I’ve been looking at a few integrations for my 2 ecobee3s and smarthings.
What I’m looking for is this scenario.
If the temperature difference between 2 sensors is >x degrees, then switch the fan from auto to on. (Also turn my z-wave ceiling fan on)
If the temperature difference is < x degrees, turn the fan back to auto.
I would also like to set if the temperature upstairs (ecobee3 thermostat 1) is different than downstairs (ecobee3 thermostat 2) turn on the ceiling fan.
Rule Machine can do the logic, and would work for my ceiling fan.
But it looks like there is not a Ecobee fan toggle endpoint though. @yvesracine, @StrykerSKS, is there a way that you can send a fan command to ecobee.
And I’m in the process of adding the fanMode support to the Open device type that I released. The stubs are all there, I just need to connect it all up.
I should have this completed by next weekend at the latest, maybe even as early as today. We already have over 80 people using the device type and I’ve been continuously adding features and fixes since I launched it a few weeks ago.
I think I am doing this now. The weather has been pretty nice here so it’s hard for me to test this properly, but I think I have it.
In order to accomplish this, you will need StrykerSKS’s Ecobee smart app and device type referenced above.
Anyway,here is my rule. If you see any logic errors, let me know.
Upstairs >= Downstairs +3
OR
Upstairs <= Downstairs -3
True = fan on
False = fan auto
BTW; there is not a Resume action, so I am just returning the fan to auto. this holds it in auto. Not a big deal since I have the default resume setting to resume on next scheduled program change, in the StrykerSKS Ecobee smart app. However, I may try a custom command in RM and see if I can get a resume command to work.
I will post later to let you know how testing goes. It’s the South, the weather is bound to change soon.
So far, so good. It got frosty last night so I got to see my rule in action. Worked like a charm.
Now, my example is for keeping the temperatures within three degrees. I chose this because my upstairs is often considerably warmer than my downstairs. If I went with a straight match the fan would run all the time. A three degree offset is comfortable enough and more economical, for me anyway. So, what happens is; if the temps are off by more than three degrees, the fan comes on. As son as they reach the three degree offset, the program resumes. So I never get an exact match in temp unless it occurs naturally.
If you want to match exactly, then I expect this rule should cover it:
