Has anyone used or tried the Ecobee switch that has built in Alexa with ST. Wanting to hear from anyone that knows if it works without problems.
Thanks Mike
I like mine except the PIR sensors in them triggering occupancy from the ac temperature fluctuation and turning on the lights.
I have two. One near my kitchen sink and the other in my laundry room. Mainly, I wanted a small speaker and Alexa compatibility while in those rooms. I have not had the problems with the passive infrared that Diademz was talking about but none are near any vents.
I wish that at DTH would come out to fully integrate them with SmartThings. I would like to add the motion sensors like you can with the temperature sensors.
But, the light on/off function works well with SmartThings through the default SmartApp. If you use a different SmartApp for the Thermostat than the default, only add your switches with the default SmartApp and leave off the thermostat. I run it for the switches and Ecobee Suite Manager for the thermostat.
