I’ve got the lifx bulb set up on one of the home control buttons on the harmony remote now, and set up a smartthings routine to turn on the smart plug when the light is on, and off when it’s off.
I was hoping that there’d be more control options within harmony for the bulb other than just on and off so that I could assign the other controls to my other smart plugs but it doesn’t look like this is possible.
For anybody having problems with their Harmony Hub connecting to SmartThings (ie it used to work but no longer does) then I can confirm that this worked perfectly and my Harmony Hub is now controlling things in SmartThings again (I use TP-Link extension leads which I turn on and off but this should work for any device). Thank you so much for this.
Enter IP address in settings (note that this is the IP address of your Harmony Hub) - as per step 3
In SmartThings you will now see each Harmony Activity - create routines to be actioned when the Harmony Activity has state on and again for state off. As an example I have a Harmony activity [Turn TV On] with a routine in SmartThings which turns on the TP-Link socket when the Harmony Activity has status ‘On’
The driver continues to be the integration that stops me from losing my temper and junking anything Harmony for good Thank you so very much for the updates you have made @lmullineux
I do have a question on the feasibility of somehow getting the home control buttons on the remotes into the mix with this integration. I get that with the driver we can now send commands from smart things via the hub and that activity states can be used as triggers in smartthings
My question is if it would be possible for the home control buttons on the remote could somehow trigger something in smart things? The biggest impact on the broken native integration is that the lights and plugs that the remote could previously control is no longer functioning. Any realistic way that the signals sent by harmony to smart things could be reserected?
This has been covered several times. Unfortunately this would require Harmony/Logitech to do something at their end. It does not look like that is going to happen but anything is possible.
There is one thing that I used to do that I can’t seem to get working. My TV will power off after a certain period of inactivity. Using WecCore, I was able to sync the state of the Harmony activity by setting the activity to off rather than turning it off, essentially just updating the state without actually switching it off. (I know the TV is off by reading its power draw.) Then, Harmony would know it’s off and if I turn it an activity on, the TV would come back on rather than stay off, with Harmony thinking it’s already on.
I guess my question is, is the bridge able to set the state rather than flip the state or, in other words, can it tell Harmony that it is off without actually turning it off?
Looking at this from the root cause aspect, that sounds like a power save setting on your TV. Can you not change that so that it simply doesn’t turn itself off?
Hi sorry for the slow reply, I’m currently on holiday and staying away from the computer.
The short answer is, No - there is no way that I’m aware for an activity to stop without it actually executing it’s power off routine inside harmony. (But I’ll look into this properly when I’m back)
If you have power draw, could you have a routine in harmony to check power draw after the activity is started, if it’s below a threshold send a harmony device command to turn on the TV?
This is a strange one.
One of my hubs have suddenly started doing things on its own.
So if I’m watching something on my nvidia shield, it’ll suddenly go back to the Home Screen, and the volume goes down, like it’s some sort of automation. I don’t have any sort of automation.
No problems here. What exactly stopped working? Remember that Logitech/Harmony shutoff the direct integration some time ago (IIRC around June) so directly controlling ST via the device control buttons at the bottom of the Elite no longer works although their are a few work arounds using other devices/integrations (scroll back thru the discussion here for info).
I have about 8 hubs working great. I’d say in the last week all of a sudden any command in SmartThings doesn’t respond. Had it linked to Alexa, for example turn on living room tv, get an acknowledgment from Alexa harmony hub light won’t blink. Reset SmartThings hub and harmony hub same result
