle!
Thanks also to @milandjurovic71.
I do not think this is a routine issue, but I thought I would ask the guru @Mariano_Colmenarejo. My routine did not work this morning, but I believe it is related to the U.S.A time change, as I have other time based automation issues, are these routines correct?
I noticed that it changed the time in the automation, but when you go to edit the automation, it’s set at the original time
It may be that today, Sunday, according to the last capture, the time 03:00 did not exist and it went directly from 02:00 to 03:01, but I don’t know for sure
Do we have to reset the driver manually for daylight saving time (there actually is no s on saving)? I changed my offset so that time is correct. Although, I am testing it, and I have a text sent 20 minutes before sunrise, and it seemed to use the correct time this morning (pre adjustment manually for DST), so I wonder if it does adjust for DST?
All calculations are made with respect to GMT time and are adjusted to local time according to the entered value.
Everything should work fine once the local time offset to GMT is updated.
