Echo speaks server error
During updating the heroku server I get to the part where I deploy the server and it takes me to the amazon login screen ,but goes to a blank heroku page and the setup option is still in the echo speak app. What am I missing?
Did you verify the correct Amazon region is set?
Are you following the instructions here?:
https://tonesto7.github.io/echo-speaks-docs/#/docs/installation/configuration/serverConfig
What version of the echo speaks server are you running?
@tonesto7
I am following the steps here:
https://tonesto7.github.io/echo-speaks-docs/installation/smartthings/github_install/
1) Give a description of the problem
While setting up Echo Speaks, I get to the step where I am performing Update from Repo, select the three “new on GitHub” items for echo-speaks
select Publish checkbox, Execute Update, and then get the following error:
2) What is the expected behaviour?
Load Echo Speaks into My SmartApps, which I will later allow webCoRE to access via the Classic app
3) What is happening/not happening?
See the error in 1.
4) Post a Green Snapshot of the pistonimage
See 1.
5) Attach logs after turning logging level to Full
N/A
I have webCoRE set up and working fine, having followed similar steps. I have been using it for months. I did log into GitHub separately and try again, no difference, still getting the above error.
Please provide any assistance you can.
Try logging into IDE using an incognito/private tab in your browser
Unfortunately, same result in:
Chrome normal
Chrome incognito
Firefox normal
IE 11 normal
I am going to go through all the settings I can to see if I can discover an issue. I do not understand how this could be, as it seems like it is ultimately just communication between the Smartthings servers and GitHub.
I went through the manual process here:
https://tonesto7.github.io/echo-speaks-docs/installation/smartthings/app_install/
When I get over to Heroku per the server config process, the URL in the instructions is not the same as that which is shown. The instructions show:
tonesto7/echo-speaks-serverf#dev
where mine shows
tonesto7/echo-speaks-server#master
I mention that because when I put in the App name provided, it tells me “echo-speaks-zzq0z9xxx” (last three x’s blocked out in case personal info) is not available.
Up to this point, I have tried this through GetHub, and received a server error. I backed that out and went with the manual process. Now I am at the server portion, have copied the name the app provided, and get the above error.
Any help appreciated.
Did you add and then delete a space at the end of the app name as detailed in the instructions?
It’s step 4 of the server configuration.
No, I stopped when I hit the failure and tried to find solutions. I see in looking through the rest of the instructions that this is likely operator error. I’ll try it later today.
Thank you!
