I want to convert an analogue voltage output in to a dry contact.
How is best to do this. I believe the output from the sensor is the same as the input. This can be from 5-24v DC. But for my use I need to change this to a dry contact for monitoring.
I use these for dry contact sensors they work great. They can be used as a door or window sensor but they also have a dry contact sensor in the main body. https://www.amazon.com/gp/product/B01N5HB4U5
I need to connect a voltage output on to a dry only solution. So I need a relay. Just can’t work out which one I need or if anyone makes a mini module.
Well, that is a big range. But one of your easiest options actually is to use a 12v automotive relay and a modified Contact sensor (one that allows for external contacts). The GoControl WADWAZ-1 is one that does this. You would wire your output to the coil side of the relay so that when it was on, it would provide contact to the other side of the relay, therefore closing the loop for your contact sensor. Much cheaper and easier than a dry contact.
A USB wall wart is plugged into the same circuit and keeps the relay closed. If the circuit goes out the relay opens and I get an alert that the power is out.
This is what I am looking for. I assume I would use the IN port to signal the relay to switch not the DC only like you are using? I assume DC +/- only fires the relay and the IN port turns the relay off again? allowing this to do both functions?
