Plus 1 on swann.
Please see this method
You can add text to speech (TTS) using VLC Thing
https://github.com/statusbits/smartthings/blob/master/VlcThing.md
And then use any smartthings sons app throughout your home.
Looking for ST support for the Carrier Cor Programmable Wi-Fi Thermostat TP-WEM01 and/ or TP-WEM01-A. Does this exist and/or could be considered? The -A version appears to be compatible with the Apple HomeKit.
I see a newer version of the Carrier Cor (5c and 7c) are to be released in April 2017, and is supposed to be more friendly towards automation and compete harder against Ecobee & Nest. Iāll probably hold out for that those to get released and hopefully some integration into the SmartThings hub can be done then.
Carrier press release on new Cor
https://www.carrier.com/carrier/en/us/news/news-article/carrier_cor_thermostat_expands_lineup.aspx
Hopefully ST compatible as well. Have a Carrier and pretty restricted on what is compatible - bit $300!!!
http://www.insteon.com/ceiling-fan-controller/
I need to be able to control my five ceiling fans individually through my SmartThings HUB. Three are currently controlled solely by remote controls and two have an on/of switch on the wall with light and fan speed controlled by dangle cables.
Technical support has got nothing. HELP!
This topic has a lot of posts in it but look above and youāll see this was actually addressed here somewhat recently. Take a look at the other topic thatās mentioned for a fan/light control that uses zigbee and is hopefully available from Home Depot soon.
How about Aeon labs Double Micro Switch and Smart Switch 6.
Those should work with ST. The double switch might need a community-developed device handler, I know that in-wall relays from other brands tend to need that to work. But the smart switch should pair as a generic z-wave switch.
Thanks for the advice. Where can I get the device handler for the Double? I
got the handler for the 6 from git hub but I still canāt get it to load a
Smart App. Iām new to this but enjoying learning. I have a tech background.
Roger H Proulx II
*General Contractor *
CSLB# 805883
15152C Campus Park Drive
Moorpark, CA 93021
805-517-1905
There are several posts in this forum about dual relays, I donāt remember if any are for the aeotec dual relay specifically. But look at some of the handlers written by @erocm1231 as a starting point to see if any will work for you.
Iām not 100% sure what you mean but thereās a difference between device handlers and smartapps. So that may be the issue youāre describing? This post discusses custom code in ST if you want to learn more.
If you have more questions about your situation feel free to take it to another topic. This oneās supposed to be limited to discussion re: devices that arenāt supported by ST at all.
Thanks Mark! I will check this out and also use another topic,
Roger H Proulx II
CSLB# 805883
Moorpark, CA 93021
805-517-1905
Airtopia.com has a great controller that works well with all brands of remote IR controlled air conditioners see their video at https://youtu.be/pLeTnU-10Ug
This is one I am interested in. I have not purchased them yet,but I am planning on buying two.
Lutron Caseta has pretty cool Sonos integration with the Pico remotes for audio, and they have remote holders that fit into standard wall plates.
I need an input that will accept a dry contact closure. I have tried the MIMO and the MIMO2 and have had no luck on the input side even with their device handlers.
I just found Aeon Labs Dry Contact Sensor Gen5 but Smartthings doesnāt support it.
This a major issue of not having an input device. Anyone know how to get around this
I would ask in some of the Mimolite threads to see if you can figure out whatās going on there.
As far as the Aeotec contact device, it reports as an open/close binary sensor so it can definitely be used with SmartThings as a generic door sensor.
There are some community members who have customized the device type handler to reverse what is reported as āopenā. You can see that work in the following thread (this is a clickable link)
It works well. I am using them for to read a old alarm system with relay, a yard light with a relay and a heating boiler with a relay. So I have 3 at each of two locations. Set up is under open /closed sensors is this weeks version of Smart things as a Aeotec Dor/Window Sensor (Gen 5) mostly all z wave things work but only one function. Also using 4 Fibaro Door Window sensors which have connections so it can be used a a dry contact sensor and is much smaller FGK 101 -107. I use the Mimolite for a momentary switch on a garage door and a automatic Gate but use a dry contact sensor with a garage door armored door magnetic switch to sensor the gate and on the Garage door I use the positon function on a Smart things door switch and that shows up as a garage door in the APP. Anything not a Samsung part takes some messing around and when setting thing up you do it and walk away wait a few hours and the server will figure it out. The Z wave things are funny about getting them to join. I am up to 87 Devices on 2 hubs in 2 countries
Motion Detector for Outdoors?
I have an iDevices outdoor 2 outlet plug that I would love to have available within Smartthings but I havenāt seen any integration yet. It does have Homekit compatibility but I donāt use that much.
