Hi, is there any way to sync between the physical switch state to virtual switch?
I have the situation like this: I turn off the virtual switch by alexa, later, I turn on physical switch. after that, If I use Alexa to turn off the virtual switch, it says ok but didn’t do anything because the virtual switch is off already.
I have read another post that can sync two switches but it not for multiples switches device:
I’m don’t know about this coding language so I don’t know if it can be use here.
Why not create a Routine or Piston in SmartThings that when Physical Switch is turned on, set Virtual Switch On as well.
I’m assuming that you already have a Routine created in ST for when Virtual switch is turned off either via Alexa or manually changing it to Off in ST that the Physical Switch turns Off.
