I’m looking for clarification on device.value as seen in these docs compared to getDataValue.
// use of device.value
void deviceDescriptionHandler(physicalgraph.device.HubResponse hubResponse) {
def body = hubResponse.xml
def devices = getDevices()
def device = devices.find { it?.key?.contains(body?.device?.UDN?.text()) }
if (device) {
device.value << [name: body?.device?.roomName?.text(), model: body?.device?.modelName?.text(),
serialNumber: body?.device?.serialNum?.text(), verified: true]
// use of get data value
def sync(ip, port) {
def existingIp = getDataValue("ip")
def existingPort = getDataValue("port")
if (ip && ip != existingIp) {
updateDataValue("ip", ip)
if (port && port != existingPort) {
updateDataValue("port", port)
// building device with standard addChildDevice
def params = ["label":"something","completedSetup":true,[data:["verified":true]] //tried with and without the verified
device = addChildDevice("tagyoureit", lightGroup, childMac, hubId, params)
device.getDataValue("verified") // is true
device.value << ["verified":true] // throws error
device.value.verified // of course doesn't work either.
I’m building a smart app with a composite device that has children. I am looking for a way to verify the children and the
device.value << [verified: true]
looked like it might be a solution. But it doesn’t appear that
getDataValue("verified") == device.value.verified
Can someone articulate how device.value is used in the example referenced? TIA!
